  • deggial
    • Aug 2022
    • 10
    Originally posted by deggial
    I was able to fix it, using another P50's patched file. It took a little bit time, and it restarted a few times, but eventually it did boot and I could remove the password.
    Thank you anyway.
    I am attaching the patched file that worked on my P50. Maybe helps for anyone. The patched file is from another P50, that I got way back. I wanted to give it a try on this one, and it worked.
    • bardiasm
      • Jan 2025
      • 8
      Originally posted by bratapita
      Have you removed the disk? Anti-theft switch pressed?​
      I've tried almost all the combinations and I still get the 0285 error with black screen, with/without hard drive, with/without holding the tamper switch, with/without the CMOS battery plugged in, the only thing I have not tried is removing the RAM. Does that matter? I also cleared the 1.2 TPM from the app and using Power Shell.
      • Kokofli
        • Jan 2024
        • 10
        • Greece
        #3643
        Hey Y'all
        I have an issue with my X280.
        At "STEP 2: Boot the machine" i got no display, and I get beep code 0285 (TCG-compliant functionality related error / Might be TPM initialization failure).
        If i re-flash my BIOS chip with the original unpatched BIOS, it boots normally.
        Can anyone please help me with this issue?
        Thanks.
        Hardware Specifications |
        Machine Type Model : Lenovo X280 20KE-SCMU00
        System Unit S/N : PC-1AMPEC
        BIOS Chip : 25Q128JVSQ winbond
        • Stefan Steff
          • Mar 2024
          • 274
          #3644
          If your CPU is i7-8650U then the patcher doesn't work...
          • Kokofli
            • Jan 2024
            • 10
            • Greece
            #3645
            Damn.... Didn't know that... thank you for info!
            • Stefan Steff
              • Mar 2024
              • 274
              #3646
              Try with this method :
              https://www.badcaps.net/forum/troubl...ss#post3237235
              99% it will do the job if you're patient
              • Kokofli
                • Jan 2024
                • 10
                • Greece
                #3647
                Will try and come back. Thank you!!!
                • kil0s
                  • Jan 2020
                  • Беларусь
                  #3648
                  Thank you very much, I revived my old Lenovo thinkpad x1 yoga 1gen on i7-6600u.
                  thanks again, everything worked out
                  • shivaraj m
                    • Jul 2024
                    • india
                    #3649
                    lenovo thinkpad T14s patch file need please share if have
                    NM-D326 REV 2.0
                    issue : superviser password
                    • nullldata
                      • Feb 2025
                      Trying this, thanks!
                      • Aphex00
                        • Feb 2025
                        Just want to say thank you to @Knucklegrumble​ for this patch. Managed to unlock my x270 bios after getting the patch to run. Amazing work!
                        • MrBenn
                          • Feb 2025
                          • PL
                          #3652
                          hello, this solution does not work on Lenovo e490 TP00094D, 20N9-S16L00 S/N PF-1PAA5L, NM-B911. After starting, nothing is displayed, a black screen and there is a sound as if the BIOS is damaged (TPM module fault). Do you have any idea?
                        • VegaByte
                          • Feb 2025
                          • España
                          #3653
                          Does the extraction and programming of the BIN file have to be done on the chip itself with a programmer? Or could it be done with some software?​
                          Thanks.
                          • bardiasm
                            • Jan 2025
                            • 8
                            It seems like the issue with black screen and error code 0285 is more common that I thought. Has anyone figure out a way how to get it to work? I'd really appreciate any help.
                            • vzgherea
                              • Sep 2018
                              • 16
                              The LPC approach worked for X1 Yoga 3rd Gen, Type 20LE (i7-8650U CPU). Thanks for the hint!
                              • kattyg
                                • Kazahstan
                                #3656
                                Anyone get success with p72 ? gettin 3 beep and no boot after patch
                                tryin 3 times
                              • kattyg
                                • Kazahstan
                                #3657
                                tryin 3 times
                                BIOS Version N2CET71W (1.54)
                                Embdedded Controler Version N2CHT26W (1.16)
                                ME FIRMWARE 12.0.90.2072
                                Machine Type Number 20MCS27300
                                System Unit Serial number PF1RGGQP
                                System Board serial number L1HF93S0025
                                (ili tryin flash U9 MX25L25673G)
                                also get success with lot of p50 ant t480, but p72 stomped me ;0
                                • Stefan Steff
                                  • Mar 2024
                                  • 274
                                  #3658
                                  tryin 3 times
                                  It's not about the model...
                                  It's about CPU type, if your CPU is i7-8850H then the autopatcher wont work.
                                  Try LPC method described here : https://www.badcaps.net/forum/troubl...ss#post3237235
                                  Good luck!
                                  • AAAC
                                    • Jan 2020
                                    • 458
                                    • Mexico
                                    #3659
                                    tryin 3 times
                                    I do have ThinkPad P72 (20MB, 20MC) [32MB]​ in my list of compatible ThinkPad models, meaning that I had patched it myself and confirmed working. I usually patch the earliest BIOS version downloaded from Lenovo website using Serial Number, then I use this patched BIOS Region and replace it in the Original BIOS, doing it this way I virtually eliminated any possible beep codes on patched files. You may have to add some padding at the beginning of the BIOS extracted from BIOS update to match the size of BIOS Region in your Original BIOS.
                                    • Paffo
                                      • May 2024
                                      • 29
                                      • Italy
                                      #3660
                                      I am having an issue with the script, it always tells me that there's a dumping error.
                                      I have dumped 4 times with power cycles in between and all the files are (MD5) the same, so i don't think its a bad dump.
                                      Could anyone please check?
                                      The model is a T10 Thinkpad Tablet
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
