hp 840 g6 6050A3022501-MB-A01
  • volinakis
    • Jan 2021
    • 2872
    • N/A
    #581
    Originally posted by huzo
    I have a problem with dumps...i flashed a few dumps found here...32 and 16mb, i get caps lock always on and nothing else...Before the laptop would turn on but was extremly slow...Then i restored the orginal bios, and it's all the same ,only caps lock...
    your bios backup was faulty, that's why is recommended to read chipset 2-3 times and compare results, if you have 2 backups identical it means you have a good backup. Writing other files from another laptops requires at least to perform a clean_ME and transfer DMI, win key, MAC adress, etc.
    • yev2021
      • Jan 2022
      • 13
      • ukraine
      #582
      help me remove bios password
      laptop hp probook 840 g6
      BOARD 6050A3022501-MB-A01
      SN 2ТК9460Н9С​
      • hoaca388
        Badcaps
        • Jan 2022
        • 12257
        #583
        SN 2ТК9460Н9С​
        Unlocked
        • yev2021
          • Jan 2022
          • 13
          • ukraine
          #584
          Originally posted by hoaca388
          Unlocked
          no ctart
          • LEVSKI14
            • Mar 2025
            Hi can someone help me with my laptop please? I read and try over one week all posts here but nothing. I tried with the script to fix the backup bin file but just some error in Line 11 Error code 1. Elitebook 840G G6
            Details:
            HP EliteBook 840 G6 Notebook PC
            Serial number
            5CG9529Q3Z
            Product number
            6XD49EA#ABU​
            And some idea for util to put back the fixed bios.
            Thanks in advance!
            • hoaca388
              Badcaps
              • Jan 2022
              • 12257
              #586
              Details:
              Serial number
              5CG9529Q3Z
              Product number
              6XD49EA#ABU​
              Thanks in advance!
              What did you use to extract your bios ? Your original file is only half.
              • LEVSKI14
                • Mar 2025
                So i use from HP download site old util, because this one for this model don`t have option for backup file. Only update bios and create butable usb. But i think for the half, problem coming from last attempt to update the bios. when instalation finish under windows, to be completed continue after restart. But then coming the problem. I see only error message for ENDPOINT problem, and auto restart, and again error message and next restart to infinity. After remove power and battery and cmos battery, i see only endpoint error and windows load normal. If that what you attach for me is correct BIN file, can you recommend me some util or tool to flash the bios please?
                Thank you Hoaca
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12257
                  #588
                  Thank you Hoaca
                  We should only use a programmer (a hardware device) to extract the bios from the SPI chip, other software (if any) can only extract the Bios region (half).
                  https://www.badcaps.net/forum/troubl...rces-and-tools
                  • yev2021
                    • Jan 2022
                    • 13
                    • ukraine
                    #589
                    help me unlock bios hp elitebook 840 G6 motherboard 6050A3022501-MB-A01 serial number 2TK9460N9S in archive 2 files 16mb 32MB​
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12257
                      #590
                      Originally posted by faisalhabib
                      PLEASE HELP ANY BODY
                      HP ZBOOK 14U G6 laptop no display problem,
                      s/n: 5CG94032GR
                      Please post in the correct topic. This is a topic for HP 840 G6 .
                        • 21641
                        Try using RCUnlocker software -> https://www.badcaps.net/forum/troubl...23#post1622423
                        • huzo
                          • Sep 2014
                          • 185
                          • CROATIA
                          #592
                          Guys i have a few of these laptops , i 've tried to flash three of them already and i only get caps lock on,and nothing else...the original dump had the power button on and keyboard light ,and i tried few dumps found here and none work, only caps lock on and nothing else... here are the two dumps from the latest board if someone could do the magic?
                          S/N DI68CB21DRF (this is on the sticker by the ram, i don't have the bottom cover by me to see the S/N)
                          model 840 G6
                          Board number 6050A3022501-MB-A01
                          • peste
                            • 13370
                            • ROMANIA
                            #593
                            post S/N, full name and model, motherboard model, product number,etc.
                            read the forum rules..
                            https://www.badcaps.net/forum/troubl...ore-posting​
                            • dqtech
                              Badcaps
                              • Jul 2018
                              • 633
                              • N/A
                              #594
                              Originally posted by peste
                              Re: HP 840 G6 Bios Password
                              And from me..try ..
                              this file working
                              • huzo
                                • Sep 2014
                                • 185
                                • CROATIA
                                #595
                                Can someone check mine dumps two posts prior? When i flash peste's dumps i get caps only...
                                • huzo
                                  • Sep 2014
                                  • 185
                                  • CROATIA
                                  #596
                                  model 840 G6
                                  Please anyone?
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12257
                                    #597
                                    Please anyone?
                                    I see a serial number in your dump file, 5CG8515SSC, it is of HP EliteBook 840 G5 Notebook PC.​
                                    • huzo
                                      • Sep 2014
                                      • 185
                                      • CROATIA
                                      #598
                                      OMG...But it's the 8th gen. it should be G6....That explains it why it deosn't work...Tnx alot!
                                      • pronto
                                        • Mar 2019
                                        • 120
                                        • morocco
                                        #599
                                        HI INEED BIN OF HP ELITEBOOK 840 G6 JUST EC
                                        PROD ID 8TJ27UC#ABA
                                        SN/5CG0204HP7
                                        • kingkong computers
                                          • Sep 2018
                                          • 210
                                          • pakistan
                                          #600
                                          remove password
                                          hp 850 g6
                                          BOARD NO 6050A3022501
                                          sn 5CG95184Z6
