ME Firmware Cleaning Guide
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: ME Firmware Cleaning Guide
    Originally posted by SMDFlea
    It means the ME firmware is already cleaned.
    Thanks for clarifying,.
    So it means ME firmware is clean for all files as all bios files which i got showed same status whether it is original bios or downloaded from HP website.
    Alright i got it thanks and also if you have time reply my other created threads.
    i have an updated situation there.
      • 20374
      If the bios update image is a full bios including the ME firmware and not just a bios update then yes.Once the laptop is booted the ME will be married to the chipset and become initialised. For more info see the ME cleaning guide at win-raid section A. ,B. , C. https://winraid.level1techs.com/t/gu...lization/31277
      • Bonzas
        • 468
        • Indonesia
        Which part in particular are you getting stuck with
        I'm not sure where, maybe i need more practice.
        and how we get rsa key or can rsa key generate by software ?
        i read on some forums that some bios need rsa key when we clean ME section
        CMIIW
          • 20374
          CMIIW
          The key is generated by openssl ,see the definitive win-raid guide linked above ,read this section -
          D4. CSME 11 - 14 & CSTXE 3 - 4
          7.Go to "Platform Protection" and check if "Platform Integrity" section is present. If "Platform Integrity" section is present, continue as instructed below. Otherwise, proceed to the next step of the guide.
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            If the bios update image is a full bios including the ME firmware and not just a bios update which is the bios region then yes.Once the laptop is booted the ME will be married to the chipset and become initialised. For more info see the ME cleaning guide at win-raid section A. ,B. , C. https://winraid.level1techs.com/t/gu...lization/31277
            Hi, this guide is very valuable and i am currently reading it and trying to understand these methods .On the other hand i am sharing an image of ME analyzer reading the file bios bin and it has state configured but i am not able to understand Chipset status , SKU is Consumer H which is valid but chipset name i am not getting it.
            Thanks in advance.
            • oscars
              • Oct 2013
              • Turkey
              #26
              what do you think about "Intel Easy Clean Me"? i use this before and it worked for me.
              • lapfix
                • Mar 2020
                • 2602
                • my workshop
                #27
                Maybe it help you for some models , but not a good one.
                Try the official soft : Flah image tool
                If you follow the guide post it By SMDflea , you will be sure that your clean is perfect
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3559
                  • slovakia
                  #28
                  when i try to open bios file i get this error
                    • 20374
                    The bios is corrupt.Post it in the bios requests for fixing .
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3559
                      • slovakia
                      #30
                      but it show me even on known good bios
                        • 20374
                        You should open the bios with ME Analyzer first and check what ME firmware version you have,then you need the FIT tools version that matches. You`ve been trying to open a G50-70 bios that has an ME FW version 9.5 with FIT 11 . Each ME firmware version has its own set of tools.There`s a link in the first post to all the tools, and the full ME cleaning guide at win-raid .
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          #32
                          @smdflea, is the procedure same for TXE cleaning?? Why a cleaned file shows a lot of warning and error(even a original dump also) with MEA for ME 12.0 or higher??
                          • ligym60
                            • Oct 2016
                            • 39
                            Hi, im trying to clean a ME region on a mba 7.1 im using this file MB71_003F_00B.scap
                            with uefitool ne alpha 58. I can't seem to find the ME region raw section.
                              • 20374
                              Yes its the same for TXE except the FW needs renaming to TXE Region.bin for versions 1,2,3.For version 4 rename to TXE Sub Partition.bin .The win-raid guide has everything you need to know.
                              Ive had the same MEA error messages in the past with a few bios,updating to the latest version made the errors go away. https://github.com/platomav/MEAnalyzer/releases
                                • 20374
                                You can find apple ME FW here - https://www.badcaps.net/forum/showthread.php?t=83137 , @piernov has a good video too showing how to extract the ME from the scap files and how to use the correct FIT settings
                                • ligym60
                                  • Oct 2016
                                  • 39
                                  Thank you very much it was a quick fix because of your help
                                    • 20374
                                    You`re welcome
                                    • ligym60
                                      • Oct 2016
                                      • 39
                                      one last question is it nessary to pram when cleaning ME region?
                                        • 20374
                                        Only if it doesn`t boot.
                                        • ligym60
                                          • Oct 2016
                                          • 39
                                          Thanks for clarifying that
