I've tried almost all the combinations and I still get the 0285 error with black screen, with/without hard drive, with/without holding the tamper switch, with/without the CMOS battery plugged in, the only thing I have not tried is removing the RAM. Does that matter? I also cleared the 1.2 TPM from the app and using Power Shell.Comment
Hey Y'all
I have an issue with my X280.
At "STEP 2: Boot the machine" i got no display, and I get beep code 0285 (TCG-compliant functionality related error / Might be TPM initialization failure).
If i re-flash my BIOS chip with the original unpatched BIOS, it boots normally.
Can anyone please help me with this issue?
Thanks.
Hardware Specifications |
Machine Type Model : Lenovo X280 20KE-SCMU00
System Unit S/N : PC-1AMPEC
BIOS Chip : 25Q128JVSQ winbondAttached FilesComment
Try with this method :
https://www.badcaps.net/forum/troubl...ss#post3237235
99% it will do the job if you're patientComment
lenovo thinkpad T14s patch file need please share if have
NM-D326 REV 2.0
issue : superviser password
Just want to say thank you to @Knucklegrumble for this patch. Managed to unlock my x270 bios after getting the patch to run. Amazing work!Comment
hello, this solution does not work on Lenovo e490 TP00094D, 20N9-S16L00 S/N PF-1PAA5L, NM-B911. After starting, nothing is displayed, a black screen and there is a sound as if the BIOS is damaged (TPM module fault). Do you have any idea?Attached FilesLast edited by MrBenn; 02-07-2025, 08:18 AM.Comment
Anyone get success with p72 ? gettin 3 beep and no boot after patch
tryin 3 timesAttached FilesLast edited by kattyg; 02-09-2025, 11:16 PM.Comment
Embdedded Controler Version N2CHT26W (1.16)
ME FIRMWARE 12.0.90.2072
Machine Type Number 20MCS27300
System Unit Serial number PF1RGGQP
System Board serial number L1HF93S0025
(ili tryin flash U9 MX25L25673G)
also get success with lot of p50 ant t480, but p72 stomped me ;0Comment
It's about CPU type, if your CPU is i7-8850H then the autopatcher wont work.
Try LPC method described here : https://www.badcaps.net/forum/troubl...ss#post3237235
Good luck!Comment
I do have ThinkPad P72 (20MB, 20MC) [32MB] in my list of compatible ThinkPad models, meaning that I had patched it myself and confirmed working. I usually patch the earliest BIOS version downloaded from Lenovo website using Serial Number, then I use this patched BIOS Region and replace it in the Original BIOS, doing it this way I virtually eliminated any possible beep codes on patched files. You may have to add some padding at the beginning of the BIOS extracted from BIOS update to match the size of BIOS Region in your Original BIOS.Comment
I am having an issue with the script, it always tells me that there's a dumping error.
I have dumped 4 times with power cycles in between and all the files are (MD5) the same, so i don't think its a bad dump.
Could anyone please check?
The model is a T10 Thinkpad TabletAttached FilesComment
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
