Need bios Dell XPS 9500 LA-j191p
laptop no working please help, only kb light no fan na picture
ST:61K8P73Attached Filesif you find these attachements useful please consider making a small donation to the site
hello my laptop working fine but wifi card error code 10, i changed wifi card but error is still, please fix my dump. thank you
Dell XPS 9500
MB Code LA-J191P
ST: D6SBW33
Try
https://www.badcaps.net/donateComment
Hello everyone. My device is stuck on the logo or has a blue, red, or yellow screen. Can someone help me fix it? Thank you.
svt:40287d3Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello Guys,
Can someone please help me get this bios working,
I uploaded two files, one that should be my actual bios ( bricked ) and the exe file that I found for my laptop, I can not get directly the bios file from it.
But I dont understand the size the bios should be, the chip is 25Q80EW1G, but when i tried others I could get other size of bios, i'll upload each one, can you tell me the correct one(by size) ?
I appreciate the help already.
ST : 3J17GB3
Modele : DELL XPS 15 9500
25Q80EW1G contains NVIDIA firmware, not bios chip.Hello Guys,
ST : 3J17GB3
Modele : DELL XPS 15 9500↵
Hello and thanks you,Hello Guys,
ST : 3J17GB3
My bad I read the wrong one
Here is the good one .
Can you help me with it please?
RegardsAttached Filesif you find these attachements useful please consider making a small donation to the site
XPS 15 9500
Service Tag: 3J17GB3Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi. Please fix my bios. Laptop no turn on in my oryginal bios.
On the bios from post #15 the laptop turns on, but does not see the SSD and has a long startup.
Dell Precision 5550
ST: FVNTCB3
Precision 5550
Service Tag: FVNTCB3Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello i really need help my bios is stuck on dell logo
xps 15 9500 ST G31F6D3
thanks in advance
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
