hp 840 g6 6050A3022501-MB-A01
  • mberbouch
    • May 2014
    • 109
    • Morocco
    #621
    Here's the second bios bin file attached, please anybody can help, thanks.
    • Stefan Steff
      • Mar 2024
      • 385
      • Romania
      #622
      Write this EC content (it's your content unlocked)
      • compuline
        • Jun 2023
        • 38
        • egypt
        #623
        hey guys
        I Wanna remove this messge "HP Sure Start detected a write access failure in the HP Endpoint Security Controller."
        I want to remove this message.
        M.B 6050A3022501-MB-A01
        this amin bios and ec bios
        • peste
          • Dec 2016
          • 13793
          • ROMANIA
          #624
          Originally posted by compuline
          hey guys
          post S/N, product number,etc.
          • Jdpaz
            • Aug 2022
            • 12
            • Philippines
            #625
            Hi need help with working bios for elitebook 840 g6. Power but no display.
            Attached is the 32mb dump. Serial: 5CG9123V1X
            • sheikhbaizid
              • Sep 2023
              • 17
              • bangladesh
              #626
              HP Elitebook 840 G6
              Problem.No power
              SN.5CG9528YQ0
              please rebuild.clean me and,end point security
              • shiyab
                • Sep 2023
                • 1671
                • india
                #627
                Originally posted by sheikhbaizid
                HP Elitebook 840 G6
                Problem.No power
                SN.5CG9528YQ0
                hi try
                • ssio187dd88
                  • Jan 2023
                  • 5
                  • Deutschland
                  #628
                  Hello, can someone help me with the admin lock on my 840 G6? Serial Number: 5CG025C26S ASSET TAG: KHC840G603321 It's an Intel Core i5-8th Gen processor.
                  • Stefan Steff
                    • Mar 2024
                    • 385
                    • Romania
                    #629
                    Write only the 16Mb chip...The other chip remains as is, put it back on MB.
                    • sheikhbaizid
                      • Sep 2023
                      • 17
                      • bangladesh
                      #630
                      HP Elitebook 840 G6
                      Serial/ 5CG9528YQ0
                      display touch not work
                      please help
                      • JAFATAGNA
                        • Apr 2016
                        • 59
                        • MARRAKECH
                        #631
                        I'm having issues with a 840 G6 N0 DYSPLAY
                        SN 5CG9401F08
                        please rebuild IT THANKS
                        • nasirahmad53
                          • Sep 2023
                          • 20
                          • Bangladesh
                          #632
                          HP EliteBook 840 G6
                          SN : 2TK9460NT6
                          CRESCENT 6050A3022501-MB-A01(A1)
                          Problem : No power after update bios
                          what can i do now?
                          please give me solution
                          • kros
                            • Oct 2017
                            • 18
                            • IE
                            #633
                            Originally posted by nasirahmad53
                            HP EliteBook 840 G6
                            SN : 2TK9460NT6
                            what can i do now?
                            Check this bios and let me know
                            • kros
                              • Oct 2017
                              • 18
                              • IE
                              #634
                              HP Elitebook 840 G6
                              Serial/ 5CG9528YQ0
                              please help
                              • salawayon
                                • Nov 2012
                                • 578
                                • philippines
                                #635
                                got one with no display issue:
                                HP EliteBook 840 G6
                                board: CRESCENT-6050A3022501-MB-A01(A1)
                                SN: 5CG034847Y
                                backup attached...
                                • Zillions Tech
                                  • Jul 2022
                                  • 28
                                  • Nigeria
                                  #636
                                  I have another problem with 840 g5
                                  When I received the system there's no sign of power when you press the power button, but when you plug the charger it will flash light on the LED and then off immediately, after checking all the power rails I didn't find any problem, so I decided to program the bios, after programming the main chip the LED light began to blink amber and white steady still no power, then I programmed the EC the system powered and display but there's end point security error message.
                                  I need an assistant to help me clean the original bin and the EC if it's possible i will attach the original bin here
                                  Hp EliteBook 840 G6
                                  S/N 2TK94401G1
                                  P/N 6050A3022501-MB-A01
                                • salawayon
                                  • Nov 2012
                                  • 578
                                  • philippines
                                  #637
                                  HP EliteBook 840 G6
                                  SN: 5CG034847Y
                                  backup attached...
                                  I already sorted out the issue... thank you..
                                  • tiagofernandes
                                    • Mar 2015
                                    • 13
                                    • portugal
                                    #638
                                    Please rebuild my bios original
                                    original bios computer not power on
                                    internet bios machine power on but post error HP Endepoint Security
                                    hp elitebook 840 g6
                                    prodid 4wg30av
                                    sn 5cg0218ff9
                                  • magneh
                                    • Apr 2014
                                    • 626
                                    • Portugal
                                    #639
                                    Hello guys
                                    I have this HP machine that shuts off when loading windows.
                                    Tested with another drive etc same thing
                                    Can someone assist and help rebuid bios with clean ME
                                    Backup of 32mb and 16mb here attached
                                    HP Elitebook 840 G6
                                    Serial Number: 5CG021C5X7
                                    PROD ID:4WG26AV
                                    Many thanks for the help
                                    • Zillions Tech
                                      • Jul 2022
                                      • 28
                                      • Nigeria
                                      #640
                                      Hp EliteBook 840 G6
                                      S/N 2TK94401G1
                                      this is error i get when i run script
                                        SMDFlea commented
                                        Editing a comment
                                        it is looking for bios which should be renamed endpoint.bin
