Panasonic touchbook cf-53 mk2/mk4
    • 22203
    Re: dump Bios eeprom25Q128A- Panasonic touchbook cf-53 mk2
    Originally posted by afroindustries
    can someone post or pm the requested bios file? thank you. best regards
    Post your bios backup .
    • RAVI KARAN
      • May 2020
      • 54
      • INDIA
      try this
      • fluxor
        • Nov 2012
        • 8
        Re: Panasonic touchbook cf-53 mk2/mk4
        Hi, I'm trying to unlock my bios. The Machine is a CF-53 Mk4 CF-532SLZACM and I have attached my bios dump. Any help is greatly appreciated.
        • rioreno
          • Feb 2009
          • 540
          • Indonesia
          try.. and goodluck
          • fluxor
            • Nov 2012
            • 8
            rioreno, Thanks sir, I tried to load that and I'm still locked out. I compared the original files to see what you changed, you were alot more cautious than what I saw in the other BIOS mods. Are you pretty familiar with the layouts of these BIOS' ?
            • rioreno
              • Feb 2009
              • 540
              • Indonesia
              #26
              i really sorry....
              this my bad...
              i was forget to clean 2nd nvram...
              now this is should works..
              try, and goodluck
              • fluxor
                • Nov 2012
                • 8
                thanks sir
                • fluxor
                  • Nov 2012
                  • 8
                  Do you know if this will work on another laptop of the same exact model ?
                  So I threw caution to the wind, and it seems to
                  Does make the serial number the same though and loses things like the total power on time
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    #29
                    Well, it works but might have issues. Like slow boot, wrong serial numbers and other data or some other errors. So it is always better to upload dumps from all machines and patch them separately.
                    If you still have the backup, just upload it.
                    • rioreno
                      • Feb 2009
                      • 540
                      • Indonesia
                      #30
                      agree with @RethoricalCheese..
                      if you have another device with passwprdbios or faulty bios, BETTER upload your backup here..
                      someone will help you , but you must be patience...
                      FYI : i have another case with same type CF53-4, with password not only at store at NVRAMs.. check this..
                      https://www.badcaps.net/forum/showpo...80&postcount=4
                      • fluxor
                        • Nov 2012
                        • 8
                        Rioreno, I foolishly jumped the gun, The machine does boot and the bios seems open, but there is a slight pause when it powers up. I think it may be doomed to just be that way.
                        • RethoricalCheese
                          • Mar 2013
                          • 1519
                          • Estonia
                          #32
                          You mean from pressing power button to displaying a logo takes time? Cleaning ME region should fix that.
                          • lex00
                            • Apr 2020
                            • 10
                            • Russia
                            #33
                            Originally posted by rioreno
                            try.. and goodluck
                            Hi!
                            Help me please with CF-53 MK3 bios lock.
                            • rioreno
                              • Feb 2009
                              • 540
                              • Indonesia
                              #34
                              Originally posted by lex00
                              Hi!
                              try this.. CF53-MK3
                              goodluck and please confirm
                              • lex00
                                • Apr 2020
                                • 10
                                • Russia
                                #35
                                try this.. CF53-MK3
                                Thank you! It's work!
                                • fluxor
                                  • Nov 2012
                                  • 8
                                  That is correct, it also has the serial of another machine displayed on it as well in the bios. But I'm currently away from home without access to the machine or tools to remove the chip again. I will post the bios when I have access if you'd be willing to clear that section out . Thanks
                                  • lex00
                                    • Apr 2020
                                    • 10
                                    • Russia
                                    #37
                                    DMI block with serial at A80000 adress in bios.
                                    • fluxor
                                      • Nov 2012
                                      • 8
                                      What do you folks use for hex editing the bios ?
                                      • lex00
                                        • Apr 2020
                                        • 10
                                        • Russia
                                        #39
                                        http://www.x-ways.net/winhex/index-m.html
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1519
                                          • Estonia
                                          #40
                                          Hex Editor Neo on windows, hexedit on linux.
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • telpurleith
                                            Panasonic CF53 MK4 CF-532AWZYNG Password locked Bios
                                            by telpurleith
                                            Hello Guys, i have a CF53 MK4 with a locked bios. I wanna ask you if you could help me to remove it. I have read the bios by a programmer. I also tried to delete it by myself with a hex editor but no luck on MK4. I dont know what i am doing wrong.
                                            09-23-2023, 07:31 AM
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • adil12
                                            Panasonic toughbook cf53-as-50de bios password removal help
                                            by adil12
                                            hello everyone, can you please help me to clear the bios password from Panasonic toughbook cf53-as-50de
                                            thank you...
                                            09-14-2021, 10:39 AM
