EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
hi all
i need unlock this efi files for macbook air a1466
Attached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
try..Attached FilesPremium supporters get full download access and other benefits.
S/N C02N34GMG086
I lost my old bios region and tried all bios but the ssd won't boot in any biosAttached FilesPremium supporters get full download access and other benefits.
hi please can someone help me with this '
Device: Laptop
Brand: Apple
Model: Macbook A1466 emc 2632
Board number: 820-3437-a
Request: ME Cleaning, repairAttached FilesPremium supporters get full download access and other benefits.
hi there all techs
bios attached , from macbook 820-00165-A
some idiot flashed bios laptop works but serial info wrong require assistance in changing please
MacBook pro
model A1466
EMC 3178
serial C1MTQ9RKJ1WK
14.85V 3.05A max
MacBook Air "Core i5" 1.8 13" (2017) 1.8 GHz Core i5 (I5-5350U)
also what software is required for next time please
thanks in advance
god bless
hi can you remove efi pleaseAttached FilesPremium supporters get full download access and other benefits.
Try thisAttached FilesPremium supporters get full download access and other benefits.
someone help me please remove efi password
Model - A1466
Boardcode - 820-3437-a
emc -2925
serial - C1MRM7PYH3QDAttached FilesPremium supporters get full download access and other benefits.
TryAttached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
RetryAttached FilesPremium supporters get full download access and other benefits.
by BrahemHello, I need an SCBO file to unlock the EFI password for my MacBook Pro A1398 (Late 2012).
Hash Code: C02234500UDDY3VAWC062AEC3D227D99D
Battery Model: A1417
Please help me generate the unlock file. Thank you!...-
Channel: BIOS Requests ONLY!
by psdavid65I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by veedoHi
I have a MacBook Air that was completely dead on arrival. During inspection I found a shorted capacitor near the SMC, which appeared to be the main fault. After replacing the capacitor, the short on the rail was cleared. The board then started recognizing the charger, charging normally, and the machine powered on. Initial testing outside the chassis showed normal behaviour.
However, after full reassembly a new issue appeared. There is no boot chime and no image on the screen, only the fan spins. The power button responds normally, it powers on without the charger connected... -
by echothegamerHello all,
Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
Details:
Macbook 13' A1466
Board (820-3209-A)
Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
Pictures below of Boardview and schematic...
I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
It's an older model and it is very likely that battery has become... - Loading...
