Macbook Air A1466 820-3437-B Booting Problem
  • psdavid65
    • Dec 2021
    • 32
    • Ghana
    I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?
  • reformatt
    • Feb 2020
    • 1693
    Where did you source the donor BIOS from? Use the Mac EFI toolkit on your BIOS to find out version number, APFS support etc. Latest version for this board is 478.0.0.0. You can use this tool to clear the NVRAM stores too rather than doing a PRAM reset via the keyboard.
    Don't bother using Internet recovery on these old machines. Just create a USB installer of Big Sur (that is the last official build supported on that board). If what you are using isn't APFS enabled, you must format the SSD as MAC OS Extended in Disk Utility. The installer should update the BIOS to current version and then convert the volume to APFS.
    https://www.badcaps.net/forum/troubl...ac-efi-toolkit
    • psdavid65
      • Dec 2021
      • 32
      • Ghana
      Got this to work by serializing the bios. Everything works well now
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • cr4zychriss
        by cr4zychriss
        • Rebrand: PC Specialist
        11-14-2025, 04:04 PM
      • TopPop
        Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
        by TopPop
        Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
        I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
        12-14-2025, 09:40 PM
      • sidthesloth
        NEED HELP WITH MACBOOK AIR BIOS A1466 820-00165A
        by sidthesloth
        I HAVE A MACBOOK AIR A1466 820-00165-A THAT IS BIOS LOCKED I WAS ABLE TO DUMP THYE ORIGNAL TO UNLOCK IT AND ION THS PRFOCESS MY CAT GOT ON MY KEYBOARD AND WAS ABLKE TO ERASE THE CHIP ASND THE FILES I HAD SO IM STUMPED. I HAVE A COUPLE BIOS THAT IVE DOWNLOADED AND CHANGED THE SSN BUT WE
        HEN I FLASH THEM TO CHIP AND TRY TO BOOT THE MACBOOK NO FAN DISPSPLAY. BUT IT STILL CHARGES AND IF I PUT MY USB VOLT METER SHOW 5V AT USB WHENJ I POWER IT ON. IM STUMPED..
        11-21-2023, 02:51 AM
      • sidthesloth
        by sidthesloth
