Dell 5480 Bios need urgently
  • Murtaza527
    • May 2018
    • 257
    • Malaysia
    this is his original bios with computrace Plz clear
    thanks in advance
    • 21457
    Re: Dell 5480 Bios need urgently
    Try the bios at post #29 , if it doesn`t work then you need to flash the EC as well .
    https://www.badcaps.net/forum/showth...highlight=5480
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      No... Computrace activate in bios not need to ec flash..
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        My tool this exe file not extract correctly..
          • 21457
          Ok ,thanks ,i`ll remember that .
            • 21457
            Which exe do you mean .
            • imranromi
              • Jan 2015
              • 1288
              • Pakistan
              Dell bios exe 2 methods 1 change bios region remove and 2nd inside the bios and find.Bios region is easy just replace...
                • 21457
                If its lbe i don`t use it myself, i just use a few tools and hxd.
                • Murtaza527
                  • May 2018
                  • 257
                  • Malaysia
                  i tried that link bios but with that bios display comes but after few seconds off
                  i download this bios from internet but with this bios all otherthings working fine but trackpad only works in bios only i try update bios now fully updated but still trackpad not working
                  • Murtaza527
                    • May 2018
                    • 257
                    • Malaysia
                    anyone plz
                    • Murtaza527
                      • May 2018
                      • 257
                      • Malaysia
                      plz give me solution
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Just use the bios which works fully and clean me region to fix late display issue.
                        • Murtaza527
                          • May 2018
                          • 257
                          • Malaysia
                          that bios trackpad not working only working in bios
                          i dont know how to clean can you tell me bios me region and password how to remove and which software have to use
                          • foulou0238
                            • Mar 2014
                            • 109
                            • France
                            hello
                            test this one and let me know
                            • Murtaza527
                              • May 2018
                              • 257
                              • Malaysia
                              i have download this file earlier with this display comes but after few seconds its off
                                • 21457
                                Try this one. Consumer LP firmware, for the U version CPU`s
                                The EC is extracted from the bios update, its not the full size,it would need merging using a hex editor
                                • foulou0238
                                  • Mar 2014
                                  • 109
                                  • France
                                  Hello
                                  What’s is the ref of ur motherboard exctely ??
                                    • 21457
                                    @foulou0238 , the bios you posted at #14 has a dirty ME region, i took your bios, updated it with the latest bios update and cleaned the ME with the VPro_LP firmware ,it should be ok.
                                    • Murtaza527
                                      • May 2018
                                      • 257
                                      • Malaysia
                                      Try this one.
                                      with this totally no power
                                        • 21457
                                        Whats your service tag and motherboard id
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • Akhlz001
                                          by Akhlz001
                                          Today, 07:15 PM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
