Hello. I downloaded bios file from this thread, but i also get red message on boot. I couldn't find dmi tool, or nbdmifit which i can make as bootable device on the usb. Here is mine original, not working bios. Mine laptop is with i3 6th gen cpu. Can mine bin file be fixed?
HP Probook 640 G2 bios dump
post S/N, full name and model, motherboard model, product number,etc.Hello. I downloaded bios file from this thread, but i also get red message on boot. I couldn't find dmi tool, or nbdmifit which i can make as bootable device on the usb. Here is mine original, not working bios. Mine laptop is with i3 6th gen cpu. Can mine bin file be fixed?Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Sorry, i forgot to write it. It's like the other guys had in this thread. Message sayin that System boots in manufacterer mode and counts down every time laptop restarts. Probably missing or wrong DMI. But i couldn't find software where i can manually add information about my serial number etc.... So maybe fastest solution is to fix somehow mine original bios from this laptop.Comment
try...Sorry, i forgot to write it. It's like the other guys had in this thread. Message sayin that System boots in manufacterer mode and counts down every time laptop restarts. Probably missing or wrong DMI. But i couldn't find software where i can manually add information about my serial number etc.... So maybe fastest solution is to fix somehow mine original bios from this laptop.Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
I downloaded a theoretically working bios from this forum, there is a reaction because the keyboard lights up, the fan runs at full speed but there is still a problem because the screen is black. Could someone configure this file to my data? I would be very grateful.
640OK.zip
Device: HP ProBook 640 G2 / i5-6300U
MOTHERBOOARD: 6050a2723701-mb-a02
SERIAL NUMBER: 5CG8398WY7
The second file is my old corrupted bios after a bios update.
old bios corrupted after uptade - not working.rar
HP ProBook 640 G2 Base Model Notebook PCI downloaded a theoretically working bios from this forum, there is a reaction because the keyboard lights up, the fan runs at full speed but there is still a problem because the screen is black. Could someone configure this file to my data? I would be very grateful.
640OK.zip
https://www.badcaps.net/donateComment
I also tried that file Hoaca provided you. Mine laptop boot to the bios with it. Only thing is that again i have DMI problem. I don't know why you can't get the picture on your laptop.Comment
I made a progress. I fixed part with that missing DMI. I extract original DMI from broken dump file. Now i see it's on Norwegian language, and it is locked. Can somebody unlock this file, but to keep mine DMI infos?Attached FilesComment
UnlockedAttached Files↵
MODEL NO -- HP ProBook 640 G2
BOARD NO-- 6050A2723701-MB-A02
SERIAL NO - 5CG61041N2
PLZ REPAIR THIS BIOSAttached FilesComment
Try this one first. If it works then enable Fast startup in BIOS settings.Attached FilesComment
SORRY I FOUND SERIAL NUMBER
SN : QQ73B109VZ
CT: PFKCT00WB69310 REV : 1.20
MAC: 40B034F11801
thank you for helpAttached FilesComment
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
