Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #181
    Re: Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
    Originally posted by abumu3ed
    update, the tab only shows boot logo then off
    Should work, most probably you didn't programmed the chip correctly, do it again - use verification, read the chip after programming and compare the content.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • partner
      Banned
      • Feb 2023
      • 53
      • BR
      #182
      This can happen in some versions, when the SaDataBase variable is linked to other security.
      • abumu3ed
        • Jun 2019
        • 44
        • tunisia
        #183
        you are right, a small capacitor (or something like) was accidently removed
        now everything works fine, thank you again
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #184
          You're welcome.
          • exwilliam
            • Apr 2022
            • 5
            • Cameroon
            #185
            Re: surface pro 5 bios/uefi unlock
            hi mates.
            I want to factory reset .
            There are bitlocker and SEMM activated.
            help needed here.
            Sorry for me not understanding the "AWORD" thing. (stupid me)...
            I merged the file "dumpnopass-aword1" with my one and now I get boot loop with only square logo showing.
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #186
              Originally posted by exwilliam
              hi mates.
              help needed here.
              The "AWORD" thing:
              • akam73
                • Aug 2021
                • 6
                • iran
                #187
                hi i have surface pro 5 {m1007506-015} touch screen not work after install new windows . i install any windows and download in microsoft,unistall&install new version driver touch but not happen. touch screen is replaced
                can you help me plz
                • peste
                  • Dec 2016
                  • 13199
                  • ROMANIA
                  #188
                  can you help me plz
                  try this..
                  https://www.badcaps.net/forum/showthread.php?t=104153
                  • exwilliam
                    • Apr 2022
                    • 5
                    • Cameroon
                    #189
                    The "AWORD" thing:
                    I try the new file.
                    I can now e ter uefi settings, but SEMM seems to be still active. I can't finish the recovery process.
                    Could you remove the SEMM lock also?
                    Thanks in advance.
                    • exwilliam
                      • Apr 2022
                      • 5
                      • Cameroon
                      #190
                      I try the new file.
                      Thanks in advance.
                      Edit: I restarted everything from scratch and now I could install recovery successfully!
                      Thanks again!
                      By the way, I'm still interested in knowing exactly what was the "AWORD" thing as I'm having another device with the same issue.
                      • JOHNLAG7
                        • Nov 2014
                        • 19
                        • Greece
                        #191
                        Hi
                        can anyone help to remove SEMM surface pro 5 1796 i hve remove the UEFI password but SEMM is active.
                        • volinakis
                          • Jan 2021
                          • 2809
                          • N/A
                          #192
                          Originally posted by JOHNLAG7
                          Hi
                          in bios you have Management tab and Zero touch UEFI Management and choose opt out.
                          "Zero Touch UEFI Management lets you remotely manage UEFI settings using a device profile within Intune called Device Firmware Configuration Interface (DFCI). If you do not configure this setting, the ability to manage eligible devices with DFCI is set to Ready. To prevent DFCI, select Opt-Out."
                          this is the way a solved the same problem to a surface pro 7+ and installed from USB create with rufus - look at rufus website and check boxes as in images.
                          • JOHNLAG7
                            • Nov 2014
                            • 19
                            • Greece
                            #193
                            Thanks but only Enterprise Management tab is there.
                            I managed to remove the SEMM by modify the bios but now missing UUID.
                            There is the modified bios.
                            Any help.
                            • volinakis
                              • Jan 2021
                              • 2809
                              • N/A
                              #194
                              Any help.
                              search for "remove SEMM surface pro" and you have a guide on learn.microsoft page.
                              • JOHNLAG7
                                • Nov 2014
                                • 19
                                • Greece
                                #195
                                Thanks.
                                I manage to fix it from bios all ok now.
                                • megatech27
                                  • Nov 2021
                                  • 8
                                  • Algérie
                                  #196
                                  I NEED TO REMOVE Surface Pro password BIOS DUMP
                                  • peste
                                    • Dec 2016
                                    • 13199
                                    • ROMANIA
                                    #197
                                    try..
                                    • megatech27
                                      • Nov 2021
                                      • 8
                                      • Algérie
                                      #198
                                      Originally posted by peste
                                      try..
                                      thanks but it didn't work
                                      • peste
                                        • Dec 2016
                                        • 13199
                                        • ROMANIA
                                        #199
                                        try this..
                                        • gnoozle
                                          • May 2018
                                          • 54
                                          • gnoojpoh
                                          #200
                                          please remove password
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • shadow666
                                            Surface Book 3 1899_TOP Rev 2.0 Bios Dump
                                            by shadow666
                                            hello
                                            i need surface book 3 dump bios
                                            Model : 1899
                                            MB : 1899_TOP
                                            Rev 2.0
                                            Serial : 037248401157
                                            CPU :Core i7-1035G7
                                            Dump Bios problem is no power
                                            Problem is after update windows surface is blue screen after force shutdown , surface won,t turn on
                                            Regard...
                                            02-24-2025, 11:01 AM
