i need Dell XPS 7390 2 in 1 Gen 10 bios.bin file
    Re: i need Dell XPS 7390 2 in 1 Gen 10 bios.bin file
    Originally posted by danlopez1222 View Post
    hi,
    i'm having issues with xps 7390 2-in-1-
    board: La-g172p
    service tag: 7phfq13
    computer would not boot, just dim amber light whenever power button was pressed. I downloaded a bios online and inserted the bios region of original bios with service tag info to the new donor bios with new ec and me firmware.
    Now it will post but will not read from usb, or internal nvme drive. Sd boot still works.
    Must i use the original ec section? I tried with just using the donor me, but would not boot.
    I've attached my original non-functional backup, my half-functioning backup with new ec and me, and the donor bios.
    I also tried just the donor bios with the same symptoms as my modified bios.
    1111111
    Become a Badcaps supporter
    Thanks to all supporters.
      help me to fix this bios, cant display
        Here's your New BIOS, try it and give me the results.
        Service Tag: GDXV0X2.
        all donations are welcome,
          pls repair
            Originally posted by ACHRAFJIRANI View Post
            pls repair
            Try this file me be it helps ...
            Good luck ...
              Good luck ...
              thinks bro
                Re: Help me
                HI Bro ! Please fix this file full Fan and Alt F. Thank All Bro
                  Re: Help me
                  Try ...
                    Re: Help me
                    Try ...
                    This file you sent not power
                      Where is the BIOS chip located on this motherboard Dell XPS 13 7390 2-in-1? From what I see visually there are two Winbond 25Q64JVIQ chips in this motherboard. Which one is the BIOS chip.
                        I found it in another thread. Should have searched first. Thanks.
                          Dell XPS 13 7390 2-in-1 DDP31 LA-G172P stuck on dell logo.
                            ❤️YOU MUST:
                            ❤️Post a BIOS BACKUP if 1 or more than 1 (if you have)❤️
                            ❤️Provide the full machine model number, serial number (or Service tag, SNID)❤️
                            ❤️Motherboard part Number and revision (except QR codes)❤️
                            ❤️Must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.❤️
                            ❤️Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                              I don't have serial number, Service tag.about BIOS BACKUP i tried several time to upload but without success
                                compress it in winzip or winrar than attach
                                    Can you fix this bios?
                                    thanks
                                    Dell xps 7390 dead, no start with this bios
                                    1JPMM13
                                    3368685063
                                    CN-05M9KH-CMK00-03C-010F-A02
                                    DDP31 LA-G172P
                                    RE1 A00
                                    - i tried with other bios, laptop start, buth random detect ssd, and no usb c device detected (verry slow start)
                                      Service Tag: 1JPMM13
                                      try a new one
                                        try a new one
                                        laptop started (i have to disable C-state power management from bios.)
                                        now the usb c ports are working.
                                        -touchpad still not working, and no led working (touch pad have error in diagnostic program from dell)
                                        -bios cant update intel tbt retimer 2
                                        Important its that its working better than before. thanks
                                          Hi, I have this Dell XPS 7390 2-in-1 stuck @ Dell logo. Could you, please help me fix corrupted BIOS?
                                          Service Tag# D9J73Z2
                                          Bios file is attached. Thank you.
