Panasonic touchbook cf-53 mk2/mk4
  • LenBios
    • 122
    • Ker
    #121
    Re: Panasonic touchbook cf-53 mk2/mk4
    i tried other MK2 to unlock, changed many things in the file but still asking directly for password, what did i wrong?
    Thank you
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1356
      • France
      #122
      Thank you
      try
      • LenBios
        • 122
        • Ker
        #123
        Originally posted by Maxpower3
        try
        working good
        what did you change in my file please?
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1356
          • France
          #124
          search end of key with uefi tools or compare my file with your . come back if you don't find it
          • LenBios
            • 122
            • Ker
            #125
            need more help or pictures please, i do not understand to much
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1356
              • France
              #126
              look in thread
              many occurrence of the end of the old encryption key.
              search and extract with UEFI TOOLS
              write 2 times again
              Search volume contains end of key "D8606B"
              • LenBios
                • 122
                • Ker
                #127
                look in thread
                i found 2 times
                is this correct now?
                • LenBios
                  • 122
                  • Ker
                  #128
                  i was able to unlock another MK2.... thank you very much for all your help
                  this time on boot is other LOGO not Panasonic Logo and one error see Picture
                  any idea how to change the Logo?
                  Thank you very much
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1356
                    • France
                    #129
                    at the end of the string there is 01. Do not change it to 00. Otherwise Panasonic logo at boot will go away.
                    you haven't read all thread
                    • LenBios
                      • 122
                      • Ker
                      #130
                      no no i did not delete 01, original was with Telekom Logo on boot.
                      Logo is there but Telekom not Panasonic
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1356
                        • France
                        #131
                        ok not understand ,look maybe utility panasonic
                        • LenBios
                          • 122
                          • Ker
                          #132
                          ok
                          • LenBios
                            • 122
                            • Ker
                            #133
                            @Maxpower
                            can you please check this file. unlock ok but password return
                            delete all but not working
                            thank you
                              • 22130
                              Thank you very much
                              here . EDIT: bios removed.
                              • LenBios
                                • 122
                                • Ker
                                #135
                                Originally posted by SMDFlea
                                here .
                                with this file no display
                                  • 22130
                                  You sure its another MK2 ,post the full model number .
                                  • LenBios
                                    • 122
                                    • Ker
                                    #137
                                    cf-53JWX1CFG
                                    • LenBios
                                      • 122
                                      • Ker
                                      #138
                                      @Maxpower
                                      thank you
                                      can not find any more end of key D8606B but still password returns
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1356
                                        • France
                                        #139
                                        not find ,look with SMDFlea to clean
                                          • 22130
                                          cf-53JWX1CFG
                                          Try again .
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • telpurleith
                                            Panasonic CF53 MK4 CF-532AWZYNG Password locked Bios
                                            by telpurleith
                                            Hello Guys, i have a CF53 MK4 with a locked bios. I wanna ask you if you could help me to remove it. I have read the bios by a programmer. I also tried to delete it by myself with a hex editor but no luck on MK4. I dont know what i am doing wrong.
                                            09-23-2023, 07:31 AM
                                          • AquaMan Ua
                                            by AquaMan Ua
                                            05-17-2025, 09:40 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • adil12
                                            Panasonic toughbook cf53-as-50de bios password removal help
                                            by adil12
                                            hello everyone, can you please help me to clear the bios password from Panasonic toughbook cf53-as-50de
                                            thank you...
                                            09-14-2021, 10:39 AM
