Hello, I was flashing the bios but now the machine does not come, the battery indicator turns orange when charge is plugged in. As soon as it plugged by charger or battery the power button and escape blinks once then fade out Sometime it blinks 3 timess . With the back case off i can see the fan spins a little then top, but once i press the button it spins a little then stop and repeat for a while until stops. I have attached the bios dump. I had read the chip next to the cmos battery (25q80jvsiq) then i realize that it wasn't the bios. as the bios is next the memory slot. By doing that could i have corrupted u15 25q80jvsiq, could that be the reason why it wont post? i saw a post saying don't touch the 25q80jvsiq but it was little too late. I jumped the gun. Is 25q80jvsiq considered the EC? The bios chip on the board is win bond 25Q128JVSQ - 1911 any help would be appreciated.
Lenovo t470 20jn-sv2vnoe PF1Q63B0 Bios/EC needed
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
History:
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... - Loading...
