alienware 15 r3 La-D751p bios fix
  • teccyber-lab
    • Apr 2025
    • 27
    • BRAZIL
    #61
    Originally posted by teccyber-lab
    The screen doesn't turn on, it only beeps three times, then two times, and finally one beep, in a loop.. The RAM memory has already been discarded.
    I found three BIOS chips on this UE2/UH4/UT2 board, I don't know why it has 3, if you can help me rebuild the BIOS, I would appreciate it.
    AleinWare15 R3
    Model: P69F
    MoBo: BPA10 LA-D751P Rev 1.0 (A00)
    ST:5PBZ3H2
    I just tried all of this topic, and none of them worked for me.
    • STKR123
      The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
      by STKR123
      Greetings badcaps community,
      I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
      So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
      Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
      I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
      These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
      I learned that desoldering...
      10-29-2024, 06:03 AM
    • drux
      Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
      by drux
      I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
      Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
      These models have AMI/Aptio BIOS.
      Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
      11-03-2024, 01:18 AM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • zlr8r
      looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
      by zlr8r
      looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
      cheers
      Dell Inspiron 17 (7786) Laptop
      Service Tag: 5J0NHT2
      Bios: 1.9.0
      MOBO: RO 15 17 WHL 2GB MB / 18706-2
      Attached;
      1. My saved bios using a programmer
      2. Dells Bios updater .exe (v1.16)
      3. Dells Bios recovery file
      4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
      5. Image of ME...
      12-18-2023, 03:08 PM
