T2 Chip Programmer Tool
This topic is closed.
+ More Options
Posts
  • kevingill
    • Jun 2013
    • 152
    • England
    #181
    Re: T2 Chip Programmer Tool
    Originally posted by gugbobgug
    and it still works ? today ?
    Yes, once it's tied to your Apple ID, all updates go through and it works fine.
    • ugamazing
      • Jun 2013
      • 165
      • usa
      #182
      Hey guys, I just found this thread. I am up for helping in any way I can with regards to pulling any dumps from any boards needed. I have basically every model of T2-based Apple laptop logic board, with as many as 20-30 iCloud locked of some models. I've been setting them aside in hopes an activation lock bypass/removal that's permanent comes about.
      I miss the old days of using a headless Raspberry Pi to remove locks. These damn T2 chips are really aggravating us.
      Thanks for all the work you guys do and progress you make. I've not checked in too much on the status of a lock removal, but am ever-hopeful.
      • tungtuoitinh
        • Feb 2022
        • 10
        • Vietnam
        #183
        and with monterey does it work ?
        i think apple patched this
        Originally posted by Pedro147
        I'm wondering, if in recovery mode "starting internet recovery" is shown under the image of the earth, then surely it can't be bypassed, right? is there any chance for this new bridgeOS case?
        In my case,My Macbook air 2018 can't boot into macOS , it's stuck in select wifi to recovery, but i forgot password,it hang on at" activation lock" ,so i can't check version bridgeOS
        And the last question, can I use hackintosh device with usb A to use bypass tool?
        • Rickkap
          • Aug 2015
          • 128
          I've had the T203 for some time now and after the update it stopped working, I also noticed that Union stopped selling it so i presumed that there was no way for getting round this anymore. I then came across the Stephen's guide but it was too late for me as i've already config 2 after trying to replace the serial number. So my question is there anyway round this or do i have to wait until a fix? I also tried Check8 but they don't support the A2141 probably since i stupidly used config 2.
          • sinaps1
            • May 2022
            • 8
            • Albania
            #185
            Never thought would find something lik this support forum so much dettailed in everything! Congrats to all the staff.
            I got a A1932 T2 model activation locked that is stuck in only intermet recovery.
            I tried even in DFU mode with checkm8 soft to try if it is identified but without success.
            The Comand-R combination or any except the DFU doesnt work.
            By any chanche is any possibility from DFU to get the OS version or the iBridge OS version?
            I want to figure out if has been updated to the latest version, my colleague kept connecting with wifi in recovery mode.. and from researches found out that if it is locked is stuck in internet recovery mode only.
            Any suggestion to do any verificarion in this state. I am pretty sure if I programm the T2 ROM will stuck in DFU mode bricked.
            • tungtuoitinh
              • Feb 2022
              • 10
              • Vietnam
              #186
              you should check the previous pages, it have image how to check old bridgeOS vs new bridgeOS ( with new bridgeOS have "start internet recovery") after connect wifi
              • sinaps1
                • May 2022
                • 8
                • Albania
                #187
                Yes I have a new bridgeos but my previus question was regarding the versions. If this macbook is at latest version or something a bit earlier? So at least I will know when something comes out for the version I have.
                • tungtuoitinh
                  • Feb 2022
                  • 10
                  • Vietnam
                  #188
                  I think you should dump t2 chip rom and check iboot version, im not sure is that true, so i need comfrim from others
                  • siddiq
                    • Dec 2011
                    • 121
                    • Ghana
                    #189
                    Yes, checking iBoot in the dump works..
                    • sinaps1
                      • May 2022
                      • 8
                      • Albania
                      #190
                      Found it. is a version iboot-7459 and I guess is updated to the last one.
                      I am not sure if I re-programm the ROM with an older version will cause the Macbook fail to boot at all.
                      Did anyone tried to flash the T2 ROM with older Bridge OS after it was updated?
                      After I changed the serial number on the same .BIN file of the ROM it is not able to contact the APPLE server.. seems like the contact POST method is tied to the Serial number in the ROM.
                      The serial Number was checked online if it was available and correct.
                      P.S. Still testing and digging we will find one way!!
                      • kevingill
                        • Jun 2013
                        • 152
                        • England
                        #191
                        There are a few ROM dumps on this thread.
                        Can you compare your ROM with another posted here?
                        I'm not sure what the differences are either.
                        • sinaps1
                          • May 2022
                          • 8
                          • Albania
                          #192
                          There are a lot of differences, I tried to compare the A1932 that is the model I have!
                          The files are very different, and also the Boot sequence is different as it is not declared in the files that are here, instead the original one have some boot sequences inside. Because of this I asked if someone tried with the latest BridgeOS to rewrite the old one. Sincerely I have to unsoldering and soldering again the chip and then retry the bypass/activation.. before going through all the work and risking a board damage thought to ask if someone tried before.
                          Any suggestion for a software to decompile the .BIN files to something more understandable? I tried some software found online but without success!
                          • smzlwan223
                            • Mar 2022
                            • 20
                            • 中国
                            #193
                            [QUOTE=sinaps1;1137421]Found it. is a version iboot-7459 and I guess is updated to the last one.
                            P.
                            • smzlwan223
                              • Mar 2022
                              • 20
                              • 中国
                              #194
                              I have an A1932, did the following experiment, 1, try to read the Rom to the latest version of the ROM im4p.. Illb .. Iboot-7459.101.2... Change it to the old jailbreak version number, M4P. Illb .. Iboot-6723.80. 9, change the inside data, Swipe Rom, power test, found that the computer can not start, feeling ROM IC is not good welding, welding a few times the same effect, 2. Finally, the original backup ROM data brush to write in, the computer can boot, the current test through this experiment, came to the need to verify before boot, t 2, Rom version, so I went on to do the second experiment, or the Rom to jailbreak version number, then connect to the computer to fix T2, wait for the computer to turn on, see if it can jailbreak, the result, or has failed, and then, remove the ROM, see again to fix T2 in the process of T2, the ROM version number has changed back to the latest version number, the result of the experiment, is, the version number of t-2rom data is, the old version number, through the experiment, one point is that the version number of the Rom, is not the basic data of his jailbreak, I do not understand the software very well, I hope you friends, have a good plan, I can do the experiment test, that's all I have so far.
                              • smzlwan223
                                • Mar 2022
                                • 20
                                • 中国
                                #195
                                Check to see if the ROM version number was changed back to the latest version number in the process of fixing t 2. The result of the experiment is that the version number of the t 2 Rom data is the old version number. The experiment shows that the ROM version number is not the fundamental data for his jailbreak, my software is not very understand, hope you friends, there is no good program, I can do experimental testing, at present my inspiration only these.
                                • curiositymaster
                                  • Apr 2021
                                  • 45
                                  • Nigeria
                                  #196
                                  If you change the S/N of a T2 device, it will not pass the activation process as it won't be able to march the serial number with the bluetooth and wifi address.
                                  • Stephen
                                    Meow Meow MEOW!
                                    • Apr 2020
                                    • 667
                                    Incorrect. MDM devices are the only devices you can change the serial number on T2 chips without issue. If it fails to activate on the server, the T2 chip itself was already activated and has the original iCloud and SN tied to the device.
                                    sigpic
                                    MEOWING IN THE IMPOSSIBLE UNIVERSE!
                                    • newmac
                                      • Mar 2022
                                      • 7
                                      • Phillippines
                                      #198
                                      Can i use Mina T2 rom bin file to manually flash the T2 rom? Mine doesnt have a icloud lock it just wont restore using apple configurator. From what i know if i use the Mina bin files my serial number would be changed also would that be a issue?
                                      • heatorious
                                        • Apr 2020
                                        Do you get a error when you try to restore?
                                        • newmac
                                          • Mar 2022
                                          • 7
                                          • Phillippines
                                          #200
                                          Error i get is Unexpected device state 'DFU' expected 'Recovery' [com.apple.MobileDevice.Restore - 0xFAE (4014)]
                                          all of T2 standby power is present.
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • baletak
                                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                                            by baletak
                                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                                            I have updated laptop model number.
                                            1) I did not find the way to update laptop serial number - I have this one.
                                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                                            Many thanks
                                            Miro
                                            05-23-2025, 01:21 AM
                                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                                            by SMDFlea
                                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                            and once you do find them there`s a few crucial steps missing.
                                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                            After adding the chip save the xml file and copy it to the root directory of the...
                                            05-26-2024, 07:15 AM
                                            by SMDFlea
                                            Bad...
                                            09-02-2021, 04:40 PM
                                          • BMCappelletti
                                            Asus Chromebox CN62 - wrong chip put on BIOS reader
                                            by BMCappelletti
                                            Long story short:
                                            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                            - gave the computer to his son a couple years later
                                            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                            (seems like the story was not that short)
                                            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                            01-08-2025, 07:27 PM
