Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
  • ykcornisauga
    • 4
    • phillippines
    #101
    Re: Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
    Originally posted by SMDFlea
    Read earlier posts .Download both attachments,open both with with a hex editor and do a file compare,there is only one change to make.
    The clue is AWORD
    what do you mean by AWORD please id like to educate my self so that i can help others to. i compare the one with pass with the other one. i only get hex character i dont see an AWORD. Please enlighthen me. Thanks!
    • t000
      • Apr 2022
      • 4
      • Switzerland
      #102
      Surface Pro 1796
      Hi
      I have a Surface Pro 1796 (Gen.5). A bios password is set. I know the password but I can't change it. I can't change all the other options either, such as Security, Secure Boot, m TPM SMT etc..
      It also says "some settings are managed by your organization"
      Is it possible to flash the bios again so that I can use all options? Are there other solutions so that I can use the device to its full extent?
      note the attachments.
      Regards
      • peste
        • Dec 2016
        • 12742
        • ROMANIA
        #103
        Re: Surface Pro 1796
        Originally posted by t000
        Hi
        Regards
        post the original bios ..
        • t000
          • Apr 2022
          • 4
          • Switzerland
          #104
          Where can I find instructions on how to save the bios?
          Regards
          • peste
            • Dec 2016
            • 12742
            • ROMANIA
            #105
            Regards
            you need an SPI programmer ...
            you can find more videos on the internet >>
            https://www.youtube.com/watch?v=DWWigscuQDY
            • t000
              • Apr 2022
              • 4
              • Switzerland
              #106
              thanks
              • SiO2
                • Apr 2022
                • 24
                Hi, I have a Surface Pro 5 with a lost system password Can you help me to clear it?
                Cheers
                  • 20801
                  Cheers
                  Compare a locked and unlocked bios with a hex editor,there is only one thing to change.
                  • SiO2
                    • Apr 2022
                    • 24
                    When I compare the two posted files in this thread on page 4, my compare tool finds a few scattered diffs and a huge block which is different. I can't figure out which diff is the significant one.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11709
                      #110
                      Try
                      Mį»i khoįŗ£n quyĆŖn góp cho badcaps đều được hoan nghĆŖnh, hĆ£y nhįŗ„p vĆ o liĆŖn kįŗæt nĆ y Ä‘į»ƒ quyĆŖn góp. Cįŗ£m Ę”n tįŗ„t cįŗ£ những ngĘ°į»i į»§ng hį»™----------------------------------------------------------------------------------------------------------------------------------------------------------------
                      • SiO2
                        • Apr 2022
                        • 24
                        Great, now I see the byte that matters Thanks, will try it!
                        Update: My Surface is alive again and running a recovery. Thanks a lot!!! You saved my day
                        • alex3ple7
                          • Aug 2021
                          • 6
                          • Montenegro
                          #112
                          Hi guys.
                          I get Surface 1796 with corrupted bios. Turn logo for few sec and shuts off. Does anyone have clean bios file for this model? A lot of files from this thread that I downloaded cannot open cause it says it's damaged file.
                          Thanks in advice.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11709
                            #113
                            Originally posted by alex3ple7
                            Hi guys.
                            Thanks in advice.
                            Post here your original bios file.
                            • alex3ple7
                              • Aug 2021
                              • 6
                              • Montenegro
                              #114
                              here..
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11709
                                #115
                                here..
                                Try
                                • alex3ple7
                                  • Aug 2021
                                  • 6
                                  • Montenegro
                                  #116
                                  Try
                                  I tried. Same thing,power for few sec and shut off. Drop to 0.03v and stay there. Should I try other bios or is something else here?
                                  • alex3ple7
                                    • Aug 2021
                                    • 6
                                    • Montenegro
                                    #117
                                    Any advice? another flash file,bios ic?
                                    • alex3ple7
                                      • Aug 2021
                                      • 6
                                      • Montenegro
                                      #118
                                      I flashed with some bios file i found on forum and finally laptop booted. But touchscreen and keyboard with trackpad not working and its also locked on BitLocker. So it was corrupted bios but dont know how to find and where clean good working bios file for this model. ANyone had some advice?
                                      • djquickshouse@gmail.com
                                        • Jul 2022
                                        • 3
                                        Hey guys. I just bought a second hand Surface Pro 5 and it works fine. I'm trying to get into the bios though to enable secure boot because when I boot it up, it shows a red bar on top with an unlock symbol. The bios/uefi however is secured with a password which I obviously don't know.
                                        I've read through this particular forum topic as well as did research online but I'm still having a hard time trying to dump my bios. What do I have to do to dump the bios to a file?
                                        Any help would be appreciated and thank you in advance.
                                        • peste
                                          • Dec 2016
                                          • 12742
                                          • ROMANIA
                                          #120
                                          you will need an SPI programmer ... more information on the internet ...
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • shadow666
                                            Surface Book 3 1899_TOP Rev 2.0 Bios Dump
                                            by shadow666
                                            hello
                                            i need surface book 3 dump bios
                                            Model : 1899
                                            MB : 1899_TOP
                                            Rev 2.0
                                            Serial : 037248401157
                                            CPU :Core i7-1035G7
                                            Dump Bios problem is no power
                                            Problem is after update windows surface is blue screen after force shutdown , surface won,t turn on
                                            Regard...
                                            02-24-2025, 11:01 AM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
