M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
  • hotcrossedbuns999
    • Jan 2024
    • 17
    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
    3. I could only locate two chips that look like bios chips. Could someone verify this is the correct chip and location?
      1. WINBOND 25Q64FWSIQ 1715 was under the cpu fan, and is the only one that could be read by ch431a programmer. (File is attached.)
      2. WINBOND 25Q80DVSIG 1719 is right next to the CMOS battery, and cannot be read by the ch431a programmer. (Tried NeoProgrammer 2.2.0.10, ASProgrammer 2.0.4, and ASProgrammer 2.1.0. Tried many many times.
    4. I only found one post about this model and it scared me off by talking about serial numbers and Windows keys being tied too the bios. So, I don't think I should try someone else's bios.
    5. Info
      1. Machine: Lenovo Thinkcentre M715q M903
      2. S/N: MJ06B60D
      3. Board model number: AM4IH ver: 1.0
      4. CPU: AMD A12-9800E
    6. Here is the LINK to Lenovo Bios page for my PC using S/N:
      1. https://pcsupport.lenovo.com/us/en/p...ry=BIOS%2FUEFI
        1. The file that I get from the USB Download (m11jt56usa.zip attached below) is a ROM file (IMAGEM11.ROM). Programmers need BIN files. Am I mistaken that I could just rename the ROM to BIN and flash it? The programmers can read and write the BIN.
    BONUS Info: I had two sticks of ram installed (8gb x 2) and the bios and Windows only read 8gb. BUT, windows read 2 sticks in single channel. Verified with HWINFO. I was hoping the bios update would fix the issue.
  • hotcrossedbuns999
    • Jan 2024
    • 17
    Did I do something wrong?
    Or is this a lost cause?
    TIA
    • STKR123
      The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
      by STKR123
      Greetings badcaps community,
      I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
      So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
      Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
      I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
      These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
      I learned that desoldering...
      10-29-2024, 06:03 AM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • h955
      Need Clean BIOS Dump / ME Region Fix for Lenovo ThinkCentre M70t Gen 5 (Board: IB760ME v1.0)
      by h955
      I need help getting a clean/original BIOS dump or fixing the Intel ME region for my desktop. Here are the system details:
      - Model: Lenovo ThinkCentre M70t Gen 5
      - Motherboard Revision: IB760ME v1.0
      - Serial Number (S/N): GMORJRJ1
      Current Situation / Issue:
      1. The original BIOS was corrupted.
      2. I flashed a BIOS dump from an M70s Gen 5 model.
      3. The system now powers on and boots, but the hard drives / storage drives (SATA/NVMe) are not working/detected.
      4. I am also experiencing issues with the Intel Management...
      07-22-2026, 08:33 AM
    • TopPop
      Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
      by TopPop
      Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
      I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
      12-14-2025, 09:40 PM
    • amgat
      BIOS for ThinkCentre M910 Tiny
      by amgat
      I need a BIOS dump for ThinkCentre M910 Tiny.
      The BIOS chip is : Winbond 25Q128JV
      Board : IQ2X0IH ver 1.0
      I was using a chip clip with my xgecu pro which led to a corrupt BIOS dump, and the BIOS chip was since re-flashed with the donor BIOS from this thread:
      https://www.badcaps.net/forum/troubl...nkcentre-m910q
      This donor BIOS is not working in my system (because...
      11-22-2024, 02:06 PM
