T470 bios needed
https://www.badcaps.net/donate -
Re: T470 bios needed
okey so how i understand when im using that patcher and flash with new bios file its always stuck on lenovo logo . when i flash bios with password then its works without problems . it can be problem in another bios chip ? there is 2 bios chips . first one u15 and another u49 .
		Attached Files↵
https://www.badcaps.net/donateComment
I have a T470. The Bios is corrupted. It starts, i see logo and then it show the normal screen that there is no system on hard drive.
But when i press F1 to go to bios, the screen is black. I cant go to bios.
Hope you guys can help.Attached FilesComment
hello , please help this bk have computrace, any can helpme to remove please. thanks youAttached FilesComment
try and give replyAttached FilesKill the state in yourself and you will be free like a wind...Comment
hello,
i try to unlock bios with patcher, but now i cant enter bios. its just blank screen when i enter bios. can you help fix my bios ?Attached FilesComment
I got my t470 20HE corrupted in a bad flash (no boot).
The winbond is a 25Q80JV 8Mb chip, but all I see here is 16Mb files for this bios.
I used Neo programmer and a ch341 to read the bios.
Am i missing something?
is there a way to extract a bin file from a bios update?Attached FilesComment
101.4 KB is far away from a good read. Try again be more careful.I got my t470 20HE corrupted in a bad flash (no boot).
Use NeoProgrammer V2.2.0.10
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
"25Q80JV" size is (1MB/8Mbit/1024KB) and it's a Wrong chip, search for another chip on the Motherboard (Both sides).I got my t470 20HE corrupted in a bad flash (no boot).
is there a way to extract a bin file from a bios update?----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
I found an other one ; 25Q128FVSQ
seems to be the right size, but the read freezes (neo 2.2.0.10)
Current programmer: CH341 Black
SPI ID: EF4018
Currently selected: W25Q128FV [3.3V] 128 Mbits, 16 Mbytes
i'm reading on board, the chip gets detectedComment
25Q80JV is the most famous spi chip around here.
I don't understand why rookies likes him the most, probably because of the number 80 on the marking.
Edit:
Yes it is, that's the right one. Are you using a clip to read the chip?
.Last edited by Vesko356; 05-05-2023, 04:07 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
They probably assume it will be 8MB. Also sometimes it has the same package as the BIOS chip (SOP8/SOIC8).
Yep, the full aliexpress package.
Freezes sometimes in the beginning, sometimes halfway.
desolder?
Yep, I bet that's exactly why.
Maybe it's time to put in my signature - "Do not touch the 25Q80xxxx chip"
Edit:
Absolutely.
.Last edited by Vesko356; 06-22-2023, 01:24 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------
			by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
							Channel: BIOS Requests ONLY!
			by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
 - External display (HDMI) shows
07-24-2025, 02:17 PM -
			by loftonHello, I was flashing the bios but now the machine does not come, the battery indicator turns orange when charge is plugged in. As soon as it plugged by charger or battery the power button and escape blinks once then fade out Sometime it blinks 3 timess . With the back case off i can see the fan spins a little then top, but once i press the button it spins a little then stop and repeat for a while until stops. I have attached the bios dump. I had read the chip next to the cmos battery (25q80jvsiq) then i realize that it wasn't the bios. as the bios is next the memory slot. By doing that could...
04-17-2024, 09:27 AM -
			by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
			by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
 - Loading...
