HP Probook 640 G2 bios dump
  • INFONE aLONEX
    • 7
    • italy
    #121
    Hello everyone, first of all, I would like to thank those who will help me with this post. I need the BIOS dump for this PC model:
    HP 640 G2
    PRODUCT:T9X62ET#ABZ
    Circus-6050a2723701-mb-a02
    In some cases, ezflash tells me that the file is too large, around 16MB.
    BIOS code 25l12873f
    I am attaching a photo. Thank you again for your help.
    • peste
      peste commented
      Editing a comment
      post moved..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • INFONE aLONEX
    • 7
    • italy
    #122
    Good morning, I tried the various BIOSes here, but some won't let me start the PC, others show a black screen. I tried the original one again, but now it won't start. The original problem was to unlock the BIOS from the password. Here is the backup I made with EZP2023. I am also attaching the file and other information if it can be of help.
    HP PROBOOK 640 G2
    SERIAL: 5CG6243WMP
    PRODUCT: T9X62ET#ABZ
    • INFONE aLONEX
      • 7
      • italy
      #123
      HP PROBOOK 640 G2
      SERIAL: 5CG6243WMP
      For those who need it, I solved it with this BIOS.
      • killersoft
        • Apr 2017
        • 75
        • algeria
        #124
        I have a working dump that boots my laptop correctly, but I don’t have the original BIOS. Since this dump is not the original one, I would like to replace or edit the DMI information in it.
        HP PROBOOK 640 G2
        SERIAL: 5CG81930J0
        PRODUCT: 2TK78UC#ABA
        • killersoft
          • Apr 2017
          • 75
          • algeria
          #125
          HP PROBOOK 640 G2
          SERIAL: 5CG81930J0
          It seems no one can help me with this issue.
          • Aissa Chs
            • Feb 2025
            • 12
            • algeria
            #126
            hp probook 640 G2
            Need rebuild this bios .I have a problem with the LAN and I tried reprogramming the bios several times and it solved the LAN problem but I get a message "machine is not in committed state"
            SERIAL : 5CG62921HK
            PRODUCT : W8F40UP#ABL
            • volinakis
              • Jan 2021
              • 2874
              • N/A
              #127
              Originally posted by Aissa Chs
              hp probook 640 G2
              SERIAL : 5CG62921HK
              download sp143762 and update ME firmware.
              • Aissa Chs
                • Feb 2025
                • 12
                • algeria
                #128
                I tryed this the problem don't solve
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • haitham sharabati
                  by haitham sharabati
                  Hello engineers 😀,
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  💀 Problem:😅
                  08-07-2025, 04:54 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
