Microsoft Surface Pro 7 NEED BIOS. HELP!
  • magneh
    • Apr 2014
    • 588
    • Portugal
    #41
    Re: Microsoft Surface Pro 7 NEED BIOS. HELP!
    Originally posted by AAAC
    @magneh
    I've taken PESTE bios (post #8) and complemented it with your bios (bkp.zip, post #29), invalidated "SetOEMStrings" UEFI variable... but seen other Dfcixxxx UEFI variables too.
    If this bios works it will be your starting point, then you can take care of the MDM/DFCI.
    @AAAC
    Thank you, really appreciated you took the time.
    Gonna test in a bit and let you know.
    • magneh
      • Apr 2014
      • 588
      • Portugal
      #42
      @magneh
      Thanks again AAAC.
      Device booted with your dump!
      I can see now the touch firmware version also, but touch still does not work.
      Device was brought to me already disassembled, even if screen not broken, touch could be defective itself.
      Regarding the MDM/DFCI , I suppose I should try to update firmware in windows to see if everything is good?
      Ive seen that bitlocker is active, so I couldnt get to login screen
      Thanks again for your help!
      Saludos a Mexico
      • AAAC
        • Jan 2020
        • 458
        • Mexico
        #43
        @magneh
        Try to check Touch connector, ripped flat cable, etc.
        Have you tried to use your own "bkp.zip" (post #29) file? to me seems to have the correct structure, have patched the SetOEMString UEFI variable too on this one.
        (The other "original.zip" file from post #29 is damaged)
        • magneh
          • Apr 2014
          • 588
          • Portugal
          #44
          @magneh
          Hello AAAC!
          Thanks for checking that bkp.zip dump.
          Ive just tried it, and it works!
          Same touch firmware version, but now works perfectly.
          Thanks for helping me with this one!
          Saludos para zapatecas!
          Gracias amigo.
          • ahmypc
            • Oct 2013
            • 78
            • Turkey
            #45
            @magneh
            Hi. Can you edit bios for pro 7 that only shows logo.Thanks.
            • giangtt
              • Oct 2017
              • 18
              • viet nam
              #46
              i have a surface pro 7 touch not work, can you fix help me!
              • fthgyj
                • Apr 2022
                • 3
                • New Zealand
                #47
                Hi
                I have a surface pro 7 Bios locked, can you please help to remove the password?
                • peste
                  • Dec 2016
                  • 12754
                  • ROMANIA
                  #48
                  Originally posted by fthgyj
                  Hi
                  the posted bios is corrupt ... what programmer are you using ??
                  • fthgyj
                    • Apr 2022
                    • 3
                    • New Zealand
                    #49
                    I am using Universal Bios Backup Toolkit 2.0
                    Just tried again, hopefully it works
                    • AAAC
                      • Jan 2020
                      • 458
                      • Mexico
                      #50
                      @fthgyj
                      The utility "Universal Bios Backup Toolkit 2.0" only works in those models when the password can be recovered, the utility only READ bios region (a partial bios chip dump, missing: ME Region, Descriptor Region and other), from that bios reading/dump the password is recovered.
                      In your case what you need is a bios chip programmer to obtain a FULL bios chip backup, then this backup can be patched and programmed back to bios chip.
                      If we could just build a kind of (SHA256) "rainbow table" with password hashes, then it will be a matter of looking up for your hash in that table and we would recover the actual password.
                      • iaf86
                        • Mar 2017
                        • 33
                        post the original bios, even if it is corrupt.
                        Hi Every one My surface pro 1866 shows windows logo on and off. i think bad bios can some one fix the old bios .
                        • iaf86
                          • Mar 2017
                          • 33
                          Hi, My surface pro 1866 shows windows logo and turned off I reprogramed few bios available on internet but no luck . is it possible to fix my old bios backup?
                          I attached my old bios back up .
                          thank you
                          Last edited by SMDFlea; 06-29-2022, 10:22 PM. Reason: there is no need to post the same bios again... just bump the thread !
                          • nguyenmeo199422
                            • May 2021
                            • 27
                            • Việt Nam
                            #53
                            Re: MS Surface no touchscreen after cleaning ME Firmware **FIX**
                            hi.
                            i have a surface pro 7 bootloop in logo.
                            please help me fix this. thanks.
                            • peste
                              • Dec 2016
                              • 12754
                              • ROMANIA
                              #54
                              Originally posted by LiveOnMercury
                              hi.
                              try..
                              • nguyenmeo199422
                                • May 2021
                                • 27
                                • Việt Nam
                                #55
                                try..
                                not working. thanks peste
                                it bootloop again
                                • Tjaytony
                                  • Oct 2020
                                  • 114
                                  • Nigeria
                                  #56
                                  Hi everyone.
                                  I have a surface pro 7 with bios password. I have tried every single bios dump here but my surface pro will only show windows logo for 3 seconds and go off again. but the original locked bios boots fine. This is my backup below may be anyone could help remove paasword or do some kind of magic. thanks in advance.
                                  • AAAC
                                    • Jan 2020
                                    • 458
                                    • Mexico
                                    #57
                                    @Tjaytony
                                    I've seen something similar before, it may be due to the SATA hard drive configuration in Setup/BIOS, it may be either "IDE Compatible mode", "AHCI mode" or other like "RAID mode" (have seen only the first two). So changing the SATA hdd mode may make a difference, but it's always better to work with the Original BIOS file.
                                    Give a try to your Original patched BIOS file.
                                    • Tjaytony
                                      • Oct 2020
                                      • 114
                                      • Nigeria
                                      #58
                                      Tnx I'll try it this noon.
                                      • maraketh
                                        • Jul 2017
                                        • 17
                                        • Romania
                                        #59
                                        Hi. i have the same device. i flashed a working bios, but i have no touch firmware. can anyone help me remove the password from original file?
                                        • AAAC
                                          • Jan 2020
                                          • 458
                                          • Mexico
                                          #60
                                          @maraketh
                                          Hi, this is your Original BIOS, patched to remove the password(s).
