Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
  • minhdigital
    • Nov 2022
    • 743
    • Vietnam
    #221
    Originally posted by teto8485
    sn/ 012308791653
    Send to you, try
    • c_hegge
      • Sep 2009
      • 5219
      Well, I can't believe I'm back after all these years (long story). But anyway. I'm also now in need of a Surface Pro 5 BIOS Password to be removed. I've tried it unsucessfully myself a few times, so hopefully someone with a bit more BIOS Modding experience can help. The device in question is a Surface Pro 5 1807 (LTE Variant), with the Motherboard 1011229-019 Rev 4.3 and Serial No 024774482153.
      • minhdigital
        • Nov 2022
        • 743
        • Vietnam
        #223
        Send to you
        • c_hegge
          • Sep 2009
          • 5219
          Works perfect. Thanks heaps!!😁
          I have a job lot of these which all had faulty SSD chips, so now to take care of that problem, but they also may or may not have BIOS passwords. In case I run into this issue again, I would be interested to know exactly what edits you make to the bin file to clear the password. I'm assuming it's done in a Hex editor like HxD, but I couldn't figure it out. I did find a few references to the System Password, but modifying those just caused it to power up for about 2 seconds and shut off.
        • c_hegge
          • Sep 2009
          • 5219
          OK. Interesting. The only differences that HxD Found were in 00606680x02 and 0061D540x02. In the original file, Both Values are 3F, while in the Unlocked one, both are 3C. Is that really all there is to it? Or am I (and HxD) missing something?
          • Vesko356
            Vesko356 commented
            Editing a comment
            Yes, that's it​.
        • Lucanoamaro
          • Jan 2024
          • 7
          • Italy
          #226
          Hi all, i have Surface Pro 5 Wi-fi with password lock bios. Is it possible to put the data of my bios like serial in an already unlocked working bios? Or i have to dump my bios and post it?
          Or is it possible to flash a working bios from another machine with different serial?
          Sorry, but i'm new to the forum :-)
          Thank's
          • Vesko356
            Vesko356 commented
            Editing a comment
            You MUST:
            • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
            • Name your thread with make, full model numbers and request
              Provide a BIOS/EC dump if possible
            • Attach files directly to your post instead of linking to external websites
        • Lucanoamaro
          • Jan 2024
          • 7
          • Italy
          #227
          Sorry!
          I have Surface Pro 5 1796 (i5/8gb/256/Wi-fi) with password lock bios.
          Serial is 040306174953.
          Is it possible to flash a working bios from another machine with different serial?
          Now i don't ave dump of the original bios.
          Thank's​
          • peste
            • Dec 2016
            • 12600
            • ROMANIA
            #228
            Originally posted by Lucanoamaro
            Sorry!
            Thank's​
            it would be good to post the original bios, and someone would help you..
            • Lucanoamaro
              • Jan 2024
              • 7
              • Italy
              #229
              Please remove UEFI password.
              Thank's​
              • peste
                • Dec 2016
                • 12600
                • ROMANIA
                #230
                Thank's​
                try..
                • Lucanoamaro
                  • Jan 2024
                  • 7
                  • Italy
                  #231
                  My programmer is KO. I bought a new one. When it arrives I'll try.
                  • Lucanoamaro
                    • Jan 2024
                    • 7
                    • Italy
                    #232
                    Sorry for the wait, but bios don't work. Only windows logo ad power off.
                    • peste
                      • Dec 2016
                      • 12600
                      • ROMANIA
                      #233
                      remove the bios chip from the board when you read or write it,. put back the bios with the password and see what happens.... if it works, try again with the new one..
                      • Lucanoamaro
                        • Jan 2024
                        • 7
                        • Italy
                        #234
                        All. OK!!! I had to desolder and re-solder the chip by adding solder on the motherboard.
                        Many thanks ;-)​
                        • pic16f84a
                          • May 2022
                          • 12
                          • España
                          #235
                          Good afternoon, I have a surface pro 1796. The logo appears 2 seconds and turns off. Can you help me?. Attached original bios
                          SN 028432283053
                          • sebkarimpour@gmail.com
                            Valiasr
                            • Aug 2019
                            • 25
                            • Iran
                            #236
                            SN 028432283053
                            Hi can you solve the problem .I have similar problem too?
                            • minhdigital
                              • Nov 2022
                              • 743
                              • Vietnam
                              #237
                              SN 028432283053
                              Send to you, try and feedback !
                              • minhdigital
                                • Nov 2022
                                • 743
                                • Vietnam
                                #238
                                Write serial your device and uploald your bios to here !!
                                  Valiasr
                                  • Aug 2019
                                  • 25
                                  • Iran
                                  #239
                                  hi again
                                  Sn:
                                  013817171653
                                  • pic16f84a
                                    • May 2022
                                    • 12
                                    • España
                                    #240
                                    effectively... it's working!!. Thank you very much for your contribution 😉
                                    • Buzzfuzz2k
                                      Bios password removal on a Unowhy dump
                                      by Buzzfuzz2k
                                      Hi Everyone,
                                      I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                      The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                      the Computer is a Unowhy small pc
                                      N° UYM6524702229
                                      After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                      My first attempt was to get the bios dump from windows...
                                      11-13-2023, 07:37 AM
                                    • traxformania
                                      TONGFANG "GM7TG7P" Bios Password Problem?
                                      by traxformania
                                      I tried :
                                      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                      11-15-2023, 07:32 AM
                                    • Nopslide
                                      by Nopslide
                                      04-01-2024, 04:27 PM
                                    • shadow666
                                      Surface Book 3 1899_TOP Rev 2.0 Bios Dump
                                      by shadow666
                                      hello
                                      i need surface book 3 dump bios
                                      Model : 1899
                                      MB : 1899_TOP
                                      Rev 2.0
                                      Serial : 037248401157
                                      CPU :Core i7-1035G7
                                      Dump Bios problem is no power
                                      Problem is after update windows surface is blue screen after force shutdown , surface won,t turn on
                                      Regard...
                                      02-24-2025, 11:01 AM
                                    • outsider
                                      Panasonic FZ-G1 MK5 - BIOS password returning
                                      by outsider
                                      Hello
                                      I removed the BIOS password thanks to the help of one of the friends of this forum.
                                      https://www.badcaps.net/forum/troubl...61#post3637661
                                      The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                      06-17-2025, 12:51 AM
