Thanks for sharing.
I tried the file you shared,
I wrote it and verified it was written correctly.
It has the same problem as above: it beeps 5 times twice, the fans spin for a few seconds, and then shuts down. No signal.
rewriting my original, it goes back to how it was before with the password.Comment
Hello friends! I used autopatcher, rewrote the patched file in the bios, but as a result, when I press the power button, it blinks 3 times. Then nothing happens. Can someone help?
Laptop Lenovo P50
Type 20EQ
Serial MJ-04TPLTComment
STEP 1: Flash and replace current BIOS with the P50_Bios_2_PATCHED.bin file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original P50_Bios_1.bin BIOS content
STEP 9: Reset BIOS settings to factory default
Good luck!Attached FilesComment
Flashing both chips back to their original states doesn't even fix it, it no longer boots at all after trying the PXE driver injector method...
The 25Q80 chip is your PD controller SPI so must be untouched and write it back as is.
Write the content from the attachment and tell me if it works or not.
It's tested by me on several T470s laptops.Attached FilesComment
I flashed it just now, it still does the same thing. The keyboard and power button light up briefly then it shuts off. This happens once when power is plugged in, then it is unresponsive until unplugged and plugged back in once more.Comment
I see some differences between your PD Controller backup and what I have saved on my PC.
So here is mine to try.
Check for missing or damaged components near the BIOS chip.
If programming different versions of BIOS did not result in different behavior most likely you have a hardware issue...
After looking, I don't see any damaged connections or missing pieces, or any significant activity on thermal camera. However, I did just notice that once powered on, the fan continues to spin and stop, over and over like it's continuously trying and failing to boot. I've attached pictures of the rom chips, maybe I missed something.Comment
Yes I used SOIC8 clip with CH341a programmer. Didn't happen until I went through the bios unlock process listed on the lenovo autopatcher. It showed the usual PXE driver screen, turned off, I flashed the original like it said to, then it wouldn't turn on. I'll inspect the board.
As a last try ... here is the EC content.
I hope you can and know how to use JTAG to read/write the MEC1653. (You find plenty of examples here on badcaps how to prepare the MB and use the JTAG to read/write MEC chips...
An example: https://www.badcaps.net/forum/troubl...lock#post74632)
I don't know about the MEC1653 but the MEC1633 has an internal 2Kb EEPROM in witch is the password stored so if this is true for MEC1653 then rewriting the EC content may help to bring your laptop back to life.(without clearing the password...)
Also, I don't use CH341a (I use SVOD4 and before SVOD I used JTAG programming with RT809H) so I don't know if it supports JTAG programming...
In conclusion, what I would do:
1.- Write the 25Q80 with the original backup content
2.- Write the 25Q128 with Thinkpad T470s-Type 20HG.bin
3.- Write the MEC1653 with T470s_MEC1653.bin via JTAG (attached)
If it's starts then patch the Thinkpad T470s-Type 20HG.bin file and follow the instructions.
Write back your saved BIOS backup file or write back the Thinkpad T470s-Type 20HG.bin and make a BIOS update.
Good Luck!Attached FilesLast edited by Stefan Steff; 09-13-2025, 09:33 AM.Comment
It's very tricky to use clips...must be careful and check the reading/writing at least 2 or 3 times to be sure it's done correctly...
Good Luck!Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
