How to extract and edit a Lenovo Phoenix TDK Bios
  • EpicFix
    • Aug 2024
    • 43
    • Trinidad & Tobago
    #41
    Hi guys, will anyone be able to check this file to see if I did it correctly.....also can anyone guide me on how to disable the on-board RAM via the bios for Lenovo 15ADA05 laptop
      • 22085
      Yes it`s ok you did a good job. Try the patcher to disable ram, don`t know if it will work on this model or not - https://www.badcaps.net/forum/troubl...20#post3232220
      • ordinateur
        • Mar 2020
        • 85
        • Monaco
        #43
        Maybe the packer of my BIOS for Lenovo V15 G3 IAP is different (not TDK) because when I unpacked it I am just getting .FD file which is 24 MB in size. After unpacking .FD file further with CLI extractor I got a bunch of files and folders like:
        0 Descriptor region,
        1 Padding,
        2 Boot partition ,
        3 Data partition,
        4 Boot partition and inside those folders there are a plenty of small body.bin files. So I am not getting only one .BIN file which should be 16MB in size to further flash it via RT809, all those files and folders properties are less than 10 MB
          • 22085
          1 Padding,
          2 Boot partition ,
          3 Data partition,
          It isn`t a phoenix TDK bios, it`s Insyde. Search for the word BIOSIMG in the FD file, the line just below that is the start offset at 1E6BB0. Select block, the start offset as 1E6BB0, 800000 as the length (800000 is 8MB) ,copy that to a new file. The line below that 8MB offset is the start of the 16MB bios, set the first offset, enter 1000000 as length ,copy to a new file , you now have the 8 & 16MB virgin bios.
          • ordinateur
            • Mar 2020
            • 85
            • Monaco
            #45
            Thanks so much wizard. Seems I am so near in my making my first BIOS extracted from a hidden Lenovo .EXE.
            From the screenshot uploaded on Imgur seems everything is OK?
            Click image for larger version  Name:	pQQ2il6.png Views:	0 Size:	85.6 KB ID:	3653510
            So when I create these 2 new files then I need to also take the DMI infos from the DUMP of my laptop and write only to the 16MB file at addresses:
            DMI 42000 - 43FFF
            and write that file to the chip?
            do I need to make any modification to the 8MB BIOS or write it as such Virgin as extracted from Lenovo .FD file, or it can be bypassed fully and not written at all?
            Thanks once again
              SMDFlea commented
              Editing a comment
              enter 800000 as the length, not the end offset.
          • ordinateur
            • Mar 2020
            • 85
            • Monaco
            #46
            Yes done now, I compare the start and the end and of these files that I am extracting from Lenovo .FD file and the dumps from the laptop and they are so identical, I just need to insert DMI infos to the 16MB file and try burning the file to the chip afterwards
            thanks
            • m1ch43lzm
              • Mar 2019
              • 1022
              • Peru
              #47
              Easier method:
              Extract the downloaded .exe from Lenovo website with innoextract
              https://github.com/dscharrer/innoextract
              If you only have the first .exe and nothing else (like the BIOS on 1st post), follow the step on 1st post to extract it
              Code:
              5PCN20WW.exe /ext
              Note: On newer BIOSes you'll get to the bios.cap after extracting with innoextract
              Once you get to the bios.cap, open it with UEFITool NE A72
              https://github.com/LongSoft/UEFITool/releases
              Expand the UEFI capsule -> UEFI image -> (GUID) => (another GUID)
              You'll see something like this:
              Click image for larger version  Name:	lenovo phoenixtdk uefitool.png Views:	0 Size:	63.1 KB ID:	3733752
              Notice the Body size section, it should be the same size as the BIOS region (for Intel, open the BIOS dump with UEFITool), or the dumped BIOS from the chip (for AMD)
              Right click on the second GUID (pictured above for reference) -> Extract body, you'll have your BIOS region* (Intel), or the full BIOS ready to flash (AMD), DMI can be added to it later
              * On Intel platforms, use UEFITool 0.28 to replace BIOS region on the BIOS dump from flash chip, regular procedure for cleaning ME region applies (if needed)
              • duder
                • Oct 2013
                • 41
                • canada
                #48
                I just unpacked an Insyde bios with innoextract and got a 24MB bin file instead of an fd file. Do I use the same procedure? I can see the word BIOSIMG in the file.
                • m1ch43lzm
                  • Mar 2019
                  • 1022
                  • Peru
                  #49
                  For insyde use BIOSUtilities from platomav https://github.com/platomav/BIOSUtilities , requires some setup, you feed it the Insyde .exe (sometimes downloaded from Lenovo, sometimes you have to use innoextract first)
                  Or one of those 2 Insyde extractors to extract the .fd file https://github.com/vaginessa/InsydeH2O-extractor-2
                  https://github.com/LongSoft/InsydeIm...actor/releases
                  If you get a 24MB file (exactly 25,165,824 bytes), the BIOS may need to be split into 8MB + 16MB, the motherboard has 2 BIOS chips close together in this case
                  Open the 24MB file with UEFITool NE, then if it's a Intel Image with Descriptor, ME and BIOS regions it may need to be split, the first part from 0-7FFFFF, the rest from 800000-17FFFFF is the second part
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • survivalbloke
                    Unable to extract bios file from Lenovo bios exectuable
                    by survivalbloke
                    I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                    Code:
                    "innoextract 7wcn38ww.exe"
                    it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                    The trouble I'm having is that I'm not getting the newly...
                    06-12-2024, 07:55 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                  • lucaszmn
                    by lucaszmn
                    Problem:
                    Initial Findings:
                    • I concluded that the
                    08-12-2025, 03:01 PM
