Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
    • 21447
    Re: Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
    Originally posted by bafylu
    hi surface pro 1796 bios password can someone help, thanks
    Read earlier posts .Download both attachments,open both with with a hex editor and do a file compare,there is only one change to make.
    The clue is AWORD
    • bafylu
      • May 2017
      • 3
      • moldova
      #82
      attach file
      • 4rest
        • Feb 2022
        • 3
        Could somebody help me about my Surface Pro 5 ?
        [ Microsoft Surface Pro 5 /M1796/ 4gb 128gb /
        I dumped bios from my not working chip on my Surface pro 5 ( whenever click power on, the winodws logo would last about 4 seconds, then screen goes to black), the dumped file size only 1Mb ( version 11.6..20.1221 by UFEITOOL). Said "No BIOS region section" when checked by UFEITOOL 0.28.0
        And I tried download biso 16Mb from the website (microsoft-surface-pro-5-m1007506-015-clear-me-bios, version 11.8.50.3448)), reflash to chip, pro5 is working properly in everything, but no touch function.
        Is there a way to fix touch function?
        Dumped BIOS and clear ME BIOS
        My dumped BIOS
          • 21447
          What did you use to make your backup.As it was getting to the windows logo there wasn`t much wrong with the bios. Its very important to make a good backup of the original bios,theres no way it would only be 1MB and boot to the windows logo.
          AFAIK theres no fix yet for the touch screen not working when you flash a different bios,i could be wrong though
          • 4rest
            • Feb 2022
            • 3
            I used CH341A programmer to read after removed 25Q128FV-Winbond from PCB. And I used same tool to flash the downloaded BIOS to Chip, then solder bak on PCB.
            • abdielhdz
              • Mar 2022
              • 3
              • panama
              #86
              hello everyone I'm new to the forum please I need help I bought a surface pro 5 on ebay and it's blocked by uefi it doesn't have windows installed either.
              Can someone help me or give me a link to a tutorial. Thank you
              sorry for my bad English
              • onizzbox
                Banned
                • Nov 2018
                • 604
                • Brazil
                #87
                @abdielhdz
                The only way to unlock it is through the BIOS, it is necessary to post the file after reading.
                • abdielhdz
                  • Mar 2022
                  • 3
                  • panama
                  #88
                  hello thanks for answering
                  should I use any program? excuse my ignorance
                  • onizzbox
                    Banned
                    • Nov 2018
                    • 604
                    • Brazil
                    #89
                    @abdielhdz
                    The whole process is very simple, but it depends on opening the equipment and eprom programmer, tipo CH341A (low cost).
                    • abdielhdz
                      • Mar 2022
                      • 3
                      • panama
                      #90
                      Can you tell me the steps to follow?
                      taking out the ssd disk and formatting it on another pc and then installing it on the surface could it let me install window?
                      • onizzbox
                        Banned
                        • Nov 2018
                        • 604
                        • Brazil
                        #91
                        @abdielhdz
                        It is not that simple, during the installation Windows is set to the machine's defaults.
                        The installation will probably be incompatible with another device.
                        It might even work if you had two identical laptops, i.e. of the same model.
                        It would be much easier to unlock the laptop.
                        • tooko
                          • Nov 2014
                          • 38
                          • france
                          #92
                          I need to remove bios password of my surface pro 1796 . Here is the dump of the eeprom.
                          thanks
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12110
                            #93
                            thanks
                            try
                            • onizzbox
                              Banned
                              • Nov 2018
                              • 604
                              • Brazil
                              #94
                              Originally posted by hoaca388
                              try
                              @hoaca388
                              Check again, it won't work!
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12110
                                #95
                                Ok , again
                                • tooko
                                  • Nov 2014
                                  • 38
                                  • france
                                  #96
                                  try
                                  thanks. I am going to try and let you know the result .
                                  thnak you for your answer
                                  • tooko
                                    • Nov 2014
                                    • 38
                                    • france
                                    #97
                                    Ok , again
                                    So I am going to try this one first !
                                    thanks bro
                                    • tooko
                                      • Nov 2014
                                      • 38
                                      • france
                                      #98
                                      Originally posted by onizzbox
                                      @hoaca388
                                      Thank you @onizzbox for your help !
                                      • tooko
                                        • Nov 2014
                                        • 38
                                        • france
                                        #99
                                        Ok , again
                                        Thank you, it works like a charm !
                                        Best regards.
                                        • nas600
                                          • Feb 2022
                                          • 9
                                          • United Kingdom
                                          #100
                                          Originally posted by TranTrien
                                          Hi friend , can you please tell me how did you backup bios file with CH314a . how did you connected it . or we have to take the EC out ?
                                          Thank you so much
                                          Hi Friend,
                                          I desoldered the IC. On thes chips I could not find an adapter that can connect while it is soldered to mainboard.
                                          Removed it from mainboard. Then soldered on connectivity board with low tempereture solder.
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • shadow666
                                            Surface Book 3 1899_TOP Rev 2.0 Bios Dump
                                            by shadow666
                                            hello
                                            i need surface book 3 dump bios
                                            Model : 1899
                                            MB : 1899_TOP
                                            Rev 2.0
                                            Serial : 037248401157
                                            CPU :Core i7-1035G7
                                            Dump Bios problem is no power
                                            Problem is after update windows surface is blue screen after force shutdown , surface won,t turn on
                                            Regard...
                                            02-24-2025, 11:01 AM
