Dell G3 15 3500 bios help
 Dell G3 15 3500
 Dell G3 15 3500
 motherboard code - selek g3 mlk n18p 19795-1 403yf$LA
 Service Tag: 2KDW763
 Express Service Code: 5586225483
 old bios just keyboard-led only blinking
 need repair my bios or need working bios guys
 pls help meAttached FilesComment
 Re: Dell G3 15 3500
 flash this and reportAttached FilesComment
 Re: Dell G3 15 3500
 Dell G3 15 3500Attached Files↵
 https://www.badcaps.net/donateComment
 Re: Dell G3 15 3500 bios help
 please need heelp i lost my bin bios file for dell 3g 15 3500
 and i try other bin and it is not working
 dell 3g 15 3500
 PCB SELEK 3G MLK N18P 19795-1
 BIOS IC
 XM25Q64A
 XM25Q128A
 SITUATION NOW / just fix amber light when i prees onComment
 Please help i've got a G3 15 3590 service tag D33PJT2, turn on fan spin. led blink 3 orange
 5 white continuously. Already follow guide clean me but no change. please help. i've uploaded my old bin. thanksAttached FilesComment
 Dell G3 15 3590Attached Files↵
 this bios flash it reply meAttached FilesComment
 hello everyone, need help pls build bios bin with new bios region for 19795-1.
 service tag G1PR203.
 service tag is not saving in bios config.Attached FilesComment
 DELL G3 15 3500 clean Me region please
 DELL G3 15 3500
 Reg Model: P89F (P89F003)
 Motherboard: Selek g3 mlk n18p 19795-1
 Service Tag: H4RK463
 Express Service:37293452571
 Problem: motherboard with no display!!
 try:
 As I dont have the original bios backup for this motherboard , I reprogrammed it with a dump from Internet. Surprisely It worked, BUT the cooling fans are running at full speed and the service tag is not saving in BIOS SETUP at all ( I can't get out of manufacturing mode active alt+f)
 Please, anyone could clean ME region for this Bios? or help me solve this problem?
 ThanksLast edited by latinphoenix7; 08-19-2022, 05:08 PM.Comment
 Re: DELL G3 15 3500 clean Me region please
 TryDELL G3 15 3500
 try:
 ThanksAttached Files↵
 Build On Factory ModeDELL G3 15 3500
 try:
 TryComment
 XMC QH128AHIHG = 16MB
 XMC QH64AHIG = 8MB
 You have 24MB bios file. Post both SPI CHIPS.↵
							Channel: BIOS Requests ONLY!
			by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...-
 04-23-2025, 04:30 PM
			by capoplaysHey everyone,
 I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
 The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
 When I check the BIOS using the F12 menu Flash...-
			by Akhlz001Hi,
 Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
			by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
 The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
 However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
