Microsoft Surface Pro 7 NEED BIOS. HELP!
  • aol
    • May 2020
    • 7
    • france
    #101
    Re: Microsoft Surface Pro 7 NEED BIOS. HELP!
    hi,
    Thanks, I will give it a try!
    • isa198585
      • Feb 2020
      • 71
      • austria
      #102
      Hi, I have Surface Pro 7 Bootloop evr 2-3 Seconds.
      can some one Help with a working BIOS.
      here is m Original BIOD, readed with RT809F
      • Drhleb
        • Mar 2017
        • Russia
        #103
        Try this one, it could help you.
        Thanx sir, but still the same(
        • isa198585
          • Feb 2020
          • 71
          • austria
          #104
          any one help with post #102
          • gnoozle
            • May 2018
            • 54
            • gnoojpoh
            #105
            hello i need to unlock my surface pro 7 password in bios . help me please
            • peste
              • 13747
              • ROMANIA
              #106
              try..
              • isa198585
                • Feb 2020
                • 71
                • austria
                #107
                can you help with my Problem? #102
                • vikrep
                  • Sep 2011
                  • 34
                  #108
                  Hello everyone, I need to unlock my surface pro 7 password in bios. Help me, please.
                  • peste
                    • 13747
                    • ROMANIA
                    #109
                    try..
                    • vikrep
                      • Sep 2011
                      • 34
                      #110
                      Originally posted by peste
                      try..
                      Unfortunately, the file does not fit. The serial number is not native, there are no model and UUID numbers. The touch doesn't work. Main problem - SSD didn't recognise
                      Any ideas on how to edit the original file?
                      • AAAC
                        • Jan 2020
                        • 459
                        • Mexico
                        #111
                        @vikrep
                        Try with this file, Password ("AWord") and Absolute Computrace ("SetOEMStrings") have been deactivated (by modifying corresponding UEFI variable headers from AA553F hex to AA553C hex).
                        • vikrep
                          • Sep 2011
                          • 34
                          #112
                          Originally posted by AAAC
                          @vikrep
                          Thank you AAAC,
                          Unfortunately I can't check your file, because glued screen yesterday night.
                          I tried few uefi files from this place. All of them have different versions touchpad, TPM, ME and other revisions. So, one file didn't recognize SSD, other didn't recognize touchpad.
                          I put file without touchpad, recovered windows 10 and then put back original uefi. I this case saved all original numbers and drivers, but still present password on uefi.
                          I think surface Pro was erased by virus. Disk C has name "EraseMe" and was empty, so was no chance to recovery by Windows recovery.
                          Thanks everyone.
                          • Prott
                            • May 2022
                            • 154
                            • Czechia
                            #113
                            Hello, I have a problem with my Surface Pro 7 (i5, 8 GB ram). It was working great, but after an update to the bios it only turns on briefly with the windows logo and then turns off again. I tried some other bios files from this thread but it either completely doesn't work or is stuck again with the same problem.
                            Here is the original file dumped from the device.
                            I hope somebody can help. I would be endlessly thankful, cause it's a rather nice device.
                            • aahilkhan43
                              • Feb 2020
                              • 42
                              • uk
                              #114
                              surface pro 7 bios password
                              surface pro 7 when i try to do setup and after connceting wifi.
                              comes login.
                              plzz help me to remove.
                              this i took out bios bin file.
                              thank you.
                              • Prott
                                • May 2022
                                • 154
                                • Czechia
                                #115
                                Also to add, before the update (that bricked the device) the surface showed a purple stripe at startup. Not sure what that means... is it relevant? Thank you
                                • Prott
                                  • May 2022
                                  • 154
                                  • Czechia
                                  #116
                                  I am trying to clean the bios myself. Is there something else that I should be doing other than using FIT to unpack the dumped (original, non working) .bin, replacing the ME region with a clean one and then saving it again into bin?
                                  Previous posts mentioning the need to invalidate certain variables. Is it necessary when my BIOS wasn't password locked? Thanks again!
                                  • Prott
                                    • May 2022
                                    • 154
                                    • Czechia
                                    #117
                                    I wrote my "clean" bios to the chip, soldered it back on the board and the result is slightly different (I see the logo for a second or so more, then it shuts down).
                                    When I see the logo the tablet is drawing around 0.2 amps at 19 V.
                                    I am attaching the clean version of the bios.
                                    Sorry about doubleposting, but is there anybody that can please help in any way? :/
                                    • Lulinha
                                      • Oct 2021
                                      • 10
                                      • Brasil
                                      #118
                                      Hi friends. Some one help me fix my bios? after update corrupted, now stuck screen loading loop.
                                      • hardware1
                                        • Sep 2021
                                        • 2949
                                        • N/A
                                        #119
                                        Here's your Clean file, try it.
                                        all donations are welcome,
                                        • Lulinha
                                          • Oct 2021
                                          • 10
                                          • Brasil
                                          #120
                                          Thanks, but not work. Now logo 1 Second..
