EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
  • mferna14
    • Jun 2018
    • 1046
    Hi all, I need the CLEAN original EFI BIN File for the MacBook Air A1466 (EMC 2632) 820-3437-B ... Thanks in advance
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
    Better post your original dump and tell what the issue is with it.
    • mferna14
      • Jun 2018
      • 1046
      Thanks., Cannot even read the BIOS Chip., its totally dead & in the BIOS Writer/reader it say no chip detected (NO CHIP FOUND). tried other chips & all works fine on this reader.
      • piernov
        • Jan 2016
        • 4439
        • France
        Serial number has to be edited and Fsys checksum corrected accordingly.
        • mferna14
          • Jun 2018
          • 1046
          Thank you very much... This is the first time I am going to program this BIOS. Just to verify & ask you that Serial number has to be edited and Fsys checksum in the HEX Editor?
            • 22012
            Yes it does. check this useful youtube video https://www.youtube.com/watch?v=poA8HByYqTM
            • mferna14
              • Jun 2018
              • 1046
              Very good knowledge youtube video for me & other too. Thank you very much
              • mferna14
                • Jun 2018
                • 1046
                Very helpful & great youtube video presentation. Appreciate & thank you very much for making me understand....
                • Mapiro
                  • Italy
                  Hi, I'm new on the forum.
                  Me too I'm fighting with MacBook Air Early 2014 bricked by Catalina upgrade (screen totally black, key combinations do not work).
                  I bought CH431A programmer and I build my own connector (very micro-solding challenge).
                  @mferna14
                  Did you try doing as https://youtu.be/Y7l6X51LQk4?t=124 ?
                  With this trick I'm able to detect the chip.
                  @piernov
                  I downloaded the firmware you posted (thanks for that).
                  Code:
                  strings 820-3437-10.15-clean.bin | grep EFI
                   EFI Version: 117.0.0.0.0
                  Here
                  https://eclecticlight.co/2019/10/08/...ing-version-4/
                  i read that the Catalina firmware should be 118.0.0.0.0 and here
                  https://eclecticlight.co/2018/10/31/...ing-version-3/
                  i read that 117.0.0.0.0 should be the last Mojave firmware.
                  Could you confirm that the binary you posted is from a working full-updated Catalina system?
                  I have also other questions for you, in order to solve my problem. Do I have to open new thread or I can continue on this one?
                  Thankyou,
                  Mapiro
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    A yeah it was from a Catalina beta, dated from the 11 august 2019 on my end, so it may not be the latest version, however it has APFS support at least. But it's from a working system.
                    You can at least flash it and try again the upgrade to Catalina, it's not supposed to fail every time.
                    If your issue is not related to EFI/BIOS then yes please open another thread (outside the BIOS section).
                    • Mapiro
                      • Italy
                      Thankyou piernov.
                      (BTW: I really liked your mac-videos on YouTube, after seeing them I searched for your contact to to ask you some questions, without success. By chance, I found you in this forum! ).
                      My CH341A detects the EFI chip only if I do as in the video I posted: internal battery disconnected, external power connected and then PC powered down by pressing power button.
                      This way I can read EFI more times, getting identical dumps, until I unplug the external power.
                      If I unplug and replug the external power, power off the mac pressing power button and finally try to read again the EFI, I get a EFI dump that is different from previous. The differences are not single sparse byptes, they seem to be in blocks. It seems that the differeces are around 1% of tytes.
                      Next reads are always identical.
                      1)
                      Is it normal? Each dump I have could be considered a "good" backup (ignoring the fact that the current firmware is bricked)?
                      2)
                      Could the EFI be in a infinite loop of attempts to complete a faulty internal-update-procedure ? (the mac died during Catalina update).
                      Mapiro
                      • Mapiro
                        • Italy
                        • FW downloaded
                        • Serial changed
                        • Flashing...
                        • Power reset -> Mac back to life!
                        • Reinstall -> Catalina update -> All is fine!
                        The "not last version" of the wirmware was an unexpected benefit because now I can see that Catalina updated again the firmware with the very-last release (118)
                        Thankyou very much for the support.
                        Mapiro
                        • Perovski
                          • Jul 2016
                          • 16
                          • Tunis
                          hi gays who can clear me this bin for macbookair 820-3437-A
                          • peste
                            • 13678
                            • ROMANIA
                            try..
                            • Perovski
                              • Jul 2016
                              • 16
                              • Tunis
                              thinks pest for your help ui test and reply
                              • elbtonet
                                • Nov 2019
                                • 106
                                • albania
                                Hi friend I have my macbook air dump bios bin file ..it starts but no display
                                i think is a bios issue please can u help me if there is a problem with the dump??
                                • peste
                                  • 13678
                                  • ROMANIA
                                  the posted bios is not ok ... try this ..
                                  • Perovski
                                    • Jul 2016
                                    • 16
                                    • Tunis
                                    hi pest i pupload your dump and now dead machine thinks any way have you other solution
                                    • peste
                                      • 13678
                                      • ROMANIA
                                      try post # 4 ..
                                      • alterr333
                                        • May 2019
                                        • 44
                                        • México
                                        Done that and got my mac back on track!
                                        Thanks mate! you've made a new suscriber to your chanel
