LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
 Thanks for sharing.
 I tried the file you shared,
 I wrote it and verified it was written correctly.
 It has the same problem as above: it beeps 5 times twice, the fans spin for a few seconds, and then shuts down. No signal.
 rewriting my original, it goes back to how it was before with the password.Comment
 Hello friends! I used autopatcher, rewrote the patched file in the bios, but as a result, when I press the power button, it blinks 3 times. Then nothing happens. Can someone help?
 Laptop Lenovo P50
 Type 20EQ
 Serial MJ-04TPLTComment
 Try with this attached content.
 STEP 1: Flash and replace current BIOS with the P50_Bios_2_PATCHED.bin file
 STEP 2: Boot the machine
 STEP 3: Press ENTER/F1/etc. to enter BIOS settings
 STEP 4: Enter any character when asked for Supervisor Password
 STEP 5: Press enter when it shows Hardware ID
 STEP 6: Press space bar 2x when asked
 STEP 7: Turn off machine
 STEP 8: Restore original P50_Bios_1.bin BIOS content
 STEP 9: Reset BIOS settings to factory default
 Good luck!Attached FilesComment
 Flashing both chips back to their original states doesn't even fix it, it no longer boots at all after trying the PXE driver injector method...
 OK, that's good. (PC0PTLL4 with "zero" after letter C.
 The 25Q80 chip is your PD controller SPI so must be untouched and write it back as is.
 Write the content from the attachment and tell me if it works or not.
 It's tested by me on several T470s laptops.Attached FilesComment
 I flashed it just now, it still does the same thing. The keyboard and power button light up briefly then it shuts off. This happens once when power is plugged in, then it is unresponsive until unplugged and plugged back in once more.Comment
 OK.
 I see some differences between your PD Controller backup and what I have saved on my PC.
 So here is mine to try.
 Do you use clips to flash the chips or you desolder them ?
 Check for missing or damaged components near the BIOS chip.
 If programming different versions of BIOS did not result in different behavior most likely you have a hardware issue...
 Yes I used SOIC8 clip with CH341a programmer. Didn't happen until I went through the bios unlock process listed on the lenovo autopatcher. It showed the usual PXE driver screen, turned off, I flashed the original like it said to, then it wouldn't turn on. I'll inspect the board.
 After looking, I don't see any damaged connections or missing pieces, or any significant activity on thermal camera. However, I did just notice that once powered on, the fan continues to spin and stop, over and over like it's continuously trying and failing to boot. I've attached pictures of the rom chips, maybe I missed something.Comment
 It's very tricky to use clips...must be careful and check the reading/writing at least 2 or 3 times to be sure it's done correctly...
 As a last try ... here is the EC content.
 I hope you can and know how to use JTAG to read/write the MEC1653. (You find plenty of examples here on badcaps how to prepare the MB and use the JTAG to read/write MEC chips...
 An example: https://www.badcaps.net/forum/troubl...lock#post74632)
 I don't know about the MEC1653 but the MEC1633 has an internal 2Kb EEPROM in witch is the password stored so if this is true for MEC1653 then rewriting the EC content may help to bring your laptop back to life.(without clearing the password...)
 Also, I don't use CH341a (I use SVOD4 and before SVOD I used JTAG programming with RT809H) so I don't know if it supports JTAG programming...
 In conclusion, what I would do:
 1.- Write the 25Q80 with the original backup content
 2.- Write the 25Q128 with Thinkpad T470s-Type 20HG.bin
 3.- Write the MEC1653 with T470s_MEC1653.bin via JTAG (attached)
 If it's starts then patch the Thinkpad T470s-Type 20HG.bin file and follow the instructions.
 Write back your saved BIOS backup file or write back the Thinkpad T470s-Type 20HG.bin and make a BIOS update.
 Good Luck!Attached FilesLast edited by Stefan Steff; 09-13-2025, 09:33 AM.Comment
 Can you send a link to a decent one? I don't have a JTAG programmer. I have heard of it though, but I usually avoid it and use UART with my raspberry pis, since I've only ever used it for serial debugging/console.
 Good Luck!Comment
			by macabookHello everyone,
 🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
 I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
			by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
 Operating system and OS version.If...-
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
