I need the HP zbook 17 g5 DUMP BIOS, thank you.
  • jontao
    • Jun 2019
    • 16
    • China
    I have an HP laptop, zbook 17 g5, I need an original programmer BIOS firmware, I have a friend to share, thank you very much.
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: I need the HP zbook 17 g5 DUMP BIOS, thank you.
    Whats problem your old bios?Post here someone build new
      • 20921
      He posted it already .
      https://www.badcaps.net/forum/showthread.php?t=76449
      https://www.badcaps.net/forum/showthread.php?t=77123
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        Here try this just change me region i dont know is old or latest try and post results.
        • jontao
          • Jun 2019
          • 16
          • China
          I am an engineering notebook, the motherboard chipset is also QS, 涮 officially seems to be unable to start up, the boot flashes 5 times to report the motherboard failure, I need to see if the early BIOS can start, need to test.
          • alfa20fr
            • Jan 2012
            • 34
            Please need unlock zbook17g5
            thank you
              • 20921
              thank you
              Try this https://www.badcaps.net/forum/showthread.php?t=98539
              • hopkok
                • Oct 2014
                • 178
                • Slovakia
                Hi, masters.
                I am repairing, HP Zbook17 G5,
                shorted PCH was replaced, now unit start but FAN at full speed and black screen. If I remove RAM sticks, getting beeps.
                Can anyone help me to clen ME region? I tried, but no luck, still black screen. I used ME analyzer to check ME version, than ME tool to put new region in, what did I wrong? Anyway can be another problem on board, but would like to try properly cleaned ME (FAN at full speed could be ME region)
                S/N: 5CD92240D6
                Thanks for any help.
                • hardware1
                  • Sep 2021
                  • 2930
                  • N/A
                  Originally posted by hopkok
                  Hi, masters.
                  S/N: 5CD92240D6
                  Here's your New BIOS, try it and let me know.
                  all donations are welcome,
                  • hopkok
                    • Oct 2014
                    • 178
                    • Slovakia
                    Hi, I just test it, get picture and FANs spin normally. I gonna to install Windows and let you know if everything works. Many many thanks for now.
                    • hardware1
                      • Sep 2021
                      • 2930
                      • N/A
                      You're welcome.
                      • hopkok
                        • Oct 2014
                        • 178
                        • Slovakia
                        After install, everything is working well, once again, thanks for your help
                        • hardware1
                          • Sep 2021
                          • 2930
                          • N/A
                          Great.
                          • tccyo22
                            • Oct 2019
                            • 73
                            HP Zbook 17 G5 BIOS ME Clean
                            Has anyone got the firmware version 12.0.93.2331_COR_H_BA_PRD_EXTR-Y
                            I was going to clean the ME myself but I can't seem to find this version. I only have to 12.0.92.2145.
                            I've included my BIOS dump as well.
                              • 20921
                              Re: HP Zbook 17 G5 BIOS ME Clean
                              Serial number ?
                              • tccyo22
                                • Oct 2019
                                • 73
                                Originally posted by SMDFlea
                                Serial number ?
                                ah apologies
                                The serial number is 5CD9243G66
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11741
                                  ah apologies
                                  HP ZBook 17 G5 Mobile Workstation
                                  • tccyo22
                                    • Oct 2019
                                    • 73
                                    Thank you!
                                    • tccyo22
                                      • Oct 2019
                                      • 73
                                      Ok it's stuck on the BIOS screen again and no further, can get "Entering Setup..." hitting F10 but it never gets further than that.
                                      I think it may have restored the previous one from the EC? Is this a thing with Sure Start models?
                                      EDIT: Little lookup on HP's website it says it keeps a copy in the HP Endpoint Security Controller which I think has restored some of the bad parts, is there anyway I can update this controller to prevent this data mismatch?
                                      • munir100
                                        • Dec 2018
                                        • 178
                                        • uae
                                        i have hp zbook 17 g5 hag on log i try to me clean but not sceuefull hara is bios file
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          Yesterday, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • loopster
                                          Need help cleaning ME region on Zbook 17 G1 bios dump
                                          by loopster
                                          Hello guys,
                                          could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                                          Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                                          I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                                          Error 10: Failed to open with processed commands.
                                          Unable to open file: C:\Users\Elitebook...
                                          06-16-2024, 09:57 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
