Need bios Dell XPS 9500 LA-j191p
  • hoaca388
    Badcaps
    • Jan 2022
    • 12325
    #41
    Re: Need bios Dell XPS 9500 LA-j191p
    Originally posted by nickstyle
    Looks like is not working,the bin file is corupted
    What can i do now?
    The laptop is working with the bios from post 26 but staps charging at 54%
    Post 26
    • nickstyle
      • Aug 2022
      • 42
      • United Kingdom
      #42
      Is working great
      Thank you so much
      Best regards
      • trunguntilyou
        • Aug 2022
        • 360
        • Vietnam
        #43
        need help ! I have a laptop whose fan won't turn on (sometimes it shows a fan error).. I was going to try another bios but accidentally killed the ROM (containing the bios) and couldn't read the original bios. I've tried almost everything. The files on here, some files don't load up and most of them only work the first time and turn them off and on again but only the logo hangs on them
        dell xps 15 9510 la-j191
        st : 64NSTQ3
        Need standard bios for this machine code
        • hoaca388
          Badcaps
          • Jan 2022
          • 12325
          #44
          Originally posted by trunguntilyou
          need help ! I have a laptop whose fan won't turn on (sometimes it shows a fan error).. I was going to try another bios but accidentally killed the rom (containing the bios) and couldn't read the original bios. I've tried almost everything. The files on here, some files don't load up and most of them only work the first time and turn them off and on again but only the logo hangs on them
          st : 64nstq3
          need standard bios for this machine code
          #41
          • trunguntilyou
            • Aug 2022
            • 360
            • Vietnam
            #45
            Originally posted by hoaca388
            #41
            I tried it and it stuck on the logo and then turned it off and it repeated continuously. Also, I tried turning it off with the power button but it restarted itself (there is a file that can be turned off with the power button).
            • trunguntilyou
              • Aug 2022
              • 360
              • Vietnam
              #46
              #41
              really sorry! when I soldered the bios and accidentally the 1v ic on the back of the bios died,, I replaced it and the device is back on normally,, the bios is all working,, thank you comrade
              • TheQuentincc
                • Mar 2017
                • 64
                • France
                #47
                Sevice tag ?
                Hi, sorry for the delay, the service tag is J8TKK63.
                Edit : for further information the dumped bios sometime makes the laptop display the Dell logo but it doesn't go further
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12325
                  #48
                  XPS 15 9500
                  Service Tag: J8TKK63
                  • TheQuentincc
                    • Mar 2017
                    • 64
                    • France
                    #49
                    XPS 15 9500
                    Thanks you, sadly it didn't worked, I'm ending up in the same stage with bootloop... either keyboard lit up then reboot or Dell logo then reboot, again and again :/
                    I also tried your bios on post #41 but I'm having the same issue
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12325
                      #50
                      Moving on to finding hardware problems, you don't have a bios error
                      • trunguntilyou
                        • Aug 2022
                        • 360
                        • Vietnam
                        #51
                        help me fix this bios,, every time I install all the drivers, the speaker has a red cross,, I tried another bios and it works fine, but the ST is wrong and other problems
                        ST: 4499K63
                        • Markus1741
                          • Sep 2020
                          • 946
                          • N/A
                          #52
                          ST: 4499K63
                          Try and let me know ....
                          • trunguntilyou
                            • Aug 2022
                            • 360
                            • Vietnam
                            #53
                            Thanks a lot! The device is working fine, if there are other problems I will respond later
                            • aurelmdx
                              • Jul 2016
                              • 41
                              • Italy
                              #54
                              Re: Bios Password Dell XPS 9500
                              Here's your Unlocked BIOS, hope it works fine.
                              Thanks a lot
                              • jacobk1508
                                • May 2016
                                • 69
                                • Viet Nam
                                #55
                                Originally posted by black0hackers
                                Ai đó có thể giúp tôi sửa bios này được không. Cảm ơn!!!
                                bật nguồn rồi treo Logo Dell
                                Hello. I'm also facing the same problem as you. It happens on Dell Precision 5550 LA-J191P 1.0
                                This is my original bios. Please give me the solution if you have solved your problem
                                ST: 9NBTZ53
                              • qayyum786
                                • Aug 2018
                                • 1959
                                • INDIA
                                #56
                                ST: 9NBTZ53
                                Smooth Decompose
                                no any error
                                • ciki
                                  • Aug 2014
                                  • 132
                                  • Ireland
                                  #57
                                  Hi can someone fix my bios Dell XPS 15 9500
                                  motherboard La-191p
                                • vuquanghoanh
                                  • Feb 2023
                                  • 45
                                  • US
                                  #58
                                  Could you help me to unlock the admin password, please?
                                  Model : Dell XPS 9500
                                  S/T: 4BK1M63
                                  Thank you.​
                                  • minhdigital
                                    • Nov 2022
                                    • 764
                                    • Vietnam
                                    #59
                                    S/T: 4BK1M63
                                    Thank you.​
                                    Send to you
                                    • vuquanghoanh
                                      • Feb 2023
                                      • 45
                                      • US
                                      #60
                                      Originally posted by minhdigital
                                      Send to you
                                      Thank you so much.
                                      Cám ơn anh nhiều.
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • mikeybass
                                        by mikeybass
                                        04-23-2025, 04:30 PM
                                      • capoplays
                                        Help with BIOS update on Dell G15 5515 after chip replacement
                                        by capoplays
                                        Hey everyone,
                                        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                        When I check the BIOS using the F12 menu Flash...
                                        10-24-2025, 06:53 AM
                                      • Akhlz001
                                        by Akhlz001
                                        09-20-2025, 07:15 PM
                                      • jhanra
                                        by jhanra
                                        in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                        11-02-2024, 04:19 AM
