hp 840 g6 6050A3022501-MB-A01
  • danito
    • Jun 2016
    • 1246
    #561
    Originally posted by bert-bert
    I have an EliteBook 840 G6. It had a bios password. Then I tried to read the 32MB BIOS chip, but thereby destroyed the content of this chip.
    In the meantime I have unsoldered 32MB and 16MB chip and tried to flash contents available here in the forum, but I did not succeed. The best that had happened was that I had a working laptop, but as soon as I restored the BIOS to factory default configuration the laptop died and never turned on again.
    I upload the defective 32MB BIOS and the 16MB chip content with password here.
    Would someone mind helping here?
    Thank you in advance!
    ProdID: 7KN34EA#ABD
    SN#: 5CG024BH8H
    try
    • bert-bert
      • Oct 2024
      • 25
      • Austria
      #562
      Originally posted by danito
      try
      Hey, this is great! A clean BIOS where I can enter the information with the Bios Config Utility!
      I now flashed the BIOS, and it boots. Then I entered the information in the Bios Config Utility, but somehow the MAC Address cannot be set. It always stayed at 00-04-80-00-40-00 in the BIOS. Probably because of a defective ME configuration this configuration was not possible. Dumb me, I locked the Manufacturer Programming Mode even though the MAC address does not match. When locking the MPM I entered the MAC Adress in the BIOS so the locking was possible. But on the Information page there is still not a valid MAC address. After locking MPM, I could fix the ME by performing a BIOS update.
      But now the LAN port does not work. What can I do? Is there a possibility to unlock MPM again, without having to reprogram both chips? Is the non-working LAN port even caused by a wrong configuration or is this an other error? Is it possible to do this with reprogramming only one chip? Shall I send the content of the 32MB Chip? Will this help?
      Will cleaning the VSS2 unlock MPM and help here?
      danito, thanks a ton, and for any further help, thank you in advance!
      • Duvelhedz
        • Oct 2015
        • 20
        #563
        Looking to unlock mine and remove a "startup delay" if possible.
        Attached are both dumps.
        Thanks in advance :-)
        • LBTT1121
          • Nov 2024
          • 1235
          • Việt Nam
          #564
          post S/N
          • Duvelhedz
            • Oct 2015
            • 20
            #565
            Originally posted by LBTT1121
            post S/N
            5CG952962K
            • bert-bert
              • Oct 2024
              • 25
              • Austria
              #566
              in the meantime I tried to clear VSS2, but the laptop did not boot any more then.
              So I reflashed "New folder (2).rar" in 32MB and 16MB chip and now I am again in MPM, but the LAN Port does not work. I get an error in device manager for the Ethernet controller and cannot set the right MAC address in the BCU or in the BIOS.
              Does someone have a clue how to make the ethernet LAN port work?
              • hoaca388
                Badcaps
                • Jan 2022
                • 12433
                #567
                MAC : BC:E9:2F:E6:CA:B0
                • bert-bert
                  • Oct 2024
                  • 25
                  • Austria
                  #568
                  Hey, this is great! Even though I had to flash the 32MB chip twice, probably because my soldering skills are not good enough, now it works perfectly! I did not need BCU nor MPM, it just boots with the correct information, even though it told me once that it has to recover the data because of a mismatch.
                  hoaca388, you are the best, thanks a lot, and also thank you again danito for trying to help!
                  Would you mind me asking how you produced these files? Have you handcrafted them in a hex editor, or do you have a tool for that?
                  • alechs85
                    • Jul 2024
                    • Chisinau
                    #569
                    Hello.
                    HP EliteBook 840 G6 (14-in) Touch Laptop (HSN-I24C-4)
                    Please remove the password from the BIOS
                    serial number SCG0159CZF.
                    Read MX25L25635E, W25Q128BV.​
                      • 22241
                      Originally posted by alechs85
                      Hello.
                      Read the password guide, try RCUnlocker - https://www.badcaps.net/forum/troubl...23#post1622423
                      • babyboo092
                        buzz
                        • Jul 2023
                        • 14
                        • Uganda
                        #571
                        Hello there, I hope someone can help me with my dead BIOS that failed to start after an update. the machine does not power on even after pressing the power button . thank you!
                        sn.2TK9500RN6
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12433
                          #572
                          sn.2TK9500RN6
                          HP EliteBook 840 G6 Notebook PC
                          • babyboo092
                            buzz
                            • Jul 2023
                            • 14
                            • Uganda
                            #573
                            Thank you very much , this file worked fine for me, I apreciate
                            • mdronykhan125
                              • Jan 2019
                              • Bangladesh
                              #574
                              Pls Help me hp endpoint security controller problem+let disply
                              Motherbord Part num- CRESCENT-6050A3022501-Mb-A01(A1)
                              Hp elitebook 840 G6
                              Prodid- 7KK40UT#ABA
                              SN# 5CG0094CKF
                            • stars-n-dust
                              • Apr 2019
                              • 59
                              board: 6050A3022501
                              sn: 5cg9213jys
                              laptop lost the power during the BIOS update and now is giving two long and two short beeps, not powering on.
                              please fix the firmware.
                              • hichamhb
                                • Jun 2019
                                • 94
                                • morocco
                                #576
                                hi everyone
                                Model: Elitebook 840 G6
                                sn : 5CG93577R8
                                Board Number : CRESCENT - 6050A3022501-MB-A01 (A1)
                                Request: bios repair
                                Issue: ram not detected after bios update​
                                  SMDFlea commented
                                  Editing a comment
                                  Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                              • yev2021
                                • Jan 2022
                                • 13
                                • ukraine
                                #577
                                help remove password from bios board 6050A3022501 model hp probook 840 g6​
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12433
                                  #578
                                  Originally posted by hichamhb
                                  hi everyone
                                  sn : 5CG93577R8
                                  Try
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12433
                                    #579
                                    Serial number ?
                                    • huzo
                                      • Sep 2014
                                      • 190
                                      • CROATIA
                                      #580
                                      I have a problem with dumps...i flashed a few dumps found here...32 and 16mb, i get caps lock always on and nothing else...Before the laptop would turn on but was extremly slow...Then i restored the orginal bios, and it's all the same ,only caps lock...
