alienware 15 r3 La-D751p bios fix
  • gfd2016
    • Mar 2022
    Re: alienware 15 r3 La-D751p bios fix
    I just flashed this "A15R3_Bios.rar" above but it is only the newest bios update 1.17 which does not fix my issues.
    • ajbernasko
      • Mar 2022
      • 229
      • ghana
      #42
      Looks like all firmware in this forum has administrative lock
      • ajbernasko
        • Mar 2022
        • 229
        • ghana
        #43
        Originally posted by smdflea
        try these.flash the ec as well if you have a programmer for it.
        i programmed this one so far
          • 22278
          Isn`t the password in the EC
          • ajbernasko
            • Mar 2022
            • 229
            • ghana
            #45
            I flashed both UE2 and UH4 all the time and each one of them has admin bios lock
              • 22278
              Is there a password suffix on the screen when you enter the wrong password
              • ajbernasko
                • Mar 2022
                • 229
                • ghana
                #47
                No please there us nothing like a code that I could use on bios-pw.org. thank you
                • aldopc
                  • Jul 2017
                  • 484
                  • Chilito
                  #48
                  Hello friends someone could repair my bin please I have no image ...
                  • hardware1
                    • Sep 2021
                    • 2949
                    • N/A
                    #49
                    Here's your New Bios, try it and let me know.
                    Service Tag: BTFTVF2.
                    all donations are welcome,
                    • aldopc
                      • Jul 2017
                      • 484
                      • Chilito
                      #50
                      Thanks Bro, but I still have no image, I have 2 red lights and 1 blue, on the power button
                      • aldopc
                        • Jul 2017
                        • 484
                        • Chilito
                        #51
                        Could someone make another try please.
                        • floodster1
                          • Mar 2018
                          • 26
                          • canada
                          #52
                          Need alienware 15 r3 bios bin
                          lost original bios for alienwear 15 r3
                          motherboard is la-D751P REV 1.0
                          i7 6700hq gtx 1070m
                          service tag is J2PZPF2
                          thanks for your time
                          • Jasonexe
                            • Apr 2023
                            • 70
                            Hi, not sure if someone will still reply to this topic but i also got a Alienware 15 R3 with a i7 7700HQ and a GTX 1070. The latest bios update does not let me undervolt, i managed to unlock the options with AMIBCP but i found out that there is no way of flashing it with FPT, AFU etc.. So my only option would be to use a CHA341 SPI Programmer. If i understood post #28 right, the 25B128CSIG bios IC is actually a W25Q128FVSIQ? I hope someone could confirm it before i decide to flash my modded bios to it.
                            Best Regards,
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12441
                              #54
                              Best Regards,
                              Yes that right.
                              • Jasonexe
                                • Apr 2023
                                • 70
                                Originally posted by hoaca388
                                Yes that right.
                                thank you!
                                • ms10
                                  • Jul 2023
                                  • 6
                                  • india
                                  #56
                                  Try this and let me know
                                  • Jasonexe
                                    • Apr 2023
                                    • 70
                                    I just tried to read my IC with W25Q128FV selected manually but no luck. In AsProgrammer V2.1.0.13 it just reads F, and in NeoProgrammer v2.2.0.10 it says IC not responding / Disconnected. I already had the 3.3v mod on my cha341, the bios chip was actually still soldered on the motherboard while trying to read it but i don't think that should be a issue.​
                                    • Jasonexe
                                      • Apr 2023
                                      • 70
                                      Edit: after desoldering the BIOS IC i managed to read and write on it. However, if you try to unlock options with AMIBCP and reflash the bios, the laptop will tell you that the rom is invalid and could not be updated. I also tried unlocking CFG Lock and Overclock Lock only to be able to undervolt but no luck.. And that’s probably because most of these models have intel boot guard i believe, tell me if i’m wrong. I ended up flashing the original bios back and leave it as it is. I did manage to unlock the GPU vbios with Pascal TDP Tweaker, after i flashed the modified bios with the CH341A programmer.
                                      • pepebmx
                                        • Aug 2020
                                        • 11
                                        • Argentina
                                        #59
                                        Hi I have my old Alienware 15 r3 turns on sometimes with no display, 2 red ligths 7 beeps. These means problems with display, already changed flex cable. Original was ok tough. Back in 2020 i already flashed this bios posted and fixed the problem. Now again i am facing the same issue. Need to turn on and off too many times until it has picture. Leave 2 bios inside, one is the last one i had. And the other one used to be the original dump.
                                        Would be great if somene could help me
                                        Laptop: Alienware 15 r3
                                        Serial No: 7QS73G2 service code 16856957234
                                        PCB: La-D752p
                                        • teccyber-lab
                                          • Apr 2025
                                          • 27
                                          • BRAZIL
                                          #60
                                          The screen doesn't turn on, it only beeps three times, then two times, and finally one beep, in a loop.. The RAM memory has already been discarded.
                                          I found three BIOS chips on this UE2/UH4/UT2 board, I don't know why it has 3, if you can help me rebuild the BIOS, I would appreciate it.
                                          AleinWare15 R3
                                          Model: P69F
                                          MoBo: BPA10 LA-D751P Rev 1.0 (A00)
                                          ST:5PBZ3H2
                                            SMDFlea commented
                                            Editing a comment
                                            Thread merged.
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • drux
                                          Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                                          by drux
                                          I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                                          Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                                          These models have AMI/Aptio BIOS.
                                          Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                                          11-03-2024, 01:18 AM
                                        • hotcrossedbuns999
                                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                          by hotcrossedbuns999
                                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                          3. I could only locate two chips that look like bios chips. Could someone verify this
                                          01-03-2025, 12:32 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • zlr8r
                                          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                          by zlr8r
                                          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                          cheers
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                          Attached;
                                          1. My saved bios using a programmer
                                          2. Dells Bios updater .exe (v1.16)
                                          3. Dells Bios recovery file
                                          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                          5. Image of ME...
                                          12-18-2023, 03:08 PM
