lenovo Flex 5 bios need
  • jackkyxu
    replied
    hi
    please help me with a bios
    Flex 5-14ARE05 Laptop (ideapad) - Type 81X2
    R912X34C MTM 81X20002US
    board id: LC55-14A 19793 1M
    thanks
  • shansnow
    replied
    Originally posted by shansnow
    Hello everyone. Kindly help me fix with my corrupted.bin file please.
    issue : NO POST. uploaded 3 bin for confirmation.
    R90YSZF1 MTM 81X2003HPH
    Thank you
    Hello Sir, Thank you for the effort. I can see the Bios settings now and Novo button is working. Unfortunately it stucks in Lenovo logo when I set to Legacy boot..if EUFI boot only black screen with backlight. Can't detect also any bootable media. I've tried too install an Windows 10 OS. with another driver but the issue still thesame. Please help me with this sir.. Thank you.That is my BIOS IC. Im using Neoprogrammer ch341a programmer with 1.8V converter.it's and AMD Rizen 5. thank you sir.
  • hoaca388
    replied
    Thank you
  • shansnow
    replied
    R90YSZF1 MTM 81X2003HPH​
    Thank you
  • Shako
    replied
    Originally posted by SMDFlea
    Here. Bios + DMI.
    It works. With SN and everything. Thank you very much.
    replied
    Originally posted by Shako
    Hi peste, thanks for your quick response. I have tried the link you sent but now the laptop is not turning on at all. Then I have seen that that ist for 14alc05 81yq and I have 15are05 81X2. Then I downloaded from this Poss #3 BIOS it works but my SN and MTM are showing INVALID in BIOS. How can I have my original SN and MTM number in BIOS. Please help. Thank you.
    Here. Bios + DMI.
  • Shako
    replied
  • peste
    replied
    Hello guys. Can you please help me with my BIOS. Laptop turns on and has a black screen.
    Lenovo IdeaPad Flex 5 14ARE05 Type:81X2
    SN: R9128CCK
    MTM:81X20099GE
    MO:R9N0B132700F
    I would really love to keep my Serial Number.
    Thanks in advance.
    try post #4..
    https://www.badcaps.net/forum/troubl...os#post1758667
  • Shako
    replied
    SN: R9128CCK
    MTM:81X20099GE
    MO:R9N0B132700F
    Thanks in advance.
  • hoaca388
    replied
    Originally posted by Lukosiukas
    Hello, i need bios rebuild or dmi and widnows key trasfered. Turns on, black screen, no post. Tried dump with no dmi (from #3 post) computer turns on, works perfectly.
    IDEAPAD FLEX 5 14ARE05
    SN R9121R2B
    MTM 81X2009JLT
    BOARD LC55-14A 19793-3
  • peste
    replied
    SN R9121R2B
    MTM 81X2009JLT
    now you have everything you need at post #3...transfer DMI AND KEYWIN yourself...
    the bios from post # is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
    select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
  • Lukosiukas
    replied
    SN R9121R2B
    MTM 81X2009JLT
  • redoxy
    replied
    Originally posted by qayyum786
    flash old bios and check dose it turn on
    I received the new BIOS chip and flashed the old BIOS. It still does not turn on.
  • redoxy
    replied
    I ordered new BIOS chips. I'll try and report back once I receive it.
    Thanks.
  • qayyum786
    replied
    Originally posted by redoxy
    Thanks, qayyum786. I made a rookie mistake in my haste to flash the BIOS. I forgot the battery was still when I was placing heat tapes on resistors and capacitors around the BIOS chip to prepare for desoldering the BIOS chip. I ended up shorting the BIOS chip (it burned). I replaced it with the same part number from a donor board and flashed your bin file but now there's no power. The laptop doesn't turn on anymore. I tried with battery only, power adapter only, and battery with power adapter with the same results, no power. I guess I might have damaged other components besides the BIOS chip
    This is the end of this repair for me.
    Thanks, everyone for all the help.
    Cheers!
  • redoxy
    replied
    try
    Cheers!
  • qayyum786
    replied
    try
  • redoxy
    replied
    Thanks, Hoaca388 and Shiyab for the files.
    I tried Hoaca388's file and it worked. I have display.
    However, I lost DMI info (S/N, Model #, UUID and Windows Key) as shown in the picture.
    I tried using the Lenovo Uone tool to write the DMI info but I get an error "Locate protocol with LenovoEeprom, status [e]"
    "Eeprom fail when reading or writing data."
    Is there a way to fix the DMI tool error? I'd like to try that first if possible since I'd prefer not to desolder the BIOS chip again.
    shiyab does your file retain the DMI information so I should go ahead and try that if I'm unable to write the DMI info with the tool?
    Thanks, again for the help.
    Cheers!
  • shiyab
    replied
    Hi everyone!!
    Could you please help me fix my BIOS?
    Lenovo IdeaPad Flex 5-14ITL05
    S/N: R912KL5Q
    Motherboard: LC65-14T 203013 448.0K121,0011
    Issue: Laptop powers on but no display. It appears the LCD backlight turns on but no image.
    Thanks, in advance.
    hi try
  • hoaca388
    replied
    Hi everyone!!
    S/N: R912KL5Q
    Thanks, in advance.
    Flex 5-14ITL05 Laptop (ideapad) - Type 82HS
  • claws77
    lenovo flex 5 14ITL05 bios and motherboard fault
    by claws77
    my laptop is lenovo flex 5 14ITL05
    recently my power supply for this laptop developed a fault.
    which caused a short in my usb c port -- verified with a new charger.
    rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
    I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32...
    07-05-2024, 04:33 PM
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • Wahaz
    by Wahaz
    10-30-2023, 08:42 PM
  • grimacelord
    Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
    by grimacelord
    Hello there.
    I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
    History:
    1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
    I searched for this error online and discovered...
    03-15-2023, 03:29 PM
  • to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
    by to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
    I have opened the laptop and identified the main BIOS chip...
    10-24-2025, 01:35 AM
