Need bios Dell XPS 9500 LA-j191p
https://www.badcaps.net/donate -
Re: Need bios Dell XPS 9500 LA-j191p
need help ! I have a laptop whose fan won't turn on (sometimes it shows a fan error).. I was going to try another bios but accidentally killed the ROM (containing the bios) and couldn't read the original bios. I've tried almost everything. The files on here, some files don't load up and most of them only work the first time and turn them off and on again but only the logo hangs on them
dell xps 15 9510 la-j191
st : 64NSTQ3
Need standard bios for this machine codeLast edited by trunguntilyou; 10-24-2023, 04:31 AM.Comment
#41need help ! I have a laptop whose fan won't turn on (sometimes it shows a fan error).. I was going to try another bios but accidentally killed the rom (containing the bios) and couldn't read the original bios. I've tried almost everything. The files on here, some files don't load up and most of them only work the first time and turn them off and on again but only the logo hangs on them
st : 64nstq3
need standard bios for this machine code↵
https://www.badcaps.net/donateComment
XPS 15 9500
Service Tag: J8TKK63Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks you, sadly it didn't worked, I'm ending up in the same stage with bootloop... either keyboard lit up then reboot or Dell logo then reboot, again and again :/
I also tried your bios on post #41 but I'm having the same issueComment
Moving on to finding hardware problems, you don't have a bios error↵
help me fix this bios,, every time I install all the drivers, the speaker has a red cross,, I tried another bios and it works fine, but the ST is wrong and other problems
ST: 4499K63Attached Filesif you find these attachements useful please consider making a small donation to the site
Try and let me know ....Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello. I'm also facing the same problem as you. It happens on Dell Precision 5550 LA-J191P 1.0
This is my original bios. Please give me the solution if you have solved your problem
ST: 9NBTZ53Attached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Smooth Decompose
no any errorAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi can someone fix my bios Dell XPS 15 9500
motherboard La-191pAttached Filesif you find these attachements useful please consider making a small donation to the site
Could you help me to unlock the admin password, please?
Model : Dell XPS 9500
S/T: 4BK1M63
Thank you.Attached Filesif you find these attachements useful please consider making a small donation to the site
Send to youAttached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
