EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
  • mferna14
    • Jun 2018
    • 1026
    Re: EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
    People please guide @ ViLex to the correct thread, this thread is ONLY for BIOS, kindly re-guide him to a software thread where he will get the help... Thanks
    • ViLex
      • Dec 2022
      • 6
      • Russia
      #102
      Don't cry, I'll leave myself. Thanks
      • burkancho
        • Feb 2016
        • 12
        • bulgaria
        #103
        hello friends, can someone give me original bios without a serial number and without a password?
        • burkancho
          • Feb 2016
          • 12
          • bulgaria
          #104
          I use Ufix U-bos2 but he puts the same serial number on all of this model. Even with a USB stick it is not possible to change the serial number because it is already recorded by the programmer.Can some one helps please
            • 20977
            It can be changed using a hex editor and UEFITool
            https://www.badcaps.net/forum/showpo...43&postcount=5
            4.3. Apple
            For 2017 and older machines, serial number is stored in Fsys store of BIOS and can be edited with hexadecimal editor. Fsys checksum needs to be fixed afterwards
            Search for "ssn", edit the serial number, save, open dump in UEFITool, go to the Fsys store and write down the suggested checksum in the panel on the right. Checksum is 4 bytes at the end of the Fsys store, between one zone of 0x00 either Gaid or another zone of 0xFF, it must be written in reverse order (so last 2 characters from UEFITool must be written first).
            See: https://www.youtube.com/watch?v=poA8HByYqTM
            Alternatively try Apple-UEFI-Patcher
            https://github.com/sadponyguerillaboy
            • peste
              • Dec 2016
              • 12859
              • ROMANIA
              #106
              post the original bios, EMC, full name and model of the laptop, motherboard number, serial number S/N..
              • burkancho
                • Feb 2016
                • 12
                • bulgaria
                #107
                I don't have the original one on the laptop, I have the one that puts u-bos2.The bord is 820-3437-B A1466 EMC2632 the programmer automatically deletes the old one without backing it up and overwrites it with the same serial number
                • burkancho
                  • Feb 2016
                  • 12
                  • bulgaria
                  #108
                  This is the file with which the programmer flashes the bios with the same serial number
                  • peste
                    • Dec 2016
                    • 12859
                    • ROMANIA
                    #109
                    also post the S/N...that the laptop must have....
                    • burkancho
                      • Feb 2016
                      • 12
                      • bulgaria
                      #110
                      I have too many different models locked and I want to resolve this case without having someone overwrite serial numbers for me.
                      When I use the USB stick on the U-BOS2 to overwrite the serial number it gives me a message -A serial number was detected. Blank Board Serializer (BBS)can only run on machines with blank serial numbers.The serial number that U-BOS2 records for board 820-3437 is this C02LNKBUF5V7
                        • 20977
                        You could try filling the serial number with FF`s or 0`s ,if changing only the serial doesn`t work fill the checksum as well.I never tried it,so not sure if it will work or not.
                        • burkancho
                          • Feb 2016
                          • 12
                          • bulgaria
                          #112
                          YESSS Thanks I got it After removing the password with U-bos2, I have to manually change the serial number with a hex editor and UEFIToll_NE_ALPHA_64
                          • peste
                            • Dec 2016
                            • 12859
                            • ROMANIA
                            #113
                            tri this..
                            • Gobbla
                              • Mar 2015
                              • 27
                              • United Kingdom
                              #114
                              hello everyone
                              sorry foe silly question but I used for long time ezp2019 programmer but looks like its not reading a1466 bios chip + they are cheap and clips always broke quite quickly.
                              And my question is what other better programmer I could use ?
                              As I feel its time to invest in something better
                              thanks and have good day everyone !!!
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #115
                                Originally posted by Gobbla
                                hello everyone
                                https://www.badcaps.net/forum/showpo...40&postcount=2
                                Become a Badcaps supporter
                                Thanks to all supporters.​
                                • rasta24
                                  • Feb 2022
                                  • 23
                                  • México
                                  #116
                                  can someone help me remove efi password please
                                  • peste
                                    • Dec 2016
                                    • 12859
                                    • ROMANIA
                                    #117
                                    try..
                                    • bibi019
                                      • Jun 2014
                                      • 57
                                      • algeria
                                      #118
                                      i have one macbook air a1466 emc 2632 year 2013 with efi lock
                                      i read the bios ship with rt809h tool and modified the file with winhex but
                                      now the mac some times power on and some time not power on and the lock still
                                      can some one modified my file
                                      • alfredposadas09
                                        • Aug 2020
                                        • 343
                                        • Philippines
                                        #119
                                        here is your unlocked file
                                        • bibi019
                                          • Jun 2014
                                          • 57
                                          • algeria
                                          #120
                                          not working the mackbook still locked with 4 digi pin efi
                                          any help
                                          • psdavid65
                                            Macbook Air A1466 820-3437-B Booting Problem
                                            by psdavid65
                                            I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                                            06-20-2024, 12:27 AM
                                          • echothegamer
                                            Macbook A1466 dies when charger disconnected
                                            by echothegamer
                                            Hello all,
                                            Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                                            Details:
                                            Macbook 13' A1466
                                            Board (820-3209-A)
                                            Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                                            Pictures below of Boardview and schematic...
                                            I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                                            It's an older model and it is very likely that battery has become...
                                            10-28-2023, 12:00 PM
                                          • mon2
                                            A1466 Macbook Air (Liquid damage repair)
                                            by mon2
                                            Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                            Macbook AIR Model A1466 Diagnostic 09-01-2021
                                            Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                            Problems & Resolutions
                                            1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                            09-01-2021, 09:31 AM
                                          • sidthesloth
                                            NEED HELP WITH MACBOOK AIR BIOS A1466 820-00165A
                                            by sidthesloth
                                            I HAVE A MACBOOK AIR A1466 820-00165-A THAT IS BIOS LOCKED I WAS ABLE TO DUMP THYE ORIGNAL TO UNLOCK IT AND ION THS PRFOCESS MY CAT GOT ON MY KEYBOARD AND WAS ABLKE TO ERASE THE CHIP ASND THE FILES I HAD SO IM STUMPED. I HAVE A COUPLE BIOS THAT IVE DOWNLOADED AND CHANGED THE SSN BUT WE
                                            HEN I FLASH THEM TO CHIP AND TRY TO BOOT THE MACBOOK NO FAN DISPSPLAY. BUT IT STILL CHARGES AND IF I PUT MY USB VOLT METER SHOW 5V AT USB WHENJ I POWER IT ON. IM STUMPED..
                                            11-21-2023, 02:51 AM
                                          • sidthesloth
                                            by sidthesloth
