Dell G3 15 3500 bios help
Re: Dell G3 15 3500 bios help
Try it now, and give feedback.Comment
Try the first one, if it doesn't work try the second one.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Try This one. if it doesn't work, you maybe have a hardware issue.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
If the programmer can only read the 16MB chip as 8MB don`t you think that it will only write 8MB as well,and in the process corrupt the bios.If the chip isn`t in the support list manually choose another 25Q chip that has same voltage and untick check-ID in the programmer settings,if there is such an option.Comment
Hello everyone, the dell G3 15 3500 laptop is under repair, the Soltek G3 MTK N18P - 19795-1 motherboard, the service tag is not saved in the bios settings, the native bios was lost, but with this the laptop starts but high speed and keyboard sound... there are dumps in the archive that were before the repair, I'm not sure that they are nativeAttached FilesComment
Any donations to Badcaps are welcome. Become a Badcaps supporter >>>>> click this link to donate <<<<< Thank you to all the supporters. -- -------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hi hoaca388.
Impossible to validate Service TAG, I can go in BIOS enter service tag, but when I save it clears.
Can you fix it ?
STag : 8rjbd63
Tahnks in advanceAttached FilesComment
Re: Need Dell G3 15 3500 bios dump
[Comment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
- Loading...
