HP 840 G7 password
  • ilovehaggis
    • Feb 2025
    Could you please help remove the BIOS password.
    HP 840 G7
    SN# 5CG12111DS
    ProdID 8PZ98AV
    Build ID: 20WWCMDT601#SABU#DABU
    Feature byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEnV.eT
    Motherboard ID: CAMELLIA-6050A3136201-MB-A01(A1)
    I have tried writing FF to some sections of the 128 chip as per some YouTube videos, but it didn't work. Thanks for your help! I have attached the original bin dump of both chips.
    • shiyab
      • Sep 2023
      • 1683
      • india
      #442
      HP 840 G7
      SN# 5CG12111DS
      ProdID 8PZ98AV
      hi flash 16 mb ec
      • vbot
        • Feb 2025
        • Slovenia
        #443
        HI, I have HP Sure Start password lock!
        HP 840 G7
        SN# 5CG0466QX4
        ProdID: 10U64EA#BED
        BuildID: 20WWCMBT601#SBED#DBED
        Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPguhKhkjhk8mE.nA
        MAC2: X3024A9A48C6C
        Could it be reseted to the default settings?
        Regards!
        V.
        • ilovehaggis
          • Feb 2025
          Originally posted by shiyab
          hi flash 16 mb ec
          Thanks very much! It did work!
          • bert-bert
            • Oct 2024
            • 25
            • Austria
            #445
            I have a defective 840 G7 and I suspect the BIOS being the issue. UEFITool shows yellow and red lines. I guess this means there is an error.
            I attach the BIOS image. I do not know whether there is a BIOS password, but I would like not having to flash the 16MB chip if it is not necessary.
            Would someone mind fixing the attached BIOS file or even better explaining me how to fix it myself?
            I thank everyone in advance!
            SN# 5CG040300Z
            ProdID 8PZ98AV
            Mainboard: CT:PJSCQ00WBE95J7
            • hoaca388
              Badcaps
              • Jan 2022
              • 12426
              #446
              SN# 5CG040300Z
              ProdID 8PZ98AV
              HP EliteBook 840 G7 Notebook PC
              CT Number_6JKMK06WYDX7KS
              Serial_5CG040300Z
              Product_8PZ98AV
              Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mE.ye
              Build Id_20WWCMAT601#SABD#DABD
              • bert-bert
                • Oct 2024
                • 25
                • Austria
                #447
                Serial_5CG040300Z
                Product_8PZ98AV
                Hello hoaca388,
                thank you a lot for creating an image, but somehow it does not work. Now I guess it's not the BIOS that is the issue. After flashing the BIOS, the charging LED stayed lit some longer than before and now, and there was some blinking and changing to orange on the charging LED, but after about a minute it went out, and about two minutes later I cut the power, and now it looks like before. I do not have a eDP display connected, but a display via USB-C and this did not lit up at all. I guess it was not the BIOS that was faulty. But it was a try. Or do you think, there is more we can try?
                Nevertheless thank you!
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12426
                  #448
                  Hello hoaca388,
                  Check hardware problem.
                  • pronto
                    • Mar 2019
                    • 129
                    • morocco
                    #449
                    hi i need bin bios, hp elitebook 840 g7 no working, here old bin main and ec
                    SN_5CG1390XLM
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12426
                      #450
                      SN_5CG1390XLM
                      HP EliteBook 840 G7 Notebook PC IDS Base Model
                      • vbot
                        • Feb 2025
                        • Slovenia
                        #451
                        HP 840 G7 BIOS files Please S70 or S73
                        SN# 5CG0466QX4
                        ProdID: 10U64EA#BED
                        MAC2: X3024A9A48C6C
                        Reagrds!
                        V.
                        • techrecycle
                          • Jan 2024
                          • 64
                          • england
                          #452
                          hi can someone help me to remove bios password
                          sr: 5CG0437YQW
                          thanks in advance
                          • shiyab
                            • Sep 2023
                            • 1683
                            • india
                            #453
                            sr: 5CG0437YQW
                            thanks in advance
                            post ec file
                            • techrecycle
                              • Jan 2024
                              • 64
                              • england
                              #454
                              where is EC file located
                                • 22209
                                How many chips do you see with 8 pins ,read the part number on top of each, do a google search to find what each one is.
                                • techrecycle
                                  • Jan 2024
                                  • 64
                                  • england
                                  #456
                                  THANKS I WILL DO
                                  • josebml
                                    • Nov 2015
                                    • 40
                                    • spain
                                    #457
                                    Hello, I have an HP 840 G7 that does not display an image, I think the BIOS is damaged, I am attaching files of 16 and 32 mb.
                                    S/N: 5CG1132WLM
                                    Motherboard: 6050A3136201
                                    • kamkooltech
                                      kamkooltech
                                      • Jun 2019
                                      • 132
                                      • nigeria
                                      #458
                                      help me remove password
                                      840 g7
                                      s/n 5CG1118JBK
                                      THANKS​
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12426
                                        #459
                                        840 g7
                                        s/n 5CG1118JBK
                                        THANKS
                                        CT Number_6JKML05TZDWGGJ
                                        Serial_5CG04530VF
                                        Sku_1C8N7UT#ABA
                                        Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUbhcAdUdpdqfAfPguhKhkjhk8mE.T7
                                        Build Id_20WWCMBT601#SABA#DABA
                                        • kamkooltech
                                          kamkooltech
                                          • Jun 2019
                                          • 132
                                          • nigeria
                                          #460
                                          Serial_5CG04530VF
                                          Sku_1C8N7UT#ABA
                                          thank you bro
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • m1ch43lzm
                                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                            by m1ch43lzm
                                            Hi everyone
                                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                            There's also an extra OTP Secu.R...
                                            09-06-2025, 05:47 PM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • chunhualo
                                            Please Help unlock bios password for Alienware 13 r1 bios password 7digit service tag
                                            by chunhualo
                                            HI I have forgotten my old laptop Alienware 13 r1 bios password .
                                            Can anyone find the master password for my laptop
                                            The service tag number is : 2JJVH12
                                            03-16-2025, 04:13 AM
                                          • Zain Ahmas
                                            unlock bios password ADVAN soulmate apn21s.
                                            by Zain Ahmas
                                            help me to unlock bios password ADVAN Soulmate board code: apn21s
                                            11-10-2025, 01:14 AM
