T2 Chip Programmer Tool
This topic is closed.
  • LevanGood
    • Jun 2022
    • 10
    • Ukraine
    #241
    Re: T2 Chip Programmer Tool
    Originally posted by lamo
    i replaced about 20 t2's. it's very complicated procedure by itself. too many issues. but it's possible.
    Yeah I know it's complicated. I made many T2 reballs but it was just a reball.
    And now I want to unlock the locked logic board by replacing T2.
    So the main question is if it's enough just to replace locked T2 by the unlocked one (and it's SPI) or I have to replace some else ICs (wifi, nand, etc.)?
    • ugamazing
      • Jun 2013
      • 180
      • usa
      #242
      I don't think anyone "knows" the answer to your question; you should try it and let us know how it goes!
      I think you'd need to change T2/ROM and at least one nand, but not sure which. Not sure if WiFi "needs" to be replaced, but may need to be as well. Short answer, though, is: "nobody knows, or we'd be unlocking boards already".
      • lamo
        • Nov 2017
        • 41
        • Ukraine
        #243
        only t2 and t2rom. but again, i should warn you: this is too complicated procedure. i've read your question in PM`s, will contact with you soon.
        • ugamazing
          • Jun 2013
          • 180
          • usa
          #244
          What's complicated about it? Replacing the chips themselves not a problem. What else do you think is involved? If it means unlocking a T2 board, replacing the T2/ROM is not a big task at all lol. I'm sure there's more to getting it to work than simply swapping chips though. Someone would have found that out by now, of course.
          • LevanGood
            • Jun 2022
            • 10
            • Ukraine
            #245
            Swapping chips is still a working solution for iPhones. Of course, if we're talking about iPhones it may not worth it, but the solution itself works.
            That's why I thought if it works with a macbook.
            • ugamazing
              • Jun 2013
              • 180
              • usa
              #246
              Might try it today and see. Nothing to lose, market is trash right now, lots of time for research/learning.
              • ugamazing
                • Jun 2013
                • 180
                • usa
                #247
                Can confirm this removal process is complicated as hell. Just a heads up to anyone trying it. Very tedious and grueling as T2 chip is bi-layered and bottom portion really tough to get off without first pulling the top-half, but then it's difficult to re-attach top layer. Will have to play around with heat/etc, but it's definitely a challenge.
                • lamo
                  • Nov 2017
                  • 41
                  • Ukraine
                  #248
                  exactly. and if you detach it, while desoldering t2, it is nearly impossible to correctly solder it back to lower part.
                  • Terry011
                    • Feb 2014
                    • 7
                    • England
                    #249
                    Lots of talk about swapping components from unlocked boards, does anyone think a new jailbreak won't be released?
                    • ugamazing
                      • Jun 2013
                      • 180
                      • usa
                      #250
                      I personally do not think a true (and permanent--without exceptions) software-based bypass/unlock (as everyone thinks of it) will ever be released for the T2 models. That's my opinion.
                      • LevanGood
                        • Jun 2022
                        • 10
                        • Ukraine
                        #251
                        Of course, cuz activation lock is initially a hardware problem
                        • ugamazing
                          • Jun 2013
                          • 180
                          • usa
                          #252
                          Yup. Hardware-only unlock imo.
                          • lamo
                            • Nov 2017
                            • 41
                            • Ukraine
                            #253
                            as far as i know, it won't. apple fixed the security flaw with usb-c controllers.
                            • mich6el
                              • Dec 2015
                              • 18
                              • Ukraine
                              #254
                              Hey guys!
                              Sorry for my english. I know it's poor cuz I'm from Ukraine))
                              Look, I've got AppleID locked MB Pro A2141 and I wonder if I can unlock it.
                              As I know Apple blocked jailbreak ability on the last MacOS.
                              I've got another A2141 logic board with issues and it has FMM OFF.
                              So I wonder if it's possible to replace some IC's from the defective logic board with FMM off to my locked board? Has anybody done this before?
                              Should I replace T2 itself + SPI or should I replace WIFI+NANDs additionaly?
                              Thanks in advance!
                              Hi! Glory to Ukraine? Did you manage to replace the chipset? I also have 2 2338 boards and I don't know which set to change: WI-FI, NAND, M1, SPI
                              • mich6el
                                • Dec 2015
                                • 18
                                • Ukraine
                                #255
                                according to my investigations, there're no useful information, except machine serial number and board number in t2 rom. t2 rom only need to boot into dfu. also, all known methods of jailbreak won't work, because of usb-c firmware patch in t2 chip. t2 chip also have small rom-memory inside. the only way to remove icloud lock is to modify ECID of t2. this operation isn't possible for current moment.
                                Hi! Glory to Ukraine! If I have two boards 2179 with icloud and water damaget without icloud. replays t2 chip witout ssd and spi can fix activation lock?
                                • kevingill
                                  • Jun 2013
                                  • 152
                                  • England
                                  #256
                                  Has your spare board got an older, jailbreak capable bridgeOS?
                                  There's some information in this thread to work out if you have older or newer bridgeOS based on the screenshot of it booting into recovery.
                                  • ugamazing
                                    • Jun 2013
                                    • 180
                                    • usa
                                    #257
                                    Theoretically, but MUCH easier said than done. Go try to pull a T2 and come back here once you've done so lol.
                                    • lamo
                                      • Nov 2017
                                      • 41
                                      • Ukraine
                                      #258
                                      Glory to Heroes!
                                      yes. it can. but be careful when replacing chips. the procedure is too complicated.
                                      • lamo
                                        • Nov 2017
                                        • 41
                                        • Ukraine
                                        #259
                                        all above mentioned needs to be replaced: cpu, nand, wi-fi, spi(3 rom ic's).
                                        • mferna14
                                          • Jun 2018
                                          • 1128
                                          Hi I was reading this Thread. Then I downloaded T2 Unlock Data Mina 1.4. My Model is MacBook Air A1932, but could not find A1932 T2 Unlock Data. I am getting error:21 - 0x15 (21) in DFU mode when I coonect to my other MacBook. Can I use the closet model or is there a separate Unlock Bin file for A1932 EMC 3184 2018??? Any help would be much appreciated., Thanks
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • baletak
                                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                                            by baletak
                                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                                            I have updated laptop model number.
                                            1) I did not find the way to update laptop serial number - I have this one.
                                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                                            Many thanks
                                            Miro
                                            05-23-2025, 01:21 AM
                                          • Zinge
                                            Lenovo Legion Y540 (RTX 2060): MATS isolated bad VRAM on C0. Chip with a mini rotary tool?
                                            by Zinge
                                            Hi guys,
                                            Motherboard: Lenovo Legion Y540 with RTX 2060 Mobile (TU106).
                                            Issue: Error 43, dead HDMI port.
                                            Diagnosed with Nvidia MODS/MATS 520.175:
                                            • All errors are strictly in FBIOС0 (Write Error Count: 536370, bits C000–C007).
                                            • Other channels (A0, A1, B0, B1, C1) are all clear (zero errors).
                                            • Factory VRAM: Samsung K4Z80325BC-HC14 (GDDR6).
                                            Because Lenovo boards use heavy underfill and have thin, fragile multi-layer PCBs that bubble/delaminate easily under prolonged thermal stress, I have decided to mill the defective C0 chip out using a micro rotary...
                                            11-09-2026, 08:31 AM
                                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                                            by SMDFlea
                                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                            and once you do find them there`s a few crucial steps missing.
                                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                            After adding the chip save the xml file and copy it to the root directory of the...
                                            05-26-2024, 07:15 AM
                                          • Tesla
                                            Basic Questions about using XGecu-T76 with pogo-tool to fix motherboards
                                            by Tesla
                                            I was wondering if you more experienced technicians could help answer some basic questions I have ... and help me build a reliable work-flow for using my new XGecu-T76 Chip Programmer (running XgPro v13.17). I like being able to leave the chips soldered-in (when possible) and read/write them with pogo-tool.
                                            As instructed, for more reliable operation with pogo-tool, I have backed the SPI-Clock Frequency down to 16-Mhz (and that seems to be working fine so far for reading/erasing/writing/verify).
                                            So, let's say I have a MB that soft-bricked itself after a common BIOS-Firmware...
                                            03-27-2026, 12:59 PM
