bios dump elitebook 840 g3
Re: HP Elitebook 840 g3 hp dxe update error
try .. write both bios chips ..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Last edited by SMDFlea; 04-02-2023, 12:22 PM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Re: bios dump elitebook 840 g3
yes, you can rewrite a new chip with a bios, if we have the bios ... post the full name and model of the laptop and the motherboard model ... let's see if we find the bios ..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thanks for the info. It's an HP 840 G3. Motherboard model number is 918313-601.Comment
if it works enter the DMI information
https://www.youtube.com/watch?v=9T57ktw8n3YLast edited by SMDFlea; 04-02-2023, 12:22 PM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Re: HP EliteBook 850 G3 corrupted extracted image
Hi all. I have a hp 850 g3 bought from a pawn store which had password locked bios. I desoldered the W25Q128 chip and made a dump read with ch341 programmer v1.29. After that, i've used HP bios unlocker to generate the unlocked bios, erased the chip, made a blank check and then write + verify. Made this operations few times and each time got an error that said that the info i have written on the chip is not the same as the one loaded in programmer. Soldered the chip altough i knew i have this error and the laptop either did not do anything, either started to work with no image on display and fan blowing at maximim. After furher searches on google found that only ASProgrammer works ok with this chip or CH341 programmer version 1.18. Hence, i used the bios clean me file posted by SMDFlea here because i suspected that my dump read might be corrupt, wrotted with asprogrammer and laptop start working again.
My curiosity now is if the dump read i made is corrupt or no, and if it's ok, can i unlocked it and then flash it via windows or BIOS? I am asking this because of the windows lincese which is embded on it and because i am not willing to dissasembly the laptop and desolder the chip again.
Here is my dump.Last edited by SMDFlea; 04-02-2023, 12:22 PM.Comment
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by GuestHello,
I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
I assume the BIOS update failed, so I searched for the BIOS chip.
I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
Can the corrupted...-
Channel: BIOS Requests ONLY!
by grimacelordThis laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
Motherboard model number: DA0PAMB46A1 REV: A
Secondary motherboard model number: 0PAB
SKU: 685K4UA
Serial number is: 5CD3223BJP
Recently reflashed this laptop with latest BIOS and once...-
by DynaxSCHi,
I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...-
11-06-2022, 05:22 PM -
- Loading...
