Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
  • djquickshouse@gmail.com
    • Jul 2022
    • 3
    Re: Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
    Originally posted by peste
    you will need an SPI programmer ... more information on the internet ...
    https://www.youtube.com/watch?v=DWWigscuQDY
    Thank you. There's no other way other than taking it apart?
    • jsmrepairs
      EXPERT
      • Apr 2017
      • 6
      Originally posted by SiO2
      Great, now I see the byte that matters Thanks, will try it!
      Update: My Surface is alive again and running a recovery. Thanks a lot!!! You saved my day
      Can you help me understand how you found the "byte" and where it is?
      thanks
      • JohnShared
        • Aug 2022
        Hi guys,
        I have a surface pro 5 with a UEFI password. And I use a [FPTW64.exe] tool to dump my origin bios. Could you please help me remove the password? Thx!
        And here is my operation of dumping my bios into two files:
        one is the full SPI Flash with 16MBytes and the other is only the bios part with 10MBytes.
        Code:
        PS C:\Users\Surface\Downloads\fpt11\WIN64> .\fptw64.exe -d surfacepro5_i5_7300u_full.bin
        Intel (R) Flash Programming Tool. Version: 11.8.70.3626
        Copyright (c) 2007 - 2019, Intel Corporation. All rights reserved.
        Reading HSFSTS register... Flash Descriptor: Valid
          --- Flash Devices Found ---
          W25Q128FV  ID:0xEF4018  Size: 16384KB (131072Kb)
        - Reading Flash [0x1000000] 16384KB of 16384KB - 100 percent complete.
        Writing flash contents to file "surfacepro5_i5_7300u_full.bin"...
        Memory Dump Complete
        FPT Operation Successful.
        PS C:\Users\Surface\Downloads\fpt11\WIN64> .\fptw64.exe -d surfacepro5_i5_7300u_bios.bin -bios
        - Reading Flash [0x1000000] 10240KB of 10240KB - 100 percent complete.
        Writing flash contents to file "surfacepro5_i5_7300u_bios.bin"...
        • JohnShared
          • Aug 2022
          Can anybody help me unlock my bios? I used UEFITool to read my bios but I have no idea how to change it.
          • Kazik
            • Oct 2016
            • 53
            Can you please unlock this EFI dump? It comes from the Surface 1796.
            I did try to "FF" the dump from start-offset 600064 until end-offset 00614F4F but it didn't work. I can get into the EFI/BIOS but can't really click on anything.
            Thank you.
            • peste
              • Dec 2016
              • 12852
              • ROMANIA
              #126
              Thank you.
              try..
              • Kazik
                • Oct 2016
                • 53
                try..
                Thank you Peste.
                I just realized that my original attempt (described above) to unlock the EFI was actually successful. Your file works as well. I was fooled by the touchpad and touchscreen not working in the EFI menu (on both - mine and yours files). After connecting external mouse I can change the EFI options on mine and yours EFI.
                The Touchpad and Touchscreen works fine in Windows OS.
                Regards
                Peter
                • anjelics
                  • Sep 2014
                  • 15
                  • Romania
                  #128
                  Surface pro 5 with UEFI password. need help to unlock!
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11787
                    #129
                    Your file corrupted, read chip again.
                    Mį»i khoįŗ£n quyĆŖn góp cho badcaps đều được hoan nghĆŖnh, hĆ£y nhįŗ„p vĆ o liĆŖn kįŗæt nĆ y Ä‘į»ƒ quyĆŖn góp. Cįŗ£m Ę”n tįŗ„t cįŗ£ những ngĘ°į»i į»§ng hį»™----------------------------------------------------------------------------------------------------------------------------------------------------------------
                    • anjelics
                      • Sep 2014
                      • 15
                      • Romania
                      #130
                      hi hoaca388. I read chip 3 times, same result. I compared my dump with other and I see that my dump is mostly empty but that it. Surface is starting normal but windows is corupt. In BIOS I have few options after I receive message about UEFI settings protected by password
                      • iaf86
                        • Mar 2017
                        • 36
                        Surface Pro 5 1796 has UEFI password protection
                        Hi All,
                        I have a Surface Pro 5 1796 with UEFI password lock.
                        I downloaded the bios file from the internet and programmed the chip, which removed the ufi password, but the surfacepro serial number changed to 789789789, and some functions, such as battery charging and touch screen, ceased to function.
                        I backed up the original locked BIOS; can anyone assist me in removing the password from the original BIOS Dump?
                        Thank you very much.
                        • peste
                          • Dec 2016
                          • 12852
                          • ROMANIA
                          #132
                          Re: Surface Pro 5 1796 has UEFI password protection
                          Originally posted by iaf86@live.com
                          Hi All,
                          try this
                          • Redlikeblood
                            • Dec 2022
                            • 5
                            • Hungary
                            #133
                            I have a surface pro 5 (8/256) 1796,M1007506-015
                            Bought it second hand from a shop, it works, I can reinstall it from usb, but when the system loads, a red bar with opened lock appears on top, which is annoying. (Also, I can't change the security, Tpm, secure boot settings in the Uefi menu) I made dump and attached from original rom.
                            Atm i flashed with OEMCA, SN.:789789789 without UUID. (Attached picture)
                            The touchscreen and TP works in Uefi, everything is fine until reinstall windows, what i thought without uuid: Surface app closing, and can't install drivers.
                            Anybody can help to unlock my original bios?
                            Thank you
                            • volinakis
                              • Jan 2021
                              • 2734
                              • N/A
                              #134
                              Thank you
                              try
                              • Redlikeblood
                                • Dec 2022
                                • 5
                                • Hungary
                                #135
                                Originally posted by volinakis
                                try
                                Wow, nice work, thank you.
                                Only one thing remained: the red bar with padlock on top.
                                I tried to set new password then cleared, without luck. Any idea?
                                • volinakis
                                  • Jan 2021
                                  • 2734
                                  • N/A
                                  #136
                                  found this on net:
                                  Solution: Turn on Secure Boot
                                  To turn on Secure Boot to help make your Surface more secure:
                                  Shut down your Surface and wait about 10 seconds to make sure it's off.
                                  Press and hold the volume-up button on your Surface, and, at the same time, press and release the power button.
                                  The Microsoft or Surface logo appears on your screen. Continue to hold the volume-up button until the UEFI screen appears.
                                  Select Security.
                                  Under Secure Boot, select Change Configuration.
                                  Select a Secure Boot certificate keyset (for example, Microsoft only).
                                  Select Exit > Restart now to save your changes and restart your Surface.
                                  • Redlikeblood
                                    • Dec 2022
                                    • 5
                                    • Hungary
                                    #137
                                    found this on net:
                                    Select Security.
                                    Works perfectly Thank you again.
                                    • Redlikeblood
                                      • Dec 2022
                                      • 5
                                      • Hungary
                                      #138
                                      try
                                      Oh, the charging not working.
                                      • volinakis
                                        • Jan 2021
                                        • 2734
                                        • N/A
                                        #139
                                        Bios does not contain PMC, I don't think it's from Bios. anyway try this clean ME.
                                        • volinakis
                                          • Jan 2021
                                          • 2734
                                          • N/A
                                          #140
                                          you already have bios with old ME cleaned. the file you sent was already cleaned. Here you have file with old ME cleaned and unlocked.
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • shadow666
                                            Surface Book 3 1899_TOP Rev 2.0 Bios Dump
                                            by shadow666
                                            hello
                                            i need surface book 3 dump bios
                                            Model : 1899
                                            MB : 1899_TOP
                                            Rev 2.0
                                            Serial : 037248401157
                                            CPU :Core i7-1035G7
                                            Dump Bios problem is no power
                                            Problem is after update windows surface is blue screen after force shutdown , surface won,t turn on
                                            Regard...
                                            02-24-2025, 11:01 AM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
