i need Dell XPS 7390 2 in 1 Gen 10 bios.bin file
  • Maxamax
    Student
    • 6
    • Switzerland
    #101
    I have indeed de-soldered the chip to program it.
    I already thought of this as the cause of the problem (when I tried to repair the BIOS myself before posting), but I don't think this causes the issue.
    I tried powering up the PC without the chip at all and nothing happens.
    I'll verify with my multi-meter anyway, thank you
    • Maxamax
      Student
      • 6
      • Switzerland
      #102
      Originally posted by Markus1741
      Sorry for interfering, have you de soldered the chip?
      If so, there is a possibility that not all contacts on the chip are connected when soldering in.
      This happened to me once with a Dell 5500 because only the power button wanted to light up the front LED amber.
      After I checked the contacts and soldered them, it worked again.
      Hi I'm writing a quick update, I tried soldering the chip again but it doesn't help.
      I verified the contacts with my multimeter and I get the correct voltage on all the pins.
      Is it possible that another chip needs programming ?
      Best,
      Maxamax
      • skinner
        • Jun 2013
        • 60
        I was looking for some help. I have an Dell XPS 13 7390 2in1 that turns on, shows video but stays at the dell screen. I'm not 100% sure if this is a bios issue but was hoping someone had a working one I could try. Thanks.
        st: j365yy2
        ex: 41550619178
        • SI3MAR2000
          • Apr 2018
          • 52
          • MOROCCO
          #104
          Originally posted by SI3MAR2000
          Dell XPS 13 7390 2-in-1 DDP31 LA-G172P stuck on dell logo.
          someone can help me, i still need to solve the problem.
          • ali0robot
            • Mar 2023
            • 83
            • N/A
            #105
            hi guys,
            I have xps 13 7390 2-1 that stuck at Dell logo and restart continually. could some one fix my bios bin please
            servic tag : 4h7s573
            • ali0robot
              • Mar 2023
              • 83
              • N/A
              #106
              does it issue with bios or something else, because I have programmed two other bios but still same thing.
              • danito
                • Jun 2016
                • 1095
                • Romania
                #107
                Originally posted by ali0robot
                hi guys,
                try
                • ali0robot
                  • Mar 2023
                  • 83
                  • N/A
                  #108
                  Originally posted by danito
                  try
                  thanks for reply but same thing, I think issue is on other chip or component
                  • ali0robot
                    • Mar 2023
                    • 83
                    • N/A
                    #109
                    does anyone has a suggestion for me, laptop turn on but stuck on Dell logo. I have tried several bios. even I have programmed EC chip but still same thing. I couldn't find any fault in hardware. caps lock is on and doesn't change. two amber and one white led blinking
                    • ngodatvd5
                      • Jan 2021
                      • 20
                      • viet nam
                      #110
                      Hello, my laptop starts up slowly and doesn't detect audio. The BIOS is not the original one for this machine, because the Service Tag on the laptop and in the BIOS are different. The laptop's Service Tag is 6STL5Y2, while the BIOS currently shows BKT70Z2.
                      • peste
                        • Dec 2016
                        • 13581
                        • ROMANIA
                        #111
                        post full name and model, motherboard model,etc.
                        • ngodatvd5
                          • Jan 2021
                          • 20
                          • viet nam
                          #112
                          Dell xps 13 7390 2in1. Motherboard model ddp31 la-g172p
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12329
                            #113
                            XPS 13 7390 2-in-1
                            Service Tag: 6STL5Y2
                            ​https://www.badcaps.net/donate
                            • ngodatvd5
                              • Jan 2021
                              • 20
                              • viet nam
                              #114
                              Thank you. The BIOS is working and the laptop now starts up quickly, but there's still no sound from the speakers or the audio jack. In Device Manager, the Realtek driver is detected. It might be a hardware issue—I will check again.
                              • francisew
                                • Aug 2025
                                • 10
                                Model: Dell XPS 13 7390 2-in-1
                                Dell XPS 13 7390 2-in-1 13" Intel Core i7 - motherboard : DDP31 LA-G172P rev1.0 (A00) 2019-05-27, vendor: GCE, made in China
                                Service Tag: DPR71Z2
                                Express Service Code: 29855503550
                                Motherboard serial number: DP/N OV2CCD CN-OV2CCD-CMK00-99J-0118-A00
                                BIOS download attached: winbond_25q256jveq-xps13_2-in-1_7390.zip
                                Problem/symptoms:
                                Laptop now shows Dell logo briefly when plugged into usb C power supply, or when power key is pressed with battery connected. New battery was installed. After a few seconds (<5), the laptop shuts down. It does not respond to any keys (like control-escape, F2, F12, etc). It does not show any message text about pressing keys to enter bios settings.
                                Using a multimeter, I followed the power on sequence, and saw all relevant rails *very* briefly have voltage before it shuts off. Using IR camera, no parts get particuarly warm (<~25 degC) when it is powered up.
                                I believe the bios may be corrupt. I downloaded 2 copies of the bios and they match (using HxD). I can see english error message text near the end, so it looks like a good download.
                                Please note that this Dell laptop has been a disaster for years. They swapped it a couple of times, including first the mainboard, and later the whole system. They also swapped the bottom panel. I haven't had a service tag sticker since the computer swap, but I pulled the service tag information from the Dell web site. I hope it matches the BIOS. I called Dell for help, and they said send the laptop in and they will repair it. I pointed out that I need the data. They said make sure to back the data up before sending the laptop in, because they won't promise to send my original hardware back if they can't get it working. I pointed out that I can't back up the data if the system won't boot. They suggested taking it to a local computer repair shop. I tried some local places, but they all said that they don't know how to help. I REALLY appreciate this forum, and the awesome people who provide this useful information & help!!!
                                At this point my main goal is to recover data from my old laptop, which seems impossible unless I can somehow get this system to power on. I have considered hiring an electronics repair service to transplant the eMMC BG4 chip from my Dell mainboard to the NVMe variant of the same chip. Has anyone tried this? I don't know if soldering temperatures might cause the data to be lost anyways. Unfortunately, I cannot find datasheets for the Toshiba SSD/eMMC.
                                Other notes (for other people who might be looking into this model!):
                                At first I didn't understand how to remove the black heat-shield that has the fans attached. After the screws (mostly on the underside of the board) are removed, it can be gently pried away from the mainboard. There is a metal rail soldered to the PCB, and the heat-shield is pressed onto it (no adhesive, solder, etc).
                                Model details:
                                https://www.badcaps.net/forum/specif...rade-or-repair
                                Board files:
                                https://www.badcaps.net/forum/troubl...quest?t=106805
                                Actual bios chip: Winbond 25Q256JVEQ labeled as component UH8. AsProgrammer recognizes it as W25Q256FV.
                                Bios chip location: looking at the motherboard from the bottom of the system, with the fans along the top and the battery at bottom, the bios chip is located between the black shield and right side fan. It is close to the ribbon cable for the middleboard.
                                xps13 2-in-1 7390 mainboard bios chip location UH8 (w25q256jveq)
                                I was able to download the bios using a black CH341A programmer (with the modification to 3.3V), using a 6*8mm WSON8 pogo pin Probe tool I bought from amazon: https://www.amazon.com/dp/B0CJQ8KQK2. Note that the CH341A driver requires the parallel port version of the CH341 driver (https://www.wch-ic.com/downloads/CH341PAR_ZIP.html).
                                Actual SSD chip:
                                Toshiba KBG40ZPZ512G (BG4 series eMMC, 512GB) / now Kioxia. This 512GB SSD is a BGA part directly attached to the motherboard, not an NVMe drive. I think the same chip is likely used in the NVMe variant (KBG40ZNS512G): https://www.amazon.com/Kioxia-KBG40Z.../dp/B0B9NTRGGF
                                This specification for the DELL XPS 7390 2-in-1 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7390 2-in-1 boardview and 7390 2-in-1 schematic. Our users have donated over 1 million documents which are
                                Last edited by francisew; 09-04-2025, 08:27 PM. Reason: corrected the linked bios dump file name (I added both download copies).
                                • francisew
                                  • Aug 2025
                                  • 10
                                  By the way, many people seem to have similar issues with this laptop model:
                                  https://www.reddit.com/r/Dell/commen...eriously_died/
                                  • Markus1741
                                    • Sep 2020
                                    • 946
                                    • N/A
                                    #117
                                    Hello you can try this new file from version 1.35.0 but I wouldn't make too much hopes that the Dell XPS usually doesn't want to start with newly created BIOS files.
                                    I don't know why this is.
                                    Still, good luck maybe someone else knows how to repair it.
                                    • francisew
                                      • Aug 2025
                                      • 10
                                      Thanks Markus, I can confirm, I tried with the latest bios image you shared. Unfortunately, as you predicted I'm still seeing the same behavior (powering back down after ~5 seconds, never showing any options to enter the bios). Now I'm really not sure what to try next...
                                      • Slavol
                                        • May 2015
                                        • 84
                                        • Poland
                                        #119
                                        Please help! I've tried several BIOS versions from this thread, and unfortunately, none of them work properly. Either it doesn't recognize the drive (eMMC) or it boots several times without a display or very very long starting.
                                        I'm attaching my dumps - they're definitely corrupted, because the laptop doesn't respond to the power button.
                                        Thanks in advance for your help.
                                        My ST: 65BLX33, EX: 13382523327
                                        • quarka35
                                          • Oct 2025
                                          • 4
                                          • FRANCE
                                          #120
                                          I have my bios corrupted.
                                          Could you help me to fix it ?
                                          Service code: DC2MM13
                                          Please find attached corrupted bios.
                                          I need 32MB version because my flash is Winbond W25Q256JV
                                          Thank you so much.
                                          • peste
                                            peste commented
                                            Editing a comment
                                            post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          Today, 07:49 AM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                        • Clawed07
                                          BIOS file for a Dell Latitude 3340
                                          by Clawed07
                                          I've been trying to reset the bios password on this god-forsaken laptop, and due to it being a 8FC8, i've had little to no success with online password generators like https://bios-pw.org , not to mention how I don't want to burn a hole in my wallet by paying like 80 bucks on a weird sketchy website. Im using a local bios tool, except it requires a BIOS file, and I'm not entirely sure how to retrieve it.
                                          Forgot to mention the motherboard is a Dell Inc. 004WC7, VER. A01
                                          08-13-2025, 04:06 PM
