HP Probook 640 G2 bios dump
  • cal3031
    • Nov 2020
    • 5
    • italy
    #41
    HP 640 G2 bios lost original dump
    I have a problem with my HP 640 g2, unfortunately I lost the original bios dump, I tried to flash some bios that I found on the forum but the only thing I got was the caps lock and num lock keys flashing, searching on the web I found that these indicate a "BIOS authentication failure" could someone help me? thanks
    • cal3031
      • Nov 2020
      • 5
      • italy
      #42
      Re: HP 640 G2 bios lost original dump
      So i found the original dump but the computer still does not turn on, I also need to remove the password
      • Mazorca
        • Jan 2017
        • 463
        Try this one, I replaced bios from website and cleaned ME, I don't know how to take out password, so let's hope that at least it will turn on.
        • cal3031
          • Nov 2020
          • 5
          • italy
          #44
          Thank you so much for your help, in the meantime I found this here that worked for me, I hope it can be useful for others too
          • saidbe
            • May 2017
            • 42
            • Chilo
            #45
            25q128fvsq not recognized 640 g2
            As RethoricalCheese recommended I use raspberry pi in combination with clip pomona. It works fast and stable. Only with HP 640 g2 with 25q128fvsq the chip is not recognized. I tried some laptops but without success. Can anyone there help me?
            • saidbe
              • May 2017
              • 42
              • Chilo
              #46
              Re: 25q128fvsq not recognized 640 g2
              any help?
                • 21922
                Originally posted by saidbe
                any help?
                Attach the clip then attach the charger,see if that helps
                • saidbe
                  • May 2017
                  • 42
                  • Chilo
                  #48
                  Re: HP Probook 640 G2 bios dump
                  thank you for your answer, but not recognition.
                  I put it on 650 g1/ folio / 6570b ect and it does work. With 640 g2 not working trying 5 laptops now.
                  Any suggestions are welcome!
                  • saidbe
                    • May 2017
                    • 42
                    • Chilo
                    #49
                    It works now ,
                    i had to work without any charger opposite of the other models.
                    but why? no idea
                    Thanks!
                    • sonsy
                      • Mar 2017
                      • 71
                      • Serbia
                      #50
                      Hello everyone. I have a problem with the bios on hp 650 g2 where some errors occurred during reading and a deletion of certain data from the bios, which worked before that, but was locked. With the original bios there is no picture,2 long, 2 short beeps, and with the bios from the link below it throws out the error when turning on "machine is in commited state". Thanks.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12330
                        #51
                        HP ProBook 650 G2 Base Model Notebook PC
                        • sonsy
                          • Mar 2017
                          • 71
                          • Serbia
                          #52
                          thanks. With this dump, laptop also turns on with red message machine boots in manufacturing programing mod.
                          • judamex
                            Active Member
                            • Jan 2021
                            • 186
                            • Mexico
                            #53
                            Work for me
                            • Bisketti
                              • Oct 2013
                              • 252
                              • Ireland
                              #54
                              how do I copy the dmi info from orig dump into working dump.
                              • hardware1
                                • Sep 2021
                                • 2948
                                • N/A
                                #55
                                Try this one. BTW if your original file problem is a password, you can unlock it with RCUlocker tool without using another file.
                                all donations are welcome,
                                • Bisketti
                                  • Oct 2013
                                  • 252
                                  • Ireland
                                  #56
                                  Thank you but has bios password present.
                                  • Bisketti
                                    • Oct 2013
                                    • 252
                                    • Ireland
                                    #57
                                    I ran this through Rculocker tool and am now getting machine not in a committed state , any quick fixes for this?
                                    • ymifdal
                                      • Jan 2022
                                      • 120
                                      • Morocco
                                      #58
                                      No quick I guess just do it the classic way
                                      https://www.badcaps.net/forum/showthread.php?t=69204
                                      • abdelilahocs
                                        • Nov 2018
                                        • 119
                                        • morroco
                                        #59
                                        bios extracted from good motherboard
                                        HP Probook 640 G2
                                        CIRCUS-65A272371-MB-A02
                                        • layad
                                          • Nov 2011
                                          • 244
                                          #60
                                          hp probook 640 g2 bios
                                          hi there
                                          the laptop is working with one of the files have downloaded from one post in this website but it gives red line saying that im on the manufacturing programing mode , is there anyway to fix it , couldint find dmi tool for this laptop, i attatched the original corrupted file if someone can help
                                          thanks
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • haitham sharabati
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            💀 Problem:😅
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
