T2 Chip Programmer Tool
This topic is closed.
  • lamo
    • Nov 2017
    • 41
    • Ukraine
    #261
    Re: T2 Chip Programmer Tool
    Originally posted by mferna14
    Hi I was reading this Thread. Then I downloaded T2 Unlock Data Mina 1.4. My Model is MacBook Air A1932, but could not find A1932 T2 Unlock Data. I am getting error:21 - 0x15 (21) in DFU mode when I coonect to my other MacBook. Can I use the closet model or is there a separate Unlock Bin file for A1932 EMC 3184 2018??? Any help would be much appreciated., Thanks
    mina isn't working anyway.
    • mferna14
      • Jun 2018
      • 1128
      Thanks "Iamo" for the reply... so is there any other solution for this., can anyone shed a light on this issue of mine??? Thanks in advance
      • mich6el
        • Dec 2015
        • 18
        • Ukraine
        #263
        Originally posted by ugamazing
        Theoretically, but MUCH easier said than done. Go try to pull a T2 and come back here once you've done so lol.
        Replace t2 not a problem. Will the laptop be activated with the original serial number and ssd? after replays ONLY t2 chip?
        • mich6el
          • Dec 2015
          • 18
          • Ukraine
          #264
          Originally posted by lamo
          all above mentioned needs to be replaced: cpu, nand, wi-fi, spi(3 rom ic's).
          pardon, 3 spi? but motherboard have 1 spi chip (SOC rom)
          • mich6el
            • Dec 2015
            • 18
            • Ukraine
            #265
            Glory to Heroes!
            yes. it can. but be careful when replacing chips. the procedure is too complicated.
            yes. i know man)
            • lamo
              • Nov 2017
              • 41
              • Ukraine
              #266
              a2338 board has 3 roms. all of them needs to be replaced. just look into schematic file.
              • pumemule
                • Feb 2019
                • israel
                #267
                I have a remove activation lock(MDM)
                Can i remove it? Or only bypass and how?
                • lamo
                  • Nov 2017
                  • 41
                  • Ukraine
                  #268
                  mdm connected to serial number. I think you'll find a solution how to change serial number in t2 rom.
                  good luck
                  • LevanGood
                    • Jun 2022
                    • 10
                    • Ukraine
                    #269
                    Hi! Glory to Ukraine? Did you manage to replace the chipset? I also have 2 2338 boards and I don't know which set to change: WI-FI, NAND, M1, SPI
                    Hi) still can't find A2141 unlocked logic board to use in as a donor…
                    • mich6el
                      • Dec 2015
                      • 18
                      • Ukraine
                      #270
                      Hello! I have successfully completed the reballing of chips (T2, Nand, Wi-Fi) removed from the dead processor board. When I get the Activation Locked Board, I will be able to experiment
                      • LevanGood
                        • Jun 2022
                        • 10
                        • Ukraine
                        #271
                        I can give you my own one. I’ve got my A2141 locked. But actually I wanted to try to make it work by myself…)
                        Or you can sell me that ICs
                        P.S. I think that NANDs are not necessary to replace. But I still can be wrong.
                        • mich6el
                          • Dec 2015
                          • 18
                          • Ukraine
                          #272
                          but a2141 and a2179 have different flex of touch id. i want make fully worked board. but all my a2179 have dead cpu too. Sorry I have one chip set for experiment
                          • LevanGood
                            • Jun 2022
                            • 10
                            • Ukraine
                            #273
                            Ok maybe u have any logic board with unlocked T2 (FMM off)? Any? I mean MB Air 1932 or any? I think T2 replacement only can solve the problem and I just want to try it.
                            One guy sent me a video where one Chinese guy replaces T2 and make it work..
                            • mich6el
                              • Dec 2015
                              • 18
                              • Ukraine
                              #274
                              i have only one board witрout fmm
                              • kevingill
                                • Jun 2013
                                • 152
                                • England
                                #275
                                I've done quite a lot of searching to easily find out whether a MacBook is MDM locked, but failed.
                                What's the easiest way to find if it's MDM activated on a MacBook that's been reset, i.e. no operating system.
                                Is it the availability of the option in the Recovery Assistant -> Activate with MDM key?
                                • xploiter
                                  • May 2022
                                  • 5
                                  • uk
                                  #276
                                  here
                                  Originally posted by kevingill
                                  Use this command in terminal:
                                  profiles status -type enrollment
                                  Depending on your MDM enrollment status, you may see one of the following statuses shown below:
                                  No MDM enrollment
                                  computername:~ username$ profiles status -type enrollment
                                  Enrolled via DEP: No
                                  MDM enrollment: No
                                  MDM enrolled, without user-approved MDM enable
                                  MDM enrollment: Yes
                                  MDM enrolled, with user-approved MDM enablee
                                  MDM enrollment: Yes (User Approved)
                                  DEP Enrolled
                                  Enrolled via DEP: Yes
                                  • kevingill
                                    • Jun 2013
                                    • 152
                                    • England
                                    #277
                                    I have some MacBooks that don't boot as I can't get past activation.
                                    I can't bring up the terminal so the method you gave won't work.
                                    • .::iRizwan::.
                                      Banned
                                      • Apr 2016
                                      • 63
                                      • Pakistan
                                      • Too Much
                                      #278
                                      This is not for activation lock.
                                      • kevingill
                                        • Jun 2013
                                        • 152
                                        • England
                                        #279
                                        I'm fully aware of what the script is used for.
                                        My original question was how to tell if a MacBook is MDM locked when it's been wiped and has an activation lock.
                                        • xploiter
                                          • May 2022
                                          • 5
                                          • uk
                                          #280
                                          it is not mdm locked if it is wiped and with activation lock. mdm gets installed during os installation.
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • baletak
                                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                                            by baletak
                                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                                            I have updated laptop model number.
                                            1) I did not find the way to update laptop serial number - I have this one.
                                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                                            Many thanks
                                            Miro
                                            05-23-2025, 01:21 AM
                                          • Zinge
                                            Lenovo Legion Y540 (RTX 2060): MATS isolated bad VRAM on C0. Chip with a mini rotary tool?
                                            by Zinge
                                            Hi guys,
                                            Motherboard: Lenovo Legion Y540 with RTX 2060 Mobile (TU106).
                                            Issue: Error 43, dead HDMI port.
                                            Diagnosed with Nvidia MODS/MATS 520.175:
                                            • All errors are strictly in FBIOС0 (Write Error Count: 536370, bits C000–C007).
                                            • Other channels (A0, A1, B0, B1, C1) are all clear (zero errors).
                                            • Factory VRAM: Samsung K4Z80325BC-HC14 (GDDR6).
                                            Because Lenovo boards use heavy underfill and have thin, fragile multi-layer PCBs that bubble/delaminate easily under prolonged thermal stress, I have decided to mill the defective C0 chip out using a micro rotary...
                                            11-09-2026, 08:31 AM
                                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                                            by SMDFlea
                                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                            and once you do find them there`s a few crucial steps missing.
                                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                            After adding the chip save the xml file and copy it to the root directory of the...
                                            05-26-2024, 07:15 AM
                                          • Tesla
                                            Basic Questions about using XGecu-T76 with pogo-tool to fix motherboards
                                            by Tesla
                                            I was wondering if you more experienced technicians could help answer some basic questions I have ... and help me build a reliable work-flow for using my new XGecu-T76 Chip Programmer (running XgPro v13.17). I like being able to leave the chips soldered-in (when possible) and read/write them with pogo-tool.
                                            As instructed, for more reliable operation with pogo-tool, I have backed the SPI-Clock Frequency down to 16-Mhz (and that seems to be working fine so far for reading/erasing/writing/verify).
                                            So, let's say I have a MB that soft-bricked itself after a common BIOS-Firmware...
                                            03-27-2026, 12:59 PM
