i need Dell XPS 7390 2 in 1 Gen 10 bios.bin file
  • Maxamax
    Student
    • 6
    • Switzerland
    #101
    I have indeed de-soldered the chip to program it.
    I already thought of this as the cause of the problem (when I tried to repair the BIOS myself before posting), but I don't think this causes the issue.
    I tried powering up the PC without the chip at all and nothing happens.
    I'll verify with my multi-meter anyway, thank you
    • Maxamax
      Student
      • 6
      • Switzerland
      #102
      Originally posted by Markus1741
      Sorry for interfering, have you de soldered the chip?
      If so, there is a possibility that not all contacts on the chip are connected when soldering in.
      This happened to me once with a Dell 5500 because only the power button wanted to light up the front LED amber.
      After I checked the contacts and soldered them, it worked again.
      Hi I'm writing a quick update, I tried soldering the chip again but it doesn't help.
      I verified the contacts with my multimeter and I get the correct voltage on all the pins.
      Is it possible that another chip needs programming ?
      Best,
      Maxamax
      • skinner
        • Jun 2013
        • 54
        I was looking for some help. I have an Dell XPS 13 7390 2in1 that turns on, shows video but stays at the dell screen. I'm not 100% sure if this is a bios issue but was hoping someone had a working one I could try. Thanks.
        st: j365yy2
        ex: 41550619178
        • SI3MAR2000
          • Apr 2018
          • 49
          • MOROCCO
          #104
          Originally posted by SI3MAR2000
          Dell XPS 13 7390 2-in-1 DDP31 LA-G172P stuck on dell logo.
          someone can help me, i still need to solve the problem.
          • ali0robot
            • Mar 2023
            • 70
            • N/A
            #105
            hi guys,
            I have xps 13 7390 2-1 that stuck at Dell logo and restart continually. could some one fix my bios bin please
            servic tag : 4h7s573
            • ali0robot
              • Mar 2023
              • 70
              • N/A
              #106
              does it issue with bios or something else, because I have programmed two other bios but still same thing.
              • danito
                • Jun 2016
                • 911
                • Romania
                #107
                Originally posted by ali0robot
                hi guys,
                try
                • ali0robot
                  • Mar 2023
                  • 70
                  • N/A
                  #108
                  Originally posted by danito
                  try
                  thanks for reply but same thing, I think issue is on other chip or component
                  • ali0robot
                    • Mar 2023
                    • 70
                    • N/A
                    #109
                    does anyone has a suggestion for me, laptop turn on but stuck on Dell logo. I have tried several bios. even I have programmed EC chip but still same thing. I couldn't find any fault in hardware. caps lock is on and doesn't change. two amber and one white led blinking
                    • ngodatvd5
                      • Jan 2021
                      • 14
                      • viet nam
                      #110
                      Hello, my laptop starts up slowly and doesn't detect audio. The BIOS is not the original one for this machine, because the Service Tag on the laptop and in the BIOS are different. The laptop's Service Tag is 6STL5Y2, while the BIOS currently shows BKT70Z2.
                      • peste
                        • Dec 2016
                        • 12787
                        • ROMANIA
                        #111
                        post full name and model, motherboard model,etc.
                        • ngodatvd5
                          • Jan 2021
                          • 14
                          • viet nam
                          #112
                          Dell xps 13 7390 2in1. Motherboard model ddp31 la-g172p
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11729
                            #113
                            XPS 13 7390 2-in-1
                            Service Tag: 6STL5Y2
                            • ngodatvd5
                              • Jan 2021
                              • 14
                              • viet nam
                              #114
                              Thank you. The BIOS is working and the laptop now starts up quickly, but there's still no sound from the speakers or the audio jack. In Device Manager, the Realtek driver is detected. It might be a hardware issue—I will check again.
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • jhanra
                                by jhanra
                                in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                11-02-2024, 04:19 AM
                              • hazem3636
                                need Bios Bin file Dell server 220
                                by hazem3636
                                hi everyone
                                i need dump file for dell server r220
                                i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                                i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                                if anyone has this method please need his supporting .
                                all the best
                                EXE file is attched and Original Bin file from the Bios Chip is attached also
                                and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                                11-05-2022, 06:20 AM
                              • mrrubik
                                Dell Optiplex 7010 micro bad BIOS flash?
                                by mrrubik
                                Hi folks,
                                I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                Steps I took:
                                1. Read BIOS with CH341a, verified hash twice
                                2. Patched
                                12-23-2024, 04:11 PM
                              • trix11
                                Dell Precision T1650 MT Workstation bricked after BIOS update
                                by trix11
                                I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                - Dell Precision T1650 mid tower Workstation
                                - Xeon E3-1225 V2
                                - 32Gb PC3-12800E RAM
                                - 4Tb SATA HDD
                                - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                I see now that others have experienced like issues e.g.:
                                - https://www.dell.com/community/Prec...
                                10-24-2022, 10:35 PM
