ME Firmware Cleaning Guide
ineed Intel Management Engine 11.8 Firmware version 11.8.93.4323
thinksLeave a comment:
Post your request here --> https://www.badcaps.net/forum/troubl...matic-requests .Include the make and model in your thread title.Include the PC serial number in your post. Read the rules please https://www.badcaps.net/forum/troubl...before-postingLeave a comment:
I've cleaned my ME as described and I am wondering if I did it right.
Before cleaning: ME Analyzer shows Chipset as SPT-H D
After cleaning KBP/BSF/GCF-H A SPT-H D
Is that an expected output or did I screw something up?
TLDR:
Replaced HP ZBook 17 G3 motherboard (new), added SN/Model/Board/Build/Featurebyte, locked MPM and ended up with "Warning...not in commited state". I believe I forgot to make some ME settings.
Upgraded BIOS and ME firmware to latest version. Then I dumped the BIOS with a programmer and cleaned ME using firmware ME_11.8_Corporate_D0_H_Production.bin. Warning message is gone, laptop runs fine. How do I check if everything REALLY is fine?! 😅
2 PhotosLeave a comment:
也谢谢兄弟 .Thank you too brotherLeave a comment:
Post your bios + EC backups in a related thread for fixing,describe the issue and post your laptop serial number.
https://www.badcaps.net/forum/troubl...before-posting -
Original problem was slow start and 5 slow flashes of caps lock. Resetting to defaults resulted in not being able to get back to BIOS screens, requiring a reflash of the chip.
I loaded EC and BIOS from a donor board, updated BIOS via network. System was working (did not brick after loading defaults) but still had slow start. Identified ME as likely culprit in slow boot and 5 flash symptom.
I loaded bios file into Intel FIT (version 14.06) and changed Intel ME Binary File parameter to point to the ME RGN file and built a new image. I then burned that outimage.bin file back. 5 flashes is gone, but so is the disk controller. I've done all resets and it will not show up. I don't see where what I did is really any different than the process outlined in the ME Firmware Cleaning Guide, except for the Create Intermediate Files option. So, not sure what happened here. Any possibility of recovery?
I'd like to know what I did wrong here, rather than just upload files and have someone fix it. I can of course upload any files required for analysis.
Appreciate any assistance. Assuming I can get this resolved, I will still be left with a 'HP Endpoint Security Controller Problem', but one thing at a time. Thanks in advance.
Flash Programming Tool is used to backup and flash the bios on a working machine. Modular Flash Image Tool (MFIT) is used to clean the ME firmware. -
@volinakis thanks bro for REGIONS ME . its work and i try to hide a specific GUID from a binary .bin
The idea would be to hide the splash logo and not see it with the "change logo" or with the "phoenix tool" or with the "uefitool".
its possible bro?1 PhotoLeave a comment:
by SMDFleaIf you have to clean the ME firmware on **some microsoft surface models the touchscreen can stop working.
** Some models do not need this fix.
*You should install the latest updates from microsoft,including the driver packs before assuming there is a hardware problem.* - See Post #2
EDIT: If nothing else works try this fix - https://www.badcaps.net/forum/showpo...8&postcount=40
Always check a working dump from the same model using FIT.If the working dump default setting for "Integrated Sensor Hub Supported" is set to "NO"...-
Channel: BIOS Requests ONLY!
by Wachenaggoi know a tool https://github.com/MuertoGB/MacEfiToolkit is capable of SN change and Clean ME but not updating EFI Version of the BIN file. is there a guide or a BIOS structure to update the firmware??...03-06-2024, 01:34 AM
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...02-10-2024, 02:07 PM -
by gurj1979Hi guys.
I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
Got New chip and writes good.
THE PROBLEM...
It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
Does anyone have a Good Firmware I can have?...-
Channel: Troubleshooting & Designing Networks
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
- Loading...
