T2 Chip Programmer Tool
This topic is closed.
  • mich6el
    • Dec 2015
    • 18
    • Ukraine
    #301
    Re: T2 Chip Programmer Tool
    Hi people! The experiment has ended successfully! After replays T2 chip and SPI from water damaged board and restore via dfu mode - i have clear activation window and a can install OS system from recovery! Сalculator was fucked!
    • curiositymaster
      • Apr 2021
      • 47
      • Nigeria
      #302
      Originally posted by styleangel
      warn someone buying a new mina tool. Apple did something to T2 and it doesn't work anymore
      From what you have here, this will still work; you only need to try it again and make sure your Mac is connected to the internet.
      • kevingill
        • Jun 2013
        • 152
        • England
        #303
        Which bridgeOS was your MacBook running BTW?
        • serkrn
          • Jul 2022
          Have you tried to copy the firmware from a flooded macbook to a locked one?
          • LevanGood
            • Jun 2022
            • 10
            • Ukraine
            #305
            Hi! Just done T2+soc rom replacement.
            Mac charges, touchpad becomes active, it can be connected in DFU mode but restoring T2 in Apple Configurator can’t be finished because restore freezes in the very end of progress bar((
            And yep I have black screen too. How did you deal with it?
            P.S. USB init tester doesn’t show init(
            • mich6el
              • Dec 2015
              • 18
              • Ukraine
              #306
              Unfortunately I didn't test it, the laptop was showing the activation window. How to check it? Is this information in the SOC ROM chip?
              • mich6el
                • Dec 2015
                • 18
                • Ukraine
                #307
                Yes. But it not working, after replays only soc rom I have windows "activation server not found". I think t2 chip and sock rom must be together.
                I conducted a second experiment, if you solder the blocked T2 to the working board, then we get the activation window. icloud in t2 chip 150%
                • mich6el
                  • Dec 2015
                  • 18
                  • Ukraine
                  #308
                  Mac charges, touchpad becomes active, it can be connected in DFU mode but restoring T2 in Apple Configurator can't be finished because restore freezes in the very end of progress bar((
                  P.S. USB init tester doesn't show init(
                  1. Check resistances on all coils near PMU (a2179 u7800).
                  2. Check the resistances on all coils of the board.
                  3. Voltages do not jump?
                  4. Check if the SOC rom chip is installed correctly?
                  5. Do you enter dfu mode through a test point or a key combination? If the laptop does not see the SOC ROM it will be in DFU by default
                  6. Are you flashing a laptop with a connected power supply and battery?
                  • LevanGood
                    • Jun 2022
                    • 10
                    • Ukraine
                    #309
                    It was a good-working laptop before T2 replacement
                    1. Everything’s ok
                    2. See #1
                    3. With the unlocked T2’s soc rom mac reboots when current becomes 0.9A (but still no picture). With original soc rom from the locked board current is 1.96A, no reboots, both fans are on 100% speed but Apple Configurator still can’t restore the device.
                    4. Yep it is.
                    5. I have to pull the mac in DFU with a key combination on kb.
                    6. Yep. Battery is 100% charged and dc power supply connected.
                    • mich6el
                      • Dec 2015
                      • 18
                      • Ukraine
                      #310
                      1. Everything's ok
                      2. See #1
                      3. With the unlocked T2's soc rom mac reboots when current becomes 0.9A (but still no picture). With original soc rom from the locked board current is 1.96A, no reboots, both fans are on 100% speed but Apple Configurator still can't restore the device.
                      4. Yep it is.
                      write me in ********, number in private messages
                      • LevanGood
                        • Jun 2022
                        • 10
                        • Ukraine
                        #311
                        Sorry but I have no new messages.
                        I just sent you my TG
                          • 24922
                          A reminder about the rules
                          • bluestone
                            • Jun 2011
                            • 343
                            • Ghana
                            #313
                            Okay so some people claim there is a way to remove efi lock from T2 using hardware no apple configurator required. Anypne have idea about that method?
                            • kevingill
                              • Jun 2013
                              • 152
                              • England
                              #314
                              Please read the whole of this post to see how this can be done
                              • bluestone
                                • Jun 2011
                                • 343
                                • Ghana
                                #315
                                I don't think it involves replacing the T2 chip, they say it's possible to remove it from the SOC rom
                                • mich6el
                                  • Dec 2015
                                  • 18
                                  • Ukraine
                                  #316
                                  NO, it was empirically established that icloud is in T2 and not in SOC ROM! See post #301
                                  P.S. I soldered the blocked T2 to the working board and saw the activation window. Icloud in T2 chip 150%
                                  • gancy
                                    • Jan 2021
                                    • RD congo
                                    #317
                                    Originally posted by Stephen
                                    Not true. MDM can still have Activation lock to the company email. Changing the serial will solve this issue and remove the lock for good. Even with iBridge 6+
                                    Activation lock of T2 with ibridge 6.0 or 6.1 is already able to be unlock?
                                    • Rickkap
                                      • Aug 2015
                                      • 154
                                      1. Remove the Winbond chip.
                                      2. Read the data off of the chip, then save the data to your Desktop (windows pc only)
                                      3. Run WinHex, change the serial MANUALLY that is on Mina that is used to unlock it. (IE: In the T203 tool data it will have the Serial plugged in the UNLOCK CODE. Just run WinHex and look for the serial and copy it and paste it. This is the serial activated for Mina.)
                                      4. Then run the jailbreak, then turn on the computer once its jailbroken and activated, reinstall the OS, complete OS setup. Create user and password. Then shut down computer. Remove board if necessary
                                      5. Remove the chip, read the chip via T203, copy the data from that chip on to the desktop, run WinHex and change to the original serial of the device, save the file as a .BIN then program the file to the chip. IF YOU DO NOT DO THIS the chip will be corrupted and you will have to do it all over again! That includes reinstalling the OS. (DO NOT USE THE MINA SERIAL it will run into issues).
                                      6. Solder chip back on then turn on and verify the serial and model of your computer in ABOUT THIS MAC. Voila unlocked and working. No need to patch with DFU.
                                      Fantastic read of this thread and i have a question mainly for @Stephen but maybe others might be able to help.
                                      I have an A2289 with the old BridgeOS (5.4). Followed the above instructions, replaced the original serial number with what can be found in the Mina folder, wrote it back to the chip, started it in DFU mode but when i run the bypass app, i get an Error saying 'Mina T2 Bypasser Tool DeviceInfo tampered - Good try modasucka!!'
                                      What an i doing wrong or is it not possible to do it this way anymore.
                                      • styleangel
                                        • Nov 2014
                                        • 9
                                        • Viet Nam
                                        • love apple devices
                                        #319
                                        Apple block all software jailbreak bypass. All tool and software bypass no working :gà mờ::gà mờ:
                                        • styleangel
                                          • Nov 2014
                                          • 9
                                          • Viet Nam
                                          #320
                                          i have tested on all other macbooks and same case it seems the mina software is blocked, and of course tried all the connecting cables
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • baletak
                                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                                            by baletak
                                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                                            I have updated laptop model number.
                                            1) I did not find the way to update laptop serial number - I have this one.
                                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                                            Many thanks
                                            Miro
                                            05-23-2025, 01:21 AM
                                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                                            by SMDFlea
                                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                            and once you do find them there`s a few crucial steps missing.
                                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                            After adding the chip save the xml file and copy it to the root directory of the...
                                            05-26-2024, 07:15 AM
                                          • Tesla
                                            Basic Questions about using XGecu-T76 with pogo-tool to fix motherboards
                                            by Tesla
                                            I was wondering if you more experienced technicians could help answer some basic questions I have ... and help me build a reliable work-flow for using my new XGecu-T76 Chip Programmer (running XgPro v13.17). I like being able to leave the chips soldered-in (when possible) and read/write them with pogo-tool.
                                            As instructed, for more reliable operation with pogo-tool, I have backed the SPI-Clock Frequency down to 16-Mhz (and that seems to be working fine so far for reading/erasing/writing/verify).
                                            So, let's say I have a MB that soft-bricked itself after a common BIOS-Firmware...
                                            03-27-2026, 12:59 PM
                                          • CHERIF
                                            How to add new 64MB chip in RT809H Programmer
                                            by CHERIF
                                            Hi Dears Members i need to know how to add new 64MB chip in RT809H programmer address like GigaDevice 25LR512MEYIG
                                            i'm trying no luck because my software haven't 64MB algoritm if someone have a software that can add it i'm seriously in need of help
                                            here thank you in advence
                                            04-02-2026, 06:34 PM
