Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
  • Andreasbest
    replied
    Re: Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
    Originally posted by Maxpower3
    here sur bad caps , just compare with other files
    edit :
    I forgot the 01 at the end and replace by 00 and not FF
    So clear everything with 00 including the 01 @ 00AB3090x03 ?
  • Maxpower3
    replied
    Originally posted by Andreasbest
    I mean if there is any online guide with instructions on how to remove the bios password from CF-53 dump by my self.
    It's not right to upload 30 bios dumps and wait others to work for me.
    edit :
  • Andreasbest
    replied
  • Maxpower3
    replied
    Is there any guide for CF-53 ?
    that is to say, not understood
  • Andreasbest
    replied
    Warning Mac adress and UUID
    if used in the same corporate network.
    So i must change the MAC address and UUID in every bios.
    Perhaps it will be easier if i remove the bios password on every bios my self.
  • Maxpower3
    replied
    So if we clean the ME and leave the SN as is it will be possible to work fine?
    I ask because i'll receive a pallet with 30 laptops for unlock.
  • Andreasbest
    replied
  • RethoricalCheese
    replied
    Afaik it contains SN etc and probably ME is not cleaned so it is way better to just upload your own dump and get the password removed on that.
  • Andreasbest
    replied
    Originally posted by rioreno
    try this...
    Hello.
    This bios dump can be used in multiple CF-53's OR it's unique per laptop?
    Thank you!
  • rioreno
    replied
    Originally posted by recep1982
    hi
    please bios password clear.
    try this...
  • recep1982
    replied
    hi
  • rioreno
    replied
    Originally posted by 94summit
    Please remove the password.
    post your full backup with spi programmer...
    your post files only bios region, no me region...
  • Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
  • AquaMan Ua
    by AquaMan Ua
    05-17-2025, 09:40 AM
  • aa10aa10
    Panasonic Toughbook CF-33 mk1 BIOS repair
    by aa10aa10
    Good day,
    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
    01-21-2025, 06:13 AM
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • adil12
    Panasonic toughbook cf53-as-50de bios password removal help
    by adil12
    hello everyone, can you please help me to clear the bios password from Panasonic toughbook cf53-as-50de
    thank you...
    09-14-2021, 10:39 AM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
