Dell G3 15 3500 bios help
https://www.badcaps.net/donate -
hi, can you help me with a clear ME for this G3 3500 st:58YSM93?
i merged the two files in order to clear it, but it has a ME file that is not present in my repository folder (14.1.70.2228).
so, i attach my files, i must clear my ME as i changed the PCH.
thanks in advance!Attached FilesComment
try and feedbackhi, can you help me with a clear ME for this G3 3500 st:58YSM93?
unfortunately it doesn't work. it lights the keyboard for 2 seconds and loops. waited enough to see it just does this. just in case i put the original files and all works. so, can you help me with it? with the original ones i have to wait 30s for the image to appear because i changed the PCH. thans!Comment
There is no image, I don't know the service code.Attached FilesComment
Hello, no display, black screen. Service Tag: 8J3YN93Attached FilesComment
Dell G3 15 3500
Service Tag: 8J3YN93Attached Files↵
https://www.badcaps.net/donateComment
Flash this 8MB bios .Comment
Hi, could you fix this BIOS? It displays video but gives a TPM error.Attached FilesComment
Hi, could you fix this BIOS? It's giving a TPM not detected error.
dell g3-3500
tag: 1LKBD63Attached FilesComment
Dell G3 3500
ST: B69ZH3
Motherboard: SELEK MLK N18E FJT96$LA
Sup friends, my notebook turns on and gives video only when reach windows, i cant acess bios even on external video. And fan is always on full mode. IDK if the bios is original but i will post here the backup. Can someone help me please?Attached FilesComment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
